Engine bay pic - Page 2 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus First Generation > DURATEC Performance (2003-2007)
Old 11-19-2012, 09:30 PM   #11
AMMO-Duke
AMMO-Duke's Avatar
Fan#: 84715
What I Drive: 2005 Grey ZX4
FF Reputation: 8 AMMO-Duke Good Standing Member
Looks great Daryl. Whats the point for the sheild over the stock I/M? Looks perhaps? Did you pull off the egr valve? Or just have it shut off w/ your tune? If pulled off= What'd you do w/ the coolant connections? As I can't see that in the pic's.
Thanks, I wrapped the IM with insulation and put the shield over it to try and reduce the heat from the radiator. Not sure how much of a diff it made, but it made me feel better! LOL.
I completely removed the EGR valve and made a block off plate for the coolant and exhaust holes. I will take a pic of it tomorrow and post. Yes you have to turn it off in the tune and also turn off the code it will throw for the egr not being connected.
AMMO-Duke is offline
Old 11-19-2012, 09:36 PM   #12
AMMO-Duke
AMMO-Duke's Avatar
Fan#: 84715
Wow you made that header? I've never seen one like that for a Duratec. Looks like a old shorty header for the zetec, but I'm sure it's way better lol.
Thanks for the compliment, actually, it is anything but short. Here's a pic. The primary tubes are 34 inches long before the collector, and with the collector there is total about 42 inches of header before the flex pipe.
Old 11-19-2012, 11:09 PM   #13
felixthecat
felixthecat's Avatar
Fan#: 80663
FF Reputation: 54 felixthecat Excellent Standing Member
As I said before, Daryl looks great, awesome job. Seems like you had fun doing that. Long runners w/ give your 20 more grunt.
Introduce Mr. Torsen to the mix D23 crew- D-Tech- Sedan Revolution= #131
felixthecat is online now
Old 11-19-2012, 11:27 PM   #14
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
FF Reputation: 47 sleepyboy Great Standing Member
Buy-Sell-Trade Rating: (11)
Wow that looks fantastic! What are the primary tube diameters? Either way it should make great power and torque! I applaud you sir on every level for making that
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 11-20-2012, 12:51 AM   #15
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
Props to u, that header looks great have u dyno ur car?
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
Old 11-20-2012, 07:16 AM   #16
AMMO-Duke
AMMO-Duke's Avatar
Fan#: 84715
Thank you, the tubes are 1-5/8 O.D. and the collector is 2.5 O.D. with FS Stealth 2.5 exhaust.
I did put it on a dyno when I first put the header on. It made 140whp on an otherwise stock 2.0. I have done a lot more tweaking since then, but I dont plan on dyno again.
Old 11-20-2012, 05:09 PM   #17
AMMO-Duke
AMMO-Duke's Avatar
Fan#: 84715
Here is a pic of the EGR blockoff plate from an earlier question. It is fairly simple to make one as long as you use a piece of metal that is flat and smooth, and is thick enough to not warp. This one has been on there for more than a year with no issues. The original EGR bolts are too long, so I spaced them out with washers temporarily. My temporary became permanent as I forgot all about it. lol.
Old 11-20-2012, 08:18 PM   #18
felixthecat
Fan#: 80663
[QUOTE=AMMO-Duke;4464099]Here is a pic of the EGR blockoff plate from an earlier question. It is fairly simple to make one as long as you use a piece of metal that is flat and smooth, and is thick enough to not warp. This one has been on there for more than a year with no issues. The original EGR bolts are too long, so I spaced them out with washers temporarily. My temporary became permanent as I forgot all about it. lol.
So Daryl, What'd you do w/ the coolant line going to the egr? And I have a tune w/ the egr turned off, So if I disconnect the plug is there going to be a code? I've noticed the inside of the intake manifold is a lot lot cleaner w/ the egr turned off & no more cleaning the TB w/ tb cleaner it free up the tb stickyness. I pulled the TB off to look down the I/M last month & super clean & no sticky TB either.
Old 11-21-2012, 07:51 AM   #19
AMMO-Duke
AMMO-Duke's Avatar
Fan#: 84715
Oh yeah, I forgot to mention that I just plugged the coolant line. No issues.
As for the code, I believe there was a code when I unplugged the EGR. Even though the EGR was disabled, the ECU is still aware of its existence. The best thing to do is go ahead and unplug it, write down the code that you get and it should be easy for your tuner to turn it off for you.
I agree, I love having a clean IM. No more oil/hot crankcase fumes from PCV, no more exhaust from EGR=cooler air=runs better. I used to have the same TB stickiness, but no more!
Old 11-21-2012, 04:48 PM   #20
AllCarFan
Fan#: 102583
What I Drive: 2005 Saleen Sonic Blue S121
FF Reputation: 1 AllCarFan Good Standing Member
you should sell that header. If ever consider it, let me know, my company might be interested in distribution and financing.
AllCarFan is offline
