Front right popping/crunching. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-18-2012, 08:33 PM   #1
04ZTSJelf
04ZTSJelf's Avatar
Fan#: 100701
What I Drive: 04 2.3 Sedan
Points 1,422, Level 21
Points: 1,422, Level: 21 Points: 1,422, Level: 21 Points: 1,422, Level: 21
Level Up 22% Completed
Forum Activity 8%
FF Reputation: 1 04ZTSJelf Good Standing Member
Buy-Sell-Trade Rating: (7)
Hey fellow focus enthusiasts! I wanted to know if anyone has experieced this problem or knows what it could be. Any help would be appreciated. I bought my car back in june, and when I did, it made a popping-like noise in the front right side when I turned all the way in either direction (which was only sometimes to park, and not often). I took it to a trusted shop for a general tune-up and brakes shortly after, and when they got it on the lift, they noticed that one of the sway bars was completely off, and another was off on one end, so I had to get those replaced too. Luckily they didn't charge me anything for labor on those because they aid it was a quick fix. I asked about the popping and they said everything looked good, so they didn't know what it was. But recently, the popping is more frequent and it now makes a noise like somethings loose when I go over a bump or dip with the right front at low speeds (25mph through my neighborhood is when it happens mostly) and I think it has thrown my alignment outta wack because over the past week it has begun to pull right slightly. Its easily drivable, but just wanted to know if this is something simple, as I would love to start giving my car more performance but this seems more important.
Thanks for any help!
Also, if its important, I drive an 04 sedan with the 2.3.
04ZTSJelf is online now
Old 11-18-2012, 09:50 PM   #2
bumble21
Fan#: 95826
What I Drive: 2001, Black&Yellow, ZX3
FF Reputation: 1 bumble21 Good Standing Member
I'm assuming is was missing sway bar links not the actual sway bar. Your best bet is to jack up the front right tire and kinda grab onto stuff and see if anything moves. Not sure what the popping sound is but if your trying to track down a loose part just grab it and shake it around a little and see if it moves.
bumble21 is offline
Old 11-19-2012, 12:02 AM   #3
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,314, Level 77
Points: 14,314, Level: 77 Points: 14,314, Level: 77 Points: 14,314, Level: 77
Level Up 66% Completed
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
FF Reputation: 15 Elizabeth Great Standing Member
The most common problem creating a popping noise when in a turn or turning the wheel hard is worn ball Joints.
Worn ball joints is serious, because they can break off without warning and that will leave your front wheel sidways.. Even if you are moving at 60mph
So it matters to ask if that is the issue.
the car needs to be put up on a lift and the motion checked. It may take some hard pushing to 'knock' the worn ball over. Or it may be easy. All depends HOW it is worn. Someone who understand the ball joint should look at them
Usually the noise is a sudden loud 'clunk' especially at parking manuver speeds.
If you have that.. Then i say get it checked out.
In other posts I have said ignore stuff because it can wait.
A really worn ball joint should NOT wait. It is unsafe to drive. It does NOT need to be towed, but realize the wheel falling off is not good.
Elizabeth is offline
Old 12-06-2012, 04:14 PM   #4
04ZTSJelf
04ZTSJelf's Avatar
Fan#: 100701
Forum Activity 8%
Didn't want to start another thread on this while this one was already here.
Well.... my car just got an oil change and I asked them to check out the noise in the front. I wasn't there to talk to the guy who checked it out but he said (on the phone) he looked at everything and it was good, but he heard the noise and it could be a 'strut tire'. Thats what I heard over the phone, but I assumed he meant 'strut tower'. He said to know for sure they would have to take it apart and look and the part, and if thats what it is, it is somewhere between $30-$40 + labor.
So umm.... anyone have an opinion on that? I wasn't taught anything about cars growing up so I'm trying to learn... sorry if it seems like i'm an idiot.
Old 12-06-2012, 10:02 PM   #5
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
^your car is almost 9 years old; how many miles on those struts?
If they're original, then there's not much use throwing good money at them now, just to replace them in a year or two. Consider asking the mechanic to replace them with a new strut + spring assembly (Monroe QuickStrut is $150/ea or less). His labor charge will actually be less to replace the strut with a new one than to repair the old one, and you'll save money in the long run.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 12-06-2012, 11:42 PM   #6
04ZTSJelf
04ZTSJelf's Avatar
Fan#: 100701
Forum Activity 8%
I already have FR Dynamic struts just sitting here... I was just waiting to get shocks and lowering springs to do it all at once, but that could be a while.
Old 12-07-2012, 12:17 AM   #7
Fattie
Fan#: 46016
What I Drive: 6 Duratec Focus
Points 8,431, Level 61
Points: 8,431, Level: 61 Points: 8,431, Level: 61 Points: 8,431, Level: 61
Level Up 94% Completed
FF Reputation: 5 Fattie Good Standing Member
Buy-Sell-Trade Rating: (6)
im thinking it would be the strut mounts/bearings.
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 12-07-2012, 01:53 PM   #8
mrdeath2000
Fan#: 91996
What I Drive: 2014 White SE 5spd
Points 1,331, Level 20
Points: 1,331, Level: 20 Points: 1,331, Level: 20 Points: 1,331, Level: 20
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 3 mrdeath2000 Good Standing Member
Try and tighten the top strut mount nut. It's possible the bushing is so compressed it's allowing a little play or it's backed off an RCH over time.
You'll need to put a wrench on the big nut and then a little on top to keep it from spinning the top, see if you can tighten it a half or a full turn.
2014 Focus SE Manual -
2006 Focus ZX4 SE Auto -commuter 110k /traded
mrdeath2000 is offline
