Old 11-27-2012, 09:39 PM   #1
CGfreak102
Fan#: 102291
What I Drive: 03 Aluminum ZX3 MTX
FF Reputation: 1 CGfreak102 Good Standing Member
Manual transmission not shifting in cold weather
So i have been having an issue with my 03 ZX3 Zetec, more specifically with the 5spd transmission.
Ever since it has got cold here in Wisconsin, my transmission upon start up does not want to shift at all. What i have to do to get it working again is pump the clutch for 5-10m and then i will be able get it into second or third and from there, i find if i do some laps in the parking lot across the street, shifting from 1st to 2nd that gets my clutch working normal again. Once i get on the road i find if i double clutch i can shift like there is nothing wrong.
When i push the clutch down, and push it into first or second. the car rolls forward and sometimes starts to stall (i see the rpms dropping so i put it back in neutral.)
When i first start up the car, the feeling of the clutch pedal is like there is nothing there. After pumping it for 5-10m i get the feeling of a clutch engagement and disengagement, albeit not how it was during the summer.
Now after driving for 20-30m it seems that this issue disappears, until i park the card for 3-4 hours and then it returns.
If the weather is above 50 degrees i do not have any issue besides at times its rough going into gear, but that has been like that since i got the car a year and a half ago.
Some other details, it has 138k miles on it. Got it when there was 116k, i have not changed the break fluid, or transmission fluid yet, not sure when the past owner has changed it. if i remember correctly the previous owner said he changed the clutch around 80-90k miles, or he has not changed it yet. Kinda forgot, whoops.
I remember last winter, it being stiff at times, but never this bad, this is entirely different and a lot harder.
When i checked the brake fluid container, it was on min and it seems old. So what im thinking about doing tomorrow is picking up some MTX fluid from ford dealership and some dot 3 fluid from a auto parts dealer and changing both of those. Would that be a wise choice?
Thanks
-CGfreak102
CGfreak102 is offline
Old 11-27-2012, 10:16 PM   #2
bringler26
Brokus
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
FF Reputation: 26 bringler26 Great Standing Member
I would advise having fresh fluids put in the trans. Use the Ford honey it is what most swear by here.
2003 Ford Focus ZX3(Brokus) - old and busted
2007 Subaru Impreza 2.5i - current DD
bringler26 is offline
Old 11-28-2012, 05:09 AM   #3
wisebag02
wisebag02's Avatar
Fan#: 106740
What I Drive: 2002 ZTS 5-speed
FF Reputation: 1 wisebag02 Good Standing Member
I did a tranny swap 3 months ago with new fluid (including 1 qt. of the $20 Royal purple stuff), new clutch, new slave cylinder, and a lot of new brake fluid ended up getting mixing with the old. Had no problem bleeding the air out of it. Replaced the clutch master cyl 2 yrs ago. All that and I'm having the same problem as CGfreak, Like the clutch isn't disengaging to let me shift.
Has anyone heard of running straight 75w or lower viscosity during the winter months?
Just wondered what the harm would be in using thinner gear lube and if it would result in smoother shifts.
And oh yea focus fanatics this is my first post!
'02 ZTS 5-spd, Volant CAI, CFM 65mm TB, Autolite coppercore, Steeda wires, SVT Header, 2.25" Magnaflow catback, SVT suspension, poly bushings, Steeda tri-ax short throw, 17" Enkei, Tom's tune
wisebag02 is online now
Old 11-28-2012, 09:27 AM   #4
jburkey28
Fan#: 105295
What I Drive: 2009 Cobalt SS/TC
FF Reputation: 1 jburkey28 Good Standing Member
Thanks
-CGfreak102
I have a similar problem with my SS. The clutch is very sticky and the back pressure on the pedal is strong. It doesn't like to shift at all.
