Different engines? - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > DURATEC Ti-VCT Performance (2012-Current)
Old 11-17-2012, 09:28 PM   #1
Further North
Fan#: 105616
What I Drive: 2012 SEL Black
FF Reputation: 1 Further North Good Standing Member
Different engines?
I have a 2012 SEL hatchback that is not a flex-fuel car...
It makes me wonder what the difference is between my car and the ones that are set up for flex fuel.
...not t hat I'd use E85, but I want to understand the differences.
Further North is offline
Old 11-18-2012, 05:05 AM   #2
dstiefel
dstiefel's Avatar
Fan#: 102439
What I Drive: 2012 focus ti. hatch
FF Reputation: 1 dstiefel Good Standing Member
I was told better mileage
dstiefel is offline
Old 11-18-2012, 05:10 AM   #3
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
What I Drive: LesVagon
FF Reputation: 16 TiStick Great Standing Member
Main difference is fuel pump and fuel line materials. ECU also has ability to sense what fuel you are using. I suppose it has different fuel/timing maps for E85, but I have no proof.
Sonic's Mk3 Crew #11
Hatch Nation#163
Originally Posted by suss6052 View Post
Watch out for the D
TiStick is offline
Old 11-18-2012, 10:24 AM   #4
Further North
Fan#: 105616
For the Flex-Fuel car or the one that can't run E85?
Old 11-18-2012, 10:26 AM   #5
Further North
Fan#: 105616
Thanks, I was guessing it might be things like that (E85 can do a ton of damage) but was not sure.
Old 11-20-2012, 11:30 AM   #6
Tommyatomic
Fan#: 105916
What I Drive: MK3 FocusHatch 5SPD, '93 RHD WRX
FF Reputation: 1 Tommyatomic Good Standing Member
E85 will destroy rubber seals and rubber lines if they are of the wrong type.
A flex fuel vehicle would have a fuel pump that has seals that will not degrade as a result of ethanol as well as injector seals and fuel lines safe for use with ethanol.
It should also have tuning that makes AFR and timing accommodations for the different fuel and hopefully different programming for the fuel efficiency calculator. E85 burns cleaner but not as hot. It contains less energy but is significantly more stable so much more timing can be run. Your MPG on e85 is much lower.
The PCM program should take all of that into account.
Tommyatomic is offline
Old 11-27-2012, 11:00 PM   #7
jburkey28
Fan#: 105295
What I Drive: 2009 Cobalt SS/TC
FF Reputation: 1 jburkey28 Good Standing Member
E85 does produce more power if tuned for it. That's something to keep in mind also.
jburkey28 is offline
