Found A Perfect Fix For 5 Door Tail Lights! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-18-2012, 01:15 AM   #1
MC1992
MC1992's Avatar
Fan#: 90417
What I Drive: '95 Volvo 850 Turbo/'12 Focus Sport
Points 723, Level 14
Points: 723, Level: 14 Points: 723, Level: 14 Points: 723, Level: 14
Level Up 23% Completed
FF Reputation: 1 MC1992 Good Standing Member
Found a good fix for my tail lights! First take out the tail lamp. There are two plastic nuts holding it, one is behind where the small panel is, the other is at the top which I got access through the hole near the trunk light is. Then stand at the corner of the car and gently pull it straight out, since the little prong that clips onto the car near the teardrop of the tail light is at an angle. Might want to place your hands at the bottom of the teardrop while doing so as it needs a good firm pull. Then I cut out one of those foam things that wrap around pipes for your house and fold it in half. Place it near the teardrop part of the tail light about 1.5 inches away from the very tip end and place it there. Might want to tape or glue in place, but I have small hands so I manage to fit it in there without doing so. Then reverse order of dissemble and the edges of the tail light (the teardrop part especially) should no longer be touching right up against the body. For me it actually evenly spaced the whole thing around the edges (bumper, body, and tailgate) and no longer have the squeaks from rubbing. I think itís better than putting a washer where the prong is, since Iíve tried and it doesnít clip it back in all the way and or better than backing the prong out of the housing. The foam is enough where itís pushing it out the length of the teardrop just enough where itís no longer rubbing, yet wouldnít bending the tail light, and the prong is firmly pop back in place and clipped on. I also filed the edges a bit with a nail filer so now itís smooth and no longer rough.
"2012 Focus Sport Hatchback is the bee's knees!"
MC1992 is offline
Old 11-19-2012, 09:05 AM   #2
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
I ended up putting neoprene washers on the locating post and the forward-most threaded stud.
You can find them in the hardware section at Home Depot. 1/4 x 1 1/4" neoprene washer.
Looks like this:
Joined the dark side.
Zillon is offline
