Clutch slipping some; master cylinder / relief valve? - Focus Fanatics
Old 11-17-2012, 10:22 AM   #1
LugNut
LugNut's Avatar
Fan#: 92146
What I Drive: 2001 White Sedan
FF Reputation: 1 LugNut Good Standing Member
Question Clutch slipping some; master cylinder / relief valve?
The 2001 SE Sedan, with the SPI that I rebuilt and put in a new clutch about a year ago, now has a slipping clutch. The driver (not me) is very experienced with manual transmissions, so I thinking it's not from driver error.
I just had the car for a bit this morning. There's no leakage of oil from the vent at the bottom of the bellhousing, so a bad engine rear seal is not likely.
From the FSM, the hydraulic clutch is not adjustable. Clutch pedal operates correctly. Hydraulic fluid in the shared reservoir (brakes and clutch; not a better idea!) is clean and full.
From a test drive, it is slipping some in all gears, but does slowly engage. If not a bad clutch set ($700+ by a shop), my other guess is a bad/clogged hydraulic pressure relief that is slowing the release of the throw-out bearing. I'm also assuming the relief valve is part of the master cylinder.
Sound possible? Or better yet, solved the same yourself?
A new master cylinder is only $35, but a pain to install. I see this good thread on how to do it:
http://www.focusfanatics.com/forum/showthread.php?t=243148
Thanks!
LugNut
Fixed Up a white 2001 P-code SE Sedan
including rebuilding the SPI (see my threads)
LugNut is offline
Old 11-17-2012, 11:28 AM   #2
sailor
"Elder"
sailor's Avatar
Fan#: 57268
FF Reputation: 60 sailor Excellent Standing Member
From VERY recent experience (grin), I learned that the clutch return spring can be missing for a LONG time (broken off & disappeared) WITHOUT much in the way of symptoms.
Occasional slow engagement (slipping) and occasional need to lift the clutch pedal to engage the cruise control.
Installing a spring when the leaking master was replaced solved the issues....
Worth a check B4 diving deeper...
sailor is offline
Old 11-17-2012, 12:27 PM   #3
LugNut
LugNut's Avatar
Fan#: 92146
Hmmmm ... I did look up under the dash to look for sloppiness in the pedal, etc., but don't remember looking at/for the spring. Will definitely notice the next time, but that will likely be next weekend or so if I replace the master cylinder.
Thanks.
Any others' experiences/"external" repairs for this problem?
LugNut
LugNut is offline
Old 11-17-2012, 03:24 PM   #4
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Memberjetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Worn clutch. The pressure plate fingers provide more than enough "push" to return the pedal effectively. There isn't any relief valve either. Its just a straight shot out of the master to the slave and back again.
jetrinka is offline
Old 11-17-2012, 03:55 PM   #5
sailor
"Elder"
sailor's Avatar
Fan#: 57268
Agreed, worn matches the symptoms. We don't know mileage or condition/replacement of flywheel yet when the clutch was "replaced".
New Clutch on an old, worn flywheel seldom lasts long....
sailor is offline
Old 11-19-2012, 03:09 AM   #6
amc49
Fan#: 96610
FF Reputation: 23 amc49 Great Standing Member
Uh, technically there IS a relief valve, the compensation port at master, if clogged or corroded it could easily hold the clutch fingers down. I don't screw with hydraulic clutches much but the cylinders are same basic design as brake and I've seen plenty of brake cylinders with that port clogged pretty solid to lock brakes up and car won't budge.
Worn disc most likely.
amc49 is offline
Old 11-19-2012, 06:16 AM   #7
LugNut
LugNut's Avatar
Fan#: 92146
Thanks -- I will likely try replacing the master cylinder first ($35 locally).
I found my old pics of the flywheel. It looked quite good after a light refinishing, and from experience my clutches have done well with such. So if not the master cylinder or defective materials, it's looking like driver error. That's bad news because they are needy, and are to keep this gift car longterm.
The clutch set was a LuK. Anyone had bad luck with Luk?
LugNut
LugNut is offline
Old 11-19-2012, 07:11 AM   #8
sailor
"Elder"
sailor's Avatar
Fan#: 57268
The identical to stock master cyl. I just installed was an LuK (German), so that could match stock. Good Rep. AFAIK
Hope you get Lucky, and can keep it going for them cheaply.
sailor is offline
Old 11-25-2012, 01:49 PM   #9
LugNut
LugNut's Avatar
Fan#: 92146
Luck not on my side -- for this, nor the $250MM Powerball drawing.
Did the work yesterday morning. 11 month-old fluid came out rusty color, but not lumpy. New clutch master cylinder was identical to the original (LuK brand). No difference in the clutch operation, darn it.
LugNut
LugNut is offline
