2010 focus air in lines after brake job - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-22-2012, 05:54 PM   #31
amc49
Fan#: 96610
Points 3,390, Level 36
Points: 3,390, Level: 36 Points: 3,390, Level: 36 Points: 3,390, Level: 36
Level Up 27% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Yeah, slow as in brain power in mHz...........I NEVER bleed all 4 lines when pulling a caliper. If you block off end of disconnected line to not leak and quick enough doing it, the amount of fluid in master never gets low enough to expose air, the other 3 lines will still be full also. A simple 2 minute single line bleed and pedal solid as a rock in every case.
Odds heavily in favor of nothing wrong with master unless someone has now messed it up.
Sad how bad the Ford techs can be now, but same I guess as when we had a shop across the street from a GM dealership, we fixed LOTS of GM cars they couldn't figure out all through the '70s. They sure seem to have no trouble figuring out the highest priced part that 'goes bad' on your car though. Odd how that is the one that always seems to be at fault...............
amc49 is offline
Old 12-30-2012, 06:05 PM   #32
ghostrider_14
Fan#: 60668
What I Drive: 2013 corolla s/2005 black zxw
FF Reputation: 1 ghostrider_14 Good Standing Member
now they are saying its the abs module. They said 3 will bleed and 1 wont.
ghostrider_14 is offline
Old 01-01-2013, 10:22 PM   #33
amc49
Fan#: 96610
Forum Activity 54%
From one bad caliper to this. I gotta say it, you're being milked like a cow brother. Gross incompetence seems to be the order of the day. Or they're not, and that is even scarier.
amc49 is offline
Old 01-04-2013, 11:53 PM   #34
ghostrider_14
Fan#: 60668
they have changed part after part and it still wont bleed so now ford is sending in a specialist because they have never seen this problem before.
Old 01-17-2013, 11:13 PM   #35
ghostrider_14
Fan#: 60668
Finally got the car back 1200 dollars later. They said they had to change the abs module 4 times because everyone they put in was faulty.
Old 01-17-2013, 11:16 PM   #36
GO.army.1969
GO.army.1969's Avatar
Fan#: 69605
What I Drive: 2008 Vapor Silver Coupe 5 speed
Points 2,851, Level 32
Points: 2,851, Level: 32 Points: 2,851, Level: 32 Points: 2,851, Level: 32
Level Up 68% Completed
FF Reputation: 15 GO.army.1969 Great Standing Member
Good lord that sucks
NW Posse#10 Team Duratec#69
F2 Header, Steath Exhaust, CAI, AR103, Tuned by Randy Fswerks, DGR Coil Overs
DOMINANT front and rear LCA DOMINANT endlinks Massive toe and camber arms
GO.army.1969 is offline
Old 01-19-2013, 06:34 PM   #37
amc49
Fan#: 96610
Forum Activity 54%
'They sure seem to have no trouble figuring out the highest priced part that 'goes bad' on your car though.'
I rest my case Your Honor.............
amc49 is offline
