Lemme get some input! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-27-2012, 12:20 AM   #1
TheAllMightyFocus
Fan#: 99790
What I Drive: 2012 Ingot Silver Focus SE HATCH
FF Reputation: 1 TheAllMightyFocus Good Standing Member
Was cruising through the classifies on craigslist the other night and found a hidden gem with the right bolt pattern. Its a great deal, plastidipped dark anthracite grey. I would be putting them on my Mk3 ingot silver hatch, what do you think?
http://www.google.com/imgres?num=10&...9,r:4,s:0,i:97
there jaguar s type triton wheels, keep in mind they are plastidipped dark.
TheAllMightyFocus is offline
Old 11-27-2012, 12:38 AM   #2
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,050, Level 66
Points: 10,050, Level: 66 Points: 10,050, Level: 66 Points: 10,050, Level: 66
Level Up 50% Completed
Forum Activity 24%
http://www.focusfanatics.com/forum/showthread.php?t=273962
See the wheel and tire guide for ideas that should work. I'm not sure what the hub bore spacing is on the jaguar wheels though as the Focus ones are 63.9 mm. Chances are they will work fine as long as you get them centered properly before tightening down the lugs, might need the wheel adapters to center the wheel on the hub though.
suss6052 is offline
Old 11-27-2012, 12:54 AM   #3
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
What I Drive: 2014 Mustang 3.7L SGM
Points 7,935, Level 59
Points: 7,935, Level: 59 Points: 7,935, Level: 59 Points: 7,935, Level: 59
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 7%
FF Reputation: 11 Joeywhat Great Standing Member
Assuming "wheel pilot diameter" means hub diameter, then they should fit. A quick Google search showed the wheel pilot diameter of that year S Type to be 2.49 inches, or 63.246mm.
Hatch Nation #29
Joeywhat is offline
Old 11-27-2012, 01:09 AM   #4
TheAllMightyFocus
Fan#: 99790
60mm offset on the wheels says the seller!
Old 11-27-2012, 04:20 AM   #5
Ox-y-GenIII
Ox-y-GenIII's Avatar
Fan#: 90008
What I Drive: 2012 Oxford White SEL Hatch
Points 5,075, Level 45
Points: 5,075, Level: 45 Points: 5,075, Level: 45 Points: 5,075, Level: 45
Level Up 63% Completed
FF Reputation: 4 Ox-y-GenIII Good Standing Member
They should fit. Not guaranteeing but the Jaguar has 12.5" rotors and two piston calipers, bore size might just be perfect. And the Jaguar came with 245/40/18s for tires, I'd go down to a 235/40/18 to keep the Speedo the same and your profile the same.
if they are meant for a 400hp V8 Jag then I bet they are good enough for a Focus. Try them out. Oh and they were an $800 option to upgrade from the stock 17" wheels.
Ox-y-GenIII
2012 Oxford White Focus Hatchback
Dyno #'s 164.35 HP 147.12 TQ
Ox-y-GenIII is offline
Old 11-27-2012, 04:22 AM   #6
Ox-y-GenIII
Fan#: 90008
And I said the thing About the brakes because at 5mms more inward on your offset (60mm jag wheel vs. 55mm Focus Titanium wheels) it should not have any impact on rubbing.
Ox-y-GenIII
Old 11-27-2012, 07:58 AM   #7
TheAllMightyFocus
Fan#: 99790
Any input on if the wheel will look descent on the Fo?
Old 11-27-2012, 08:03 AM   #8
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
Generally, going with an offset that's higher than OEM, isn't recommended.
However, if you like them, go for it. They should work.
Joined the dark side.
Zillon is offline
Old 11-27-2012, 09:25 AM   #9
TheAllMightyFocus
Fan#: 99790
worst case scenario wheel spacers will follow them
Old 11-27-2012, 11:56 AM   #10
Indy'sexclusiveZx3
Fan#: 65419
What I Drive: 2013 tuxedo black st
FF Reputation: 7 Indy'sexclusiveZx3 Good Standing Member
Make sure you get lugs with the wheels because jags take a special lug and I know to get them from jag they are over 7.50 a lug around here
Parts for sale check out my thread, got a new st need to sale old parts
Indy'sexclusiveZx3 is offline
