Performance Shocks - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-17-2012, 11:20 AM   #1
Thermal
Fan#: 73810
What I Drive: 2008 Pitch Black S
FF Reputation: 1 Thermal Good Standing Member
Performance Shocks
Been away for a while and had to find my way around the new site. I seriously need new shocks! I have Eiback springs and a Steeda stabilizer setup on a 2008 S coupe and I'm looking for non-adjustable improved street performance units. I've been to several dealer sites, but the folks on this forum have always been my best source of information since I began modding my car. What can you suggest and, as always, thanks for the information.
Thermal is offline
Old 11-17-2012, 12:29 PM   #2
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
FF Reputation: 9 Kipp Good Standing Member
unfortunately there isn't really anything out there for the 08-11. most have swapped to a previous design and used that.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 11-18-2012, 09:48 AM   #3
Thermal
Fan#: 73810
Performance Shocks
Thanks Kipp. Can you explain what you mean by a previous design? I didn't think I'd have this degree of trouble. Are performance shocks worth it, or should I just go with something like Monroe's?
Thermal is offline
Old 11-18-2012, 10:02 AM   #4
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,060, Level 72
Points: 12,060, Level: 72 Points: 12,060, Level: 72 Points: 12,060, Level: 72
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
Forum Activity 99%
FF Reputation: 65 felixthecat Excellent Standing Member
Which Eibach springs do you have? You'll need dampers that'll go w/ those springs. lowering/ shorter springs call for struts & shocks that can deal w/ the shorter & stiffer springs. Koni yellows work great for shorter/stiffer springs, but they are adjustable.
felixthecat is offline
Old 11-18-2012, 10:09 AM   #5
Kipp
Kipp's Avatar
Fan#: 31300
the sets are 00-04, 05-07, 08-11. each one has a slightly different design. on the 00-04 the bottom of the front struts are a smaller diameter than the newer ones, 05-07 and 08-11 are same. they all have different top hats and different spring design.
they can be swapped between years, but require different parts to do so. the issues you have now is if you want to keep the springs you have you are limited to dampers that will work with those springs.
on the rear all 00-11 are the same exc the wagon. same springs and dampers.
Midwest Crew #22
Kipp is offline
Old 11-18-2012, 02:10 PM   #6
Thermal
Fan#: 73810
I have the Eibach Pro-Kit Lowering Springs with the Eibach Anti-Roll Sway Bars. I'm willing to go with adjustable units at this point if necessary as I never considered the effects of lowering springs. I'm not racing this car so I wonder if it's worth it, or just stay with a good set of stock units and if so, which brand.
Thermal is offline
Old 11-18-2012, 04:20 PM   #7
sailor
Crankshaft
sailor's Avatar
Fan#: 57268
Points 11,838, Level 71
Points: 11,838, Level: 71 Points: 11,838, Level: 71 Points: 11,838, Level: 71
Level Up 47% Completed
Forum Activity 99%
Thermal - You'll probably get the best responses over in the "Wheels, Tires, Brakes & Suspension" Forum, so I'll move this over there for you.
Due to the small number of manufacturers that have made struts to fit the newer cars, the "Omni Kit" to adapt struts that are made to fit the earlier years is a popular solution.
It adds quite a bit to the price of replacing struts on the later cars, but it's a one time purchase & opens up the choices tremendously.
(basically a quality set of sleeves to take up the difference in diameter)
Stock shocks would be marginal at best with lower & stiffer springs, you'll be amazed at the improvement with ANY of the avail. units that match to those springs.
Luck!
sailor is offline
Old 11-18-2012, 08:18 PM   #8
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
Some clarification.....the front strut design changed in 06. The base of the strut got fatter and the spring seat design changed for those models. As mentioned, 00-05 struts can be used on 06+ (second gens cars) with an Omni Kit by Massive. The kit is essentially a shim that fits around the base of the smaller (earlier) front strut allowing it to fit in the 06+ knuckle. You'd have to use 00-05 springs as well as the 06+ springs will not fit the earlier struts.
Geezer is offline
