Life Expectancy (Miles) of the Ford Focus? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-18-2012, 06:59 AM   #11
fresh1dougie
fresh1dougie's Avatar
Fan#: 21165
What I Drive: 2005 Sangria Red ZX3 SES Auto 2.0
FF Reputation: 1 fresh1dougie Good Standing Member
122,000 '05 ZX3 Amsoil from the start. All original parts with the exception of front brakes. Battery still servicable. Living in Detroit area very hard on suspension-great car very good experience so far!
fresh1dougie is offline
Old 11-19-2012, 03:00 AM   #12
amc49
Fan#: 96610
Points 3,274, Level 35
Points: 3,274, Level: 35 Points: 3,274, Level: 35 Points: 3,274, Level: 35
Level Up 50% Completed
Forum Activity 11%
160K on two ATX zetecs, Walmart straight 30 weight and 7500 mile changes. Both run well and use no oil. Can't kill 'em.
I remember the days when a 2 liter was dead at 100K, motor couldn't hardly move car, think Pinto. For all the added complexity these are definitely better built cars. Even the bodies seem to hold up longer.
amc49 is offline
Old 11-22-2012, 07:15 AM   #13
Lscman
Fan#: 95211
What I Drive: 2007 ZX3
Points 1,218, Level 19
Points: 1,218, Level: 19 Points: 1,218, Level: 19 Points: 1,218, Level: 19
Level Up 18% Completed
FF Reputation: 9 Lscman Good Standing Member
Originally Posted by Stlouis1 View Post
My daughter in Maine has a 2005 Focus with 240,000 miles on it. Eats tires though. But no major mechanical work.
Cars with high miles eat tires when rubber suspension control arm pivot bushings tear and/or wear out from age and ozone rot. This causes the control arms to flop around and wheel alignment is totally lost. This makes for noise, poor handling and tires wear out fast.
You can replace the whole control arm with bushing already installed for about $125 each, or you can get real thrifty on some cars and replace the $20 bushings themselves using a hydraulic press. This is a problem on everything from a base Honda to a $150K mercedes. Bushings need replaced about every 100K mi on average. The front suspension bushings in my BMW need replaced about every 60K mi and the rear goes bad every 100K or so. Throwing new tires on the car every 20K mi to get chewed up is just plain nuts. This costs FAR more than a proper repair. Cars with bad bushings handle verey bad plus they shake and make a lot of noise when hitting bumps.
Replace the control arms on your daughters car instead of buying $400 worth of tires every 6 mo.
Lscman is offline
Old 11-24-2012, 02:16 PM   #14
PLRX
PLRX's Avatar
Fan#: 16768
What I Drive: 2003 - ZX5 - 5 Spd - 2.3 Duratec
Points 1,402, Level 21
Points: 1,402, Level: 21 Points: 1,402, Level: 21 Points: 1,402, Level: 21
Level Up 2% Completed
FF Reputation: 1 PLRX Good Standing Member
Mine got 224,00 miles and I'm finishing my second clutch. These have been hardcore miles. I've never babied this car.
2003 ZX5 HID Lights, Interior Carbon Fiber, Poly Bushings, SVT Suspension, Upper Strut Bar, Euro SVT Wheels,
SVT Brakes, Steel Braided Brake Lines, Drilled Rotors, K&N FIPK Generation 2 and Magnaflow Cat-Back
PLRX is offline
Old 11-26-2012, 01:44 PM   #15
kwolo302
kwolo302's Avatar
Fan#: 103880
What I Drive: 2002 black ZX3
FF Reputation: 1 kwolo302 Good Standing Member
2002 zx3 with 204,000. bought it from my father at 112,000 with no major repairs done by him. the clutch was replaced 30,000 miles ago. both cv axles replaced 1,000 miles ago. all wheel bearings replaced within the last 3 months. Shift cable end replaced 1 week ago along with another slave cylinder. I'd say those were the major repairs. Minor ones being, thermostat and thermostat housing, a couple different coolant hoses, O2 sensor lower, haven't done the upper yet but it needs to be done and as of right now I need to more than likely replace the alternator and/or battery. Kept up on regular maintenance and the engine runs great. If you can do your own work do it and repairing the car will make keeping it worth it.
!ĦIdiots doing idiot things because they're idiotsĦ!
kwolo302 is offline
Old 11-27-2012, 07:56 PM   #16
Edgenet
Edgenet's Avatar
Fan#: 106043
What I Drive: 2002 Wagon with Zetec, Auto
FF Reputation: 1 Edgenet Good Standing Member
This is like asking how long do people live???
I find if you follow basic maintenance any car will give you trouble free service for at least 10 years. If you decide to spend some cash on suspension components you could stretch that to 15 years.
No Matter How Much You Like Doing Something If You are Getting Paid "It's a Job"
Edgenet is offline
Old 11-28-2012, 10:30 AM   #17
jburkey28
Fan#: 105295
What I Drive: 2009 Cobalt SS/TC
FF Reputation: 1 jburkey28 Good Standing Member
As long as you keep up on your maintenance, you should reach 200k.
Definitely do the timing belt between 125-150 though.
jburkey28 is offline
Old 11-28-2012, 10:38 AM   #18
doubles
doubles's Avatar
Fan#: 106022
What I Drive: 2008 ford focus
FF Reputation: 1 doubles Good Standing Member
as with any car or truck do maint as recomended and fix the things that need fixing and the car can last you a lifetime. i to this day still have a 95 chevy dually sitting out back i dont use it mush other than pulling my camper it has the 454 engine with just minor repairs tune up and oil changes i have never done any real big maint on it as i have no trouble with it. it has over 400k on it and still runs and drives great and would not hesitate to jump in it and drive around the US with it. other than gas prices as of now lol
doubles is offline
Old 11-28-2012, 10:40 AM   #19
jburkey28
Fan#: 105295
Agreed. I've got a 98 Chevy C1500 with with the 350 in it, still runs strong. I think it just pushed over 225k of HARD miles.
My buddy uses it as his DD while his truck is in the shop, and I drive it in the winter.. Gotta keep my SS out of the snow :)
