My build thread(euro content lol) - Page 37 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-08-2013, 09:52 PM   #361
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
What I Drive: 03 CD Silver ZX5
Points 11,527, Level 70
Points: 11,527, Level: 70 Points: 11,527, Level: 70 Points: 11,527, Level: 70
Level Up 70% Completed
Forum Activity 2%
FF Reputation: 59 katiekay Excellent Standing Member
Buy-Sell-Trade Rating: (48)
Originally Posted by ah1f39 View Post
LED only work one way. Did you try turning the bulb arround?
I feel so stupid lol I turned it the other way and it worked, thanks!
Originally Posted by Chick View Post
Nice
Thanks!!!
Hatch Nation #8
September 2012 Ride of the Month
katiekay is offline
Old 05-09-2013, 10:41 AM   #362
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,257, Level 35
Points: 3,257, Level: 35 Points: 3,257, Level: 35 Points: 3,257, Level: 35
Level Up 38% Completed
Forum Activity 18%
FF Reputation: 4 qweesy Good Standing Member
Buy-Sell-Trade Rating: (6)
so pretty easy to put on the new headliner?
qweesy is offline
Old 05-09-2013, 11:04 AM   #363
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Points 12,749, Level 73
Points: 12,749, Level: 73 Points: 12,749, Level: 73 Points: 12,749, Level: 73
Level Up 75% Completed
Forum Activity 78%
Activity: 78% Activity: 78% Activity: 78%
FF Reputation: 10 SvviftSVT Great Standing Member
Originally Posted by pyroinsa View Post
I really don't want to Looks too hard
its super easy.. the only hard part is getting the black clip off the odometer itself.. everything else really is a piece of cake.
Track build has begun.
slow and steady.. but its going
SvviftSVT is online now
Old 05-09-2013, 11:24 AM   #364
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
Forum Activity 2%
Well, I ran into a few problems. The grab handles were destroyed when I removed them(every damn clip broke). The interior panels over the small back windows would only come out if I disassembled the rear seatbelts, so after fighting with the grab handles, I didn't bother trying to remove those panels. I slid the headliner out the back, but those rear panels were fighting me every step of the way.
Once I got it out, I had to remove the old fabric and foam from the board. That was a pain in the ass to do. The board was so thin that I thought I was going to destroy it while I was peeling off the fabric, thankfully it didn't. Once that was off, it took me another 4 hours to scrub off all the foam so the glue would have a clean surface, I used a couple green scratch pads to do that, there might have been a better way but I couldn't find one. After the foam was off and I was left with a paper-thin board, I began wrapping it like I do with vinyl. I started spraying a liberal coat of headliner glue(it came with the new headliner) in the largest and deepest area first(the rear section). Once I put the fabric on top of it, it immediately stuck and I couldn't move it to re-position it in any way, luckily I didn't need to move it. Well I wish I could have had a little bit of play with it because there are a few imperfections in it, but it still came out great. I might have sprayed too much glue because I ran out 3/4 the way done. So I ran to Home Depot to get a can of 3M #77 spray adhesive, I wish I would have started with that because it was easier to work with. After it was done, I let it dry for a day before I cut it off of the cardboard I had laid it on, yes the overlap had glued itself to the cardboard. I am glad that I had went dumpster diving for some extra large boxes to protect my shitty carpet in my house. I then cut out the holes for the lights, sunroof, etc. I went through 5 razor blades doing that, the damn suede dulled the blades real quick!
Now it was time to re-install it. I had to fight to get it back in the hatch because of the rear trim, I got it in far enough so I could open the rear doors and start to pull, I kept going back and forth between the d/s and p/s rear doors, pulling it in a few inches at a time. When it was finally in, I put it up over the rear first, since the trim was still in. Then I popped in the 2 plastic buttons in the rear. I moved up to the front to secure it with the visors. I started with the visor clips close to the domelight so that way I could still bend the headliner down to look where the screw goes. Once I got those on, the domelight and all the rest of the trim went back on easy, until it came time to put the trim ring around the sunroof. The new material was thicker than the old so I put the ring around the headliner first, then started at a corner to secure it to the metal ring as well. I had to push hard, rally hard and the more I would work my way around the ring, the more it would pop back off in areas I had just done, but I kept working it around until it finally sat secure.
Headliner removal took about 1 1/2 hours.
Headliner clean-up took about 5 hours
Headliner wrap took about 2 hours (because of a run to the store for more glue)
Headliner dry 24 hours
Trim vinyl wrap took about 1 hour
Headliner re-install took about 1 1/2 hours because I didn't have to worry about re-installing the grab handles.
Total time spent was about 3 days.
Hatch Nation #8
katiekay is offline
Old 05-09-2013, 11:27 PM   #365
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 36,803, Level 100
Points: 36,803, Level: 100 Points: 36,803, Level: 100 Points: 36,803, Level: 100
Level Up 0% Completed
That's sounds about right. I did mine in two days but I was a serious pain in th arse. I wouldn't do it again any time soon. I too had imperfections but not very many people are going to be looking at your headliner. I had to mess with side curtin airbags too. Lol
Sent from 34.0764 N, 118.4296 W
TheGlassMaker is offline
Old 05-10-2013, 12:44 AM   #366
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
Forum Activity 2%
Yeah, I won't be doing that again! lol Only me and my daughter look at the headliner, we like to play tic tac toe on it
So thanks to ah1f39 for letting me know that my bulb was reversed, I decided to take some pics!
This was taken with the windows up, all the lights on!
and just for the hell of it!
Hatch Nation #8
katiekay is offline
Old 05-10-2013, 06:20 AM   #367
Drumr90
Drumr90's Avatar
Fan#: 99659
What I Drive: 2006 Black ZX5 auto
Points 3,816, Level 39
Points: 3,816, Level: 39 Points: 3,816, Level: 39 Points: 3,816, Level: 39
Level Up 11% Completed
FF Reputation: 3 Drumr90 Good Standing Member
Looks good man.
Ive been bleeding ford blue since birth.
CO2 is nutrition not a polluitant ask a tree.
Hatch nation #03
Rally revolution #06 [HOONIGAN]
Team Duratec #30
Drumr90 is offline
Old 06-13-2013, 05:53 PM   #368
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
Forum Activity 2%
More of a pic update lol
Here are some newer pics - all cleaned up!
My showboard and all my Focus literature:
Kinda a better pic of the showboard:
I still have a few little things that I want to take care of but due to unforseen events that happened last month, I no longer have the money right now to keep going with it.
I hope you all enjoyed for now, maybe after FocusFest, I'll start concentrating on the motor.
Hatch Nation #8
katiekay is offline
Old 06-13-2013, 10:13 PM   #369
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,188, Level 96
Points: 26,188, Level: 96 Points: 26,188, Level: 96 Points: 26,188, Level: 96
Level Up 84% Completed
Forum Activity 55%
Such a clean looking car; definitely one of my favorites
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 06-14-2013, 09:13 AM   #370
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
Forum Activity 2%
Thanks!
Hatch Nation #8
katiekay is offline
