Interior Lighting Question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-18-2012, 03:47 PM   #1
dutd33
Fan#: 104381
What I Drive: 2012 White Platinum SEL Hatch
Points 1,977, Level 26
Points: 1,977, Level: 26 Points: 1,977, Level: 26 Points: 1,977, Level: 26
Level Up 77% Completed
FF Reputation: 1 dutd33 Good Standing Member
So I did a quick search here and I couldn't find anything, so I was wondering if anyone knows:
When I unlock the car, I believe the interior lights used to turn on by themselves. If I open the door it would turn on as well. It doesn't know. When I open the door it will turn on by only AFTER I've started the car.
Does anyone know how to change this? I've looked in the manual but this is all it says:
INTERIOR LAMPS
Dome/map lamp
The dome lamp will turn on when:
any door is opened.
the remote entry controls are
pressed and the ignition is off.
To manually turn on the dome lamp and/or map lamp(s):
press to activate the dome lamp.
press to activate the map lamp(s). Some map lamps have a split
switch.
Rear dome lamp
dutd33 is offline
Old 11-18-2012, 04:57 PM   #2
DoubleSh0t
DoubleSh0t's Avatar
Fan#: 24900
What I Drive: 2013 Tuxedo Black SE Hatch
Points 56, Level 1
Points: 56, Level: 1 Points: 56, Level: 1 Points: 56, Level: 1
Level Up 12% Completed
Forum Activity 2%
FF Reputation: 1 DoubleSh0t Good Standing Member
You may have switched it off. There's a button by the lamp that says 'Off' and will illuminate orange when the lamp is disabled. Press that button and the overhead lights should turn on when you open the door.
DoubleSh0t is offline
Old 11-18-2012, 04:58 PM   #3
Bogey
Bogey's Avatar
Fan#: 104241
What I Drive: 2012, Ingot Silver SE
Points 1,672, Level 23
Points: 1,672, Level: 23 Points: 1,672, Level: 23 Points: 1,672, Level: 23
Level Up 72% Completed
FF Reputation: 1 Bogey Good Standing Member
INTERIOR LAMPS
Dome/map lamp
any door is opened.
switch.
Rear dome lamp
Turn your door dome light switch on your headliner on then off, same thing happen sometimes to me if my gf turns on the lights, and press' the wrong button.
Bogey is offline
Old 11-19-2012, 06:34 PM   #4
Doctor Drew
Doctor Drew's Avatar
Fan#: 82372
What I Drive: 2012 SEL 5dr PowerShudder
Points 57, Level 1
Points: 57, Level: 1 Points: 57, Level: 1 Points: 57, Level: 1
Level Up 14% Completed
FF Reputation: 1 Doctor Drew Good Standing Member
My dome light only comes on about a third of the time when I get into my car.
I have no idea why it does this, but so far it's not a terribly huge issue since the ambient lighting provides enough illumination for me anyways.
Doctor Drew is offline
Old 11-19-2012, 07:13 PM   #5
JonathanGennick
JonathanGennick's Avatar
Fan#: 105685
What I Drive: 2013 Race Red Focus SE
FF Reputation: 1 JonathanGennick Good Standing Member
Same here. Happened just a few minutes ago. Door open. Light off. Have no idea why.
Sent from my iPhone using FF Mobile. Typos and terseness are to be expected.
JonathanGennick is offline
Old 11-19-2012, 09:22 PM   #6
Desmo748
Desmo748's Avatar
Fan#: 105715
What I Drive: 2012, Tux Black Focus SE Sport
FF Reputation: 1 Desmo748 Good Standing Member
thank god i thought i was going crazy i went through every combination of the dome light button and it still happens to my focus and the wife's. Still haven't figured it out but i am reluctant to head to my dealership after the name i have with them about the '11 250 i bought and the headache i had with that. (why i now have the 2 Foci)
Desmo748 is offline
Old 11-19-2012, 09:33 PM   #7
cobie56
Fan#: 84403
dunno if this is what's causing ur lights to stay off..... maybe you did it accidently....but when the interior light is on you can press and hold the forward facing button ... the light will blink then go out and it will STAY out until u press the button again..
I use this in the summer so at night when i open the door the bugs don't fly in
cobie56 is offline
Old 11-19-2012, 09:53 PM   #8
riparke
Fan#: 95781
What I Drive: 2012,red,se,hatch,manual,sport pkg
Points 419, Level 8
Points: 419, Level: 8 Points: 419, Level: 8 Points: 419, Level: 8
Level Up 38% Completed
FF Reputation: 1 riparke Good Standing Member
I have the opposite, dome light stays on sometimes after starting engine and driving, takes a while to shut off (almost a whole block). Yesterday they went off then came on when I pulled out of my driveway, when the locks locked. There is no rhyme or reason to this. Can't we go back to door switches tripping a relay to turn them on with a built in time delay for turn off. I think I have a bad switch/sensor and the vibration of the locks activate the switch/sensor. Light times out when it stays on.
riparke is offline
Old 11-19-2012, 10:51 PM   #9
Burns098356GX
Burns098356GX's Avatar
Fan#: 94777
What I Drive: 2013 Focus ST
Points 1,136, Level 18
Points: 1,136, Level: 18 Points: 1,136, Level: 18 Points: 1,136, Level: 18
Level Up 36% Completed
FF Reputation: 1 Burns098356GX Good Standing Member
The buttons on the ceiling above the driver side door controls this. Press the button that says OFF. If its illuminated, the lights will not turn on when the doors open.
Sent from my HTC-Z710a using FF Mobile
Burns098356GX is offline
Old 11-19-2012, 11:22 PM   #10
JonathanGennick
Fan#: 105685
No. There is more going on than that button. My button was not lit. I opened the doors. Nothing. Went to eat. Came back. Opened the doors. Got light. Why? Beats me. Some other factor is at play that I have not yet put my finger on.
