Is the antenna the problem? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-21-2012, 05:09 PM   #1
Sevenev
Fan#: 106511
What I Drive: 2007 Pitch Black ZX3
FF Reputation: 1 Sevenev Good Standing Member
Hello! I've been lurking for quite a while now but finally decided to make an account. Ever since I purchased my used 2007 focus, I've had trouble with radio reception. Everything is stock. Could my problem just be the antenna bouncing around everywhere while I'm driving? Because while stationary, if I angle the very flexible antenna pointed up, (usually slanted backwards) I get much better reception. I owned a focus of the exact same model prior to buying the car and I had no problem whatsoever, so is my assumption correct that I just need a new antenna? If so can anyone point me in the direction of a good shorty antenna I can purchase (Even if it's not the problem I would like a short antenna :P)? Or are there any other solutions you can offer? Thank you!
Sevenev is offline
Old 11-21-2012, 10:53 PM   #2
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,711, Level 78
Points: 14,711, Level: 78 Points: 14,711, Level: 78 Points: 14,711, Level: 78
Level Up 66% Completed
Forum Activity 11%
FF Reputation: 16 Elizabeth Great Standing Member
The antenna cable connects to the radio chassis with a really cheap connector. It is a push on tube with a wire inside.
You should check the backside of the radio to see if the antenna cable is stuck on good and proper.
It may be loose.
Elizabeth is offline
