Differences between a 2012 and a 2013 focus. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-19-2012, 10:01 AM   #1
powermax
powermax's Avatar
Fan#: 105453
What I Drive: Ex 2012 Ford Focus Sedan SE
FF Reputation: 2 powermax Good Standing Member
Arrow Differences between a 2012 and a 2013 focus.
I Drove a SE Sedan 2013 loaner today it has pretty much same mileage as mine 2012 around 1500kms.
Higher idle speed, my 2012 is always around 625rpms, the 2013 was always a bit over 750rpms, I believe they did that to reduce idle vibration.
SE looks cheap without the fog lights.
Larger letters in the fuel and cooler temp. gauges, the tach doesn't have the smaller lines every 250 rpms, only every 500rpms.
Tranny felt exactly the same after almost an hour of heavy traffic the clutch coupling noise (famous gridding noise) started to get louder and some shuddering started to happen I was surprise that it was more noticeable in the 2013, my 2012 does the same thing but not so noticeable.
I notice some flimsy foam inside the front fender that I didn't noticed on mine, I'm not sure if that is a 2013 add on or I just didn't notice on mine
powermax is offline
Old 11-19-2012, 10:33 AM   #2
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,057, Level 67
Points: 10,057, Level: 67 Points: 10,057, Level: 67 Points: 10,057, Level: 67
Level Up 2% Completed
Forum Activity 22%
Activity: 22% Activity: 22% Activity: 22%
Target idle speed has always been 680 rpm at idle without the a/c on not 625 rpm for the 2012 MY.
If they added more insulation to the wheel arch/ front fender liner instead of the plastic fender shield as used in 2012 that might be an attempt to quiet/ quell suspension noise from entering the cabin.
suss6052 is online now
Old 11-19-2012, 11:18 AM   #3
JonathanGennick
JonathanGennick's Avatar
Fan#: 105685
What I Drive: 2013 Race Red Focus SE
FF Reputation: 1 JonathanGennick Good Standing Member
Those of us with aging eyes who are staring down bifocals really appreciate that.
I was thinking this weekend that Ford ought to offer a Large Print Edition.
Yes, I'd like that Focus SE in a Large Print Edition please .
JonathanGennick is offline
Old 11-19-2012, 12:38 PM   #4
ScullyZX2
ScullyZX2's Avatar
Fan#: 106049
What I Drive: 2013 Race Red SE HB
FF Reputation: 1 ScullyZX2 Good Standing Member
They also changed the center console. Moving the hand brake forward and the change cup behind the shifter (ATX). Different wheel choices.
2013 Race Red SE 5dr HB 17" 201 Package
USMC 85-92 Gulf 1 VET
ScullyZX2 is offline
Old 11-19-2012, 12:59 PM   #5
Kaaru
Kaaru's Avatar
Fan#: 96763
What I Drive: '12 Oxford Wh. SEL Sedan 28/07/2011
FF Reputation: 1 Kaaru Good Standing Member
I drove a SE flex fuel 2013 loaner for 2 days also. Things I have noticed that I like about the 2013:
Overall ride is quieter, less road noises gets into the cabin. Smoother ride/operation in general.
The 2 little rubber lips they added to the cup holders. These are pants savers, really, and were able to hold that big bucket of cofee I bring along every morning.
Adjustable head rest. I was able to acheive a comfortable driving position with the loaner. I want those. Great stuff!!
2012 Oxford White SEL Sedan
303A + winter package + Moonroof + 16'' OEM
Kaaru is offline
Old 11-19-2012, 06:17 PM   #6
doublej
Fan#: 100611
What I Drive: 2012, yellow blaze, SE Sport hatch
Points 31, Level 1
Points: 31, Level: 1 Points: 31, Level: 1 Points: 31, Level: 1
Level Up 62% Completed
Forum Activity 2%
FF Reputation: 0 doublej Newbie
12,s had adjustable head rest! Regular suspension is softer (mush) in the 13,s unless you grab the sport package.
doublej is offline
Old 11-19-2012, 08:52 PM   #7
Kaaru
Kaaru's Avatar
Fan#: 96763
Hmm, I must have a job 1 car then 'cause my head rests are the type that pushes your head forward.
Kaaru is offline
Old 11-19-2012, 09:23 PM   #8
powermax
powermax's Avatar
Fan#: 105453
Just found out another difference about the 2013, the car won't roll back even after a few seconds.
The headrest in my 2012 is adjustable the seats are identical.
powermax is offline
Old 11-19-2012, 09:40 PM   #9
cobie56
Fan#: 84403
my '12 doesn't roll back at all... not since my latest TSB last spring....
cobie56 is offline
Old 11-19-2012, 09:42 PM   #10
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 22%
Well yes, job 2 builds built after the week of 4/10/12 had the four way head rests made standard.
Technically the 2013 should act exactly like 12B37's programming where if you wait more than a few seconds it will still roll backwards, otherwise it would damage the clutch or have to hold the brakes longer than it was intended to be used for.
Also if you don't fully depress the brake enough to engage the hill start assist the car will still roll back.
