DCT issue/ Rear Main Seal - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-21-2012, 08:56 PM   #31
Ysteven
Fan#: 101029
What I Drive: 2012 oxford white sel, H2, F-150
FF Reputation: 1 Ysteven Good Standing Member
Originally Posted by cheekedave View Post
Hey guys.. I hope this is the right topic. I was just changing my oil (first time doing it myself on this car) and I noticed a sort of leak where the transmission is. Do you guys think this is normal?
Could someone help provide some insight? Oil change went fine. You can see where it is, the oil filter is on the left (front of the engine/car).
I appreciate the help!
Dave
Wow. Here you go. I bet you have a shudder and rattling notice when gear switches. Most likely your clutch contaminated with oil. It will be impossible to tell though which seal is leaking(engine or trans).
Have them to fish camera thru starter opening, at least that's what they told me how they diagnosing clutch contamination.
By the way are you in the right thread? Trans issue?
Ysteven is offline
Old 12-21-2012, 09:03 PM   #32
Ysteven
Fan#: 101029
Dave
Dave, sorry didn't answer your question. It's in the DRY clutch department. So, NO, it's not normal. If you don't have any issues now then you will later when clutch will get oily. I think I had my issues started TOO AT FIRST OIL CHANGE.
Investigate it, try to clean with alcohol, dry it, and see if it back. Shouldn't be any oily spot there. Good luck.
Ysteven is offline
Old 12-21-2012, 09:07 PM   #33
cheekedave
Fan#: 103448
What I Drive: 2012 Focus SEL Silver
FF Reputation: 1 cheekedave Good Standing Member
Hey Ysteven,
I believe I am now in the right thread... I do get random shudders and it seems to get worse. I was changing my oil and I saw this right above my face and the first thing I thought of was "This is not right"... I just snapped the pictures. I assume this is not supposed to happen. I just wanted to confirm with you guys because I don't fully trust the dealership.
cheekedave is offline
Old 12-21-2012, 09:08 PM   #34
cheekedave
Fan#: 103448
Also to add, this is technically my second oil change. First was at the place I bought it from, then today I did my own change (to synthetic). I saw this BEFORE i changed the oil however.
Old 12-21-2012, 09:10 PM   #35
Ysteven
Fan#: 101029
Hey Ysteven,
I think this picture can get you seal replacement pretty easy. But if you don't have any problems, don't go there. IF its not broken, don't fix it!
Happy holidays.
Steven
Ysteven is offline
Old 12-21-2012, 09:13 PM   #36
Ysteven
Fan#: 101029
No matter if its 1st or 101st, that area shoud be dry. New focus designed with DRY CLUTCH. Any oil in there will cause disaster to cultch.
Ysteven is offline
Old 12-21-2012, 09:17 PM   #37
cheekedave
Fan#: 103448
So is this why they are replacing clutches? I am going to bring mine in. I do notice my car jerk.. especically when im in stop/go traffic. I appreciate your help! If I didn't change my oil I wouldn't have seen this and I would bet anything my dealer wouldn't :)
Thanks!
Old 12-21-2012, 09:24 PM   #38
Ysteven
Fan#: 101029
Thanks!
A lot of people on this forum dreaming to get this picture, cause dealer won't do anything unless get visual, they need prove that oil leaking. Each case is unique, most don't get that stain cause trans and engine screwed together tight(all tight ) I mean some metal diffusion is works better that gasket. (I mean two part screwed that good, becomes like solid(mechanical therm MARRIED)).
Again, if you don't have any major issues, forget about it.
Ysteven is offline
Old 12-21-2012, 09:31 PM   #39
cheekedave
Fan#: 103448
Well they did do that transmission update. I did not notice anything different. However, the one thing that bothers me is I can press slightly on the gas, and when I let go it sort of jerks like it did not like getting gas :S
Same for being in reverse. I would rather them document it now while under warranty than to wait and get screwed once I am out of the warranty :( I will let you know what the outcome is!!
Old 12-22-2013, 11:43 AM   #40
wavsine
wavsine's Avatar
Fan#: 118470
What I Drive: 2013 Focus SE Oxford White Hatch 5m
Points 18,797, Level 86
Points: 18,797, Level: 86 Points: 18,797, Level: 86 Points: 18,797, Level: 86
Level Up 90% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 16 wavsine Great Standing Member
Originally Posted by dan50 View Post
It's too bad Ford didn't include a "weep hole" in the clutch housing that would allow engine oil/trans fluid to escape and identify a problem. Or an access port at least. Would sure make diagnosis easier.
Use a Motorcraft FL-400S filter to increase filtration media and oil quantity. (Drop in for FL-910S)
Synthetic oil in GDI engines
www.focusfanatics.com/forum/showthread.php?t=324396
wavsine is online now
