Datalogging AEM Digital Boost Gauge - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-17-2012, 06:20 AM   #1
mj22
Fan#: 32067
What I Drive: 2003 silver 2.0. zetec
FF Reputation: 1 mj22 Good Standing Member
Hi Guys,
I was just wondering if anyone has had any success datalogging the analog output from an AEM Digital Boost Gauge (30-4406).
I have wired up my Xcal 3 to datalog the analog output, 0-5 volts that the gauge supplies and attempted to apply this equation to the raw voltage signal:
*Equation*: PSIA=12.5*(volts)-6.25* scale: .5v-4.5v = 0-50psia
which should then provide the boost.
I'm running a JRSC which sees 10 psi at redline. The boost level is indicated on the gauge however applying the formula to the analog output I don't get an accurate boost figure to datalog.
Can anyone advice an amendment to make to the above formula or possible reason the analog output may not be providing an accurate signal for datalog?
Thanks for the help.
Mike
mj22 is offline
Old 11-17-2012, 08:59 AM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,537, Level 100
Points: 52,537, Level: 100 Points: 52,537, Level: 100 Points: 52,537, Level: 100
Level Up 0% Completed
Forum Activity 55%
Buy-Sell-Trade Rating: (28)
If you go to commands in your live link , then do the drop down to the right and choose your AEM in the list then click apply you should have th correct equation
This has been correct for me about 99% of the time , Have you tried that ?
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 11-18-2012, 08:24 PM   #3
mj22
Fan#: 32067
Hi Tom,
Yes I have tried that.
The figures I am getting back don't match what is indicated on the boost gauge.
I will post up some figures from the datalog later, however if I start the datalog with accessories on but prior to turning the engine on, the datalog for the AEM boost gauge (with the equation applied to the RAW 0-5 v) returns a value of around 13. Obviously with the car off this value should be 0.
I will re-check the wiring tonight however I don't see this being the problem. I will also complete a datalog of all analog inputs 1 to 4 to see if it is somehow being picked up on one of the other analog inputs. I don't think this will resolve my problem either as the analog input 2 is reading between 0.5 and 4.5 volts as AEM advise the analog output fror their boost gauge should.
I've had no issues datalogging the AEM wideband by applying the formula through livelink.
Thanks,
Mike
mj22 is offline
Old 11-19-2012, 07:48 PM   #4
mj22
Fan#: 32067
Hey All,
Is anyone aware if the analog signal provided by the AEM Digital Boost Gauge provides an absolute pressure. ie. atmospheric pressure plus the pressure created by the supercharger/turbo etc?
If this is correct I am at or around sea level so I have an approximate atmospheric pressure of 14.7 psi.
If this is the case I would need to modify the formula applied to the raw 0-5 volts from the AEM boost gauge to be "[(12.5*v)-6.25]-14.7". Anyhow applying this formula the boost levels I am datalogging appear significantly more accurate.
Can anyone confirm if this correction for atmospheric pressure is required?
Thanks,
Mike
mj22 is offline
Old 12-29-2012, 09:47 AM   #5
NJSVTGUY
NJSVTGUY's Avatar
Fan#: 46519
What I Drive: 86 GN, 11.1@128, 20 psi
Points 4,550, Level 42
Points: 4,550, Level: 42 Points: 4,550, Level: 42 Points: 4,550, Level: 42
Level Up 50% Completed
Forum Activity 3%
FF Reputation: 8 NJSVTGUY Good Standing Member
Buy-Sell-Trade Rating: (10)
I would think it would. Why don't you use a 2 or 3 bar MAP? Like you mention the first bar is for atmospheric. If running under 14.7 you would just need a 2 bar, over a 3 bar.
NJSVTGUY is offline