I just let it warm up for a few minutes, pump the clutch a few times and it's better.
jburkey28 is offline
Old 11-28-2012, 12:50 PM   #5
Eiron
Fan#: 77999
What I Drive: 2002 Red Wagon
FF Reputation: 3 Eiron Good Standing Member
It's obvious that these are hydraulic clutches (as opposed to cable-actuated). Our Focus is an auto trans, but my Saab is a manual with a hydraulic clutch. The only info I don't know about the Focus' setup is if the hydraulic fluid is shared between the brake system & the clutch system, or if they use two separate reservoirs. Can you answer that for me?
Transmission oil should have absolutely nothing to do with this problem.
My Saab uses a shared reservoir. Of course, the standard maintenance interval for brake fluid has always been "replace every 2 yrs or 30k mi, whichever comes first." This is because brake fluid absorbs moisture from the atmosphere, & that water will eventually corrode the metal lines & caliper parts. With a shared reservoir, you should flush the fluid out of the clutch line at the same time that you do the brakes.
And that's as far as most people go (if they even think of it). However, I've learned over the years that the clutch really needs flushing more frequently in order to maintain proper feel & function. This is because the seals & pistons of the clutch system travel so much more than those of the brake system, & so they generate much more wear & debris that needs to be cleaned out. Because of this, I do my clutch at 1 yr intervals.
If your hydraulic fluid is of unknown age, flush both the brakes & the clutch systems. The fluid's probably pretty nasty. Drive it for a week or two, then flush just the clutch system again. The fluid will still look like crap, but it should be better than the first flush. At that point, you're good for another year. When next year rolls around, just do the clutch system again.
EDIT:
I forgot to say, these symptoms (indicating old fluid & deposit buildup) typically show up when the weather turns colder. Seals aren't as flexible as when it's warm out, so the hydraulics function much less efficiently & these symptoms start showing up. I just went thru this on my Saab, here in Northern Colorado, with the clutch engaging almost at the firewall. After performing the flush/drive/flush sequence I've been following for the past decade, my clutch engagement has now returned to the end of the pedal travel where it should be.
"Help, Mr. Wiza-a-ard!!"
Eiron is offline
Old 11-28-2012, 03:28 PM   #6
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
FF Reputation: 22 6SPD_soul Great Standing Member
It's a shared clutch/brake fluid reservoir, and I agree about disregarding trans fluid for now. If it were my car I'd bleed out whatevers in the hydraulic lines and get new fluid in, and make damn sure when refilling that you bleed out all the air.
I don't know what effect the ambient temperature is having and why the problem goes away, it just sounds like there's air in the system up until that point.
6SPD_soul is offline
Old 11-28-2012, 04:26 PM   #7
CGfreak102
Fan#: 102291
Just got done bleeding the clutch. When the fluid first came out it looked like oil. After that took it for a test drive and it works flawlessly. The test will be how it shifts tomorrow morning.
Thanks for the input guys.
Old 11-28-2012, 11:21 PM   #8
CGfreak102
Fan#: 102291
Update:
So i was driving home from dinner tonight and i noticed my foot was slippery. Looked down and noticed that my master cylinder was leaking, it was perfectly fine until i bleed the system today. i know i over filled the reservoir to the point when i put the lid in, it spilled out over the edged, do you think its just that? Going to monitor over the next few days.
Old 11-29-2012, 04:00 AM   #9
wisebag02
wisebag02's Avatar
Fan#: 106740
Thank you for your advice, 6SPD and Eiron, it seems that CGfreak and I need to stay on top of the condition of our hyd fluid since we have such aging cars.
Old 11-29-2012, 05:40 AM   #10
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
FF Reputation: 42 sleepyboy Great Standing Member
Buy-Sell-Trade Rating: (10)
Sounds like the clutch pedal master cylinder gave out on you. It has nothing to do with how much fluid you put in. That would explain why it got air in it and made it hard to shift and also why pumping it would make it work for a little while. It's a common part to go out on our cars with age.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
