2010 focus air in lines after brake job - Page 3 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Wheels & Tires - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, offset, wheel patterns and more.
Sponsored By:
Tire Rack
Old 11-30-2012, 08:06 PM   #21
GO.army.1969
GO.army.1969's Avatar
Fan#: 69605
What I Drive: 2008 Vapor Silver Coupe 5 speed
FF Reputation: 15 GO.army.1969 Great Standing Member
You may have a bad master cylinder then ??
NW Posse#10 Team Duratec#69
F2 Header, Steath Exhaust, CAI, AR103, Tuned by Randy Fswerks, DGR Coil Overs
DOMINANT front and rear LCA DOMINANT endlinks Massive toe and camber arms
GO.army.1969 is offline
Old 12-01-2012, 06:00 AM   #22
fast*st
Fan#: 93319
What I Drive: 1999 F350 Dually, 03 SVT ZX3
FF Reputation: 1 fast*st Good Standing Member
That could be possible but the good before/bad after almost says that the master is full of air. I'd love to see how much fluid comes out with each pedal cycle. Gotta be air bound.
fast*st is offline
Old 12-01-2012, 02:53 PM   #23
ghostrider_14
Fan#: 60668
What I Drive: 2013 corolla s/2005 black zxw
FF Reputation: 1 ghostrider_14 Good Standing Member
After taking it for a ride i discoverd that the driver front and passenger rear rotor and drum were hot and the passenger front and driver rear were ice cold.
ghostrider_14 is offline
Old 12-01-2012, 04:03 PM   #24
sailor
"Elder"
sailor's Avatar
Fan#: 57268
FF Reputation: 67 sailor Excellent Standing Member
That would match the "dual diagonal" nature of the system, It's set up that way so you have 1 front & 1 rear if there is a leak in one half of the hydraulics.
Is the driver front the one you replaced?
sailor is online now
Old 12-01-2012, 05:00 PM   #25
ghostrider_14
Fan#: 60668
no i replaced the passenger side front caliper.
Old 12-02-2012, 11:53 AM   #26
sailor
"Elder"
sailor's Avatar
Fan#: 57268
OOPS - I should have said pass. front....
SO, the one not working right IS the one you replaced....
At this point in a PITA, if it was in front of me I'd start re-checking everything to rule out any "simple" or "stupid' problem before giving up & replacing the master cyl.. (As one prev. poster mentioned, they CAN give up from the exercise of bleeding them but that is more common for older cars)
Possible issues:
Leak at any connection disturbed in the replacement process.
Replacement caliper "jamming up" in some manner so it flexes instead of pumping up properly to press on the pads. Look at it when someone steps on the pedal, this issue is usually obvious when you can watch it working, you'll see it flex & return to it's prev. position instead of only moving SLIGHTLY as pressure is applied. Pads can be "stuck", calipers can not move right on their pins, the list goes on....
Next "odd" one I've seen SHOULD be "obvious", but I HAVE seen it happen. The new caliper COULD be the wrong one! Believe it or not, I HAVE seen a "mirror image" situation where the new caliper was for the wrong side, and when bolted in place the inlet was on top & the bleeder screw on the bottom. This makes it virtually impossible to bleed ALL the air out of the new caliper and is ACTUALLY the most common cause for the issue you are dealing with. It bolts up fine, but just doesn't work right! And in looking for a deeper issue, the "obvious" easily gets missed.
Lastly, buying or borrowing a vacuum or pressure bleeding tool can help in making sure the system is completely bled of air.
Good Luck, let us know how it all turns out!
Old 12-06-2012, 08:34 PM   #27
ghostrider_14
Fan#: 60668
Well its been at the dealer since Monday. They changed the wheel cylinder because they thought that was the problem and it wasn't but they are still charging me for it because they are stating that it was "bad" anyways. They had to contact ford because they could not figure out the problem and after running some test that ford told them to run they came up with the ecu/hcu for the abs being bad. The part itself is 700 dollars and they have never seen one go bad on a focus especially one with only 40k on it. The part will be in tomorrow and so far my bill is up to 1200. They said they will eat it if this isn't the problem and they have no where else to turn if its not.
Old 12-21-2012, 07:52 PM   #28
ghostrider_14
Fan#: 60668
Well almost 3 weeks later and the car is still at the dealer and when i called for an update the other day i was rudely told to not call them they would call me. They say they are on the 3rd ecu/hcu unit for the brakes because each one they get is faulty. Don't know what my next step should be all i know is im done with this local dealership ill travel to another ford dealer for my next focus.
Old 12-21-2012, 10:02 PM   #29
elsolo
elsolo's Avatar
Fan#: 96835
Their technicians must be slow.
It sounds about the same as,
"I replaced the fuse three times, and each time I blew. I am out of ideas."
elsolo is offline
Old 12-21-2012, 10:04 PM   #30
elsolo
elsolo's Avatar
Fan#: 96835
http://www.speedwaymotors.com/SSBC-S...Kit,50352.html
This brake pressure gauge kit tells you how much pressure you are getting at each caliper. Includes adapters to 6 common fittings:
elsolo is offline
