Caught just in time.. shewww - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-16-2012, 03:55 PM   #1
dpmeeks
Fan#: 82112
What I Drive: 2000 Focus SE Zetec
FF Reputation: 3 dpmeeks Good Standing Member
I just bought ( got it for 950 bucks !! ) this one owner, 128k miles, SE auto trans, a few days ago. It has the 2.0 Zetec. I asked the previous owner if the T-belt has ever been changed and she wasnt sure. It had a bad pass. side motor mount so in the process of changing it i decided to look at the t-belt.. thank god ! i did... Everything else on the car works great, cruise, electrical, even has side air bags and a block heater :)
Im having it "towed" ( scared to start it again ) to a friends shop to change the T-belt, Waterpump, and everything else while hes in there. Im gonna give it a needed tune up.. I ordered NGK plugs thru Rock Auto, i happened to read its not good to use NGK because they dont seat properly in the head ?? I purchased the NGK G-power plugs if that matters..
Ive read different opinions... Is the Zetec a interference engine ??? My friend is working on a ZX2, timing belt broke, and he said you could spin the crank pulley easily by hand ( no compression ) after installing new belt.
dpmeeks is offline
Old 11-16-2012, 04:06 PM   #2
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,551, Level 48
Points: 5,551, Level: 48 Points: 5,551, Level: 48 Points: 5,551, Level: 48
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
Forum Activity 8%
FF Reputation: 35 thenorm Great Standing Member
the regular zetec is non interference. the SVT zetec IS interference.
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 11-16-2012, 04:17 PM   #3
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,743, Level 76
Points: 13,743, Level: 76 Points: 13,743, Level: 76 Points: 13,743, Level: 76
Level Up 24% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (18)
I believe that the NKG plugs are a bit too long and stick a little too far into the cly, or not far enough, I cant remember which someone did a compareson years ago with pictures. Motorcraft plugs are gonna be the best plugs for a DD in the Zetec.
The Timing belt is a fairly easy job. replace everything you can while its torn apart. And since you gotta remove it anyways i would replace the passenger side motor mount as well as they go bad much faster than the other 2.
Good Luck and to ff.com!
SkyPilot is online now
Old 11-16-2012, 05:28 PM   #4
dpmeeks
Fan#: 82112
thanks for the replies.. I forgot to ask, i also read gap the plugs at 1.0mm instead of 1.3mm as ford says ?
Yeah im having the guy at the shop replace everything so i dont have to worry about it for awhile.. :)
dpmeeks is offline
Old 11-16-2012, 06:42 PM   #5
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,684, Level 86
Points: 18,684, Level: 86 Points: 18,684, Level: 86 Points: 18,684, Level: 86
Level Up 67% Completed
Forum Activity 18%
Buy-Sell-Trade Rating: (4)
Depends which NGK's. There are one's that physically fit. But the heat range isn't optimal IMO.
... and I'll have the pictures and such fix'd once all the pictures are reuploaded.
^This.
OH, you're not playing dumb ...
iminhell is online now
Old 11-16-2012, 06:48 PM   #6
UnbridledCarnage
Rhinoliner!!!
UnbridledCarnage's Avatar
Fan#: 66551
What I Drive: 03 Rhinoliner'd ZX3 AdvanceTrac
Points 16,266, Level 81
Points: 16,266, Level: 81 Points: 16,266, Level: 81 Points: 16,266, Level: 81
Level Up 84% Completed
FF Reputation: 9 UnbridledCarnage Good Standing Member
nice pickup for under a grand! Check out FocusXtreme while your here. heres a link
http://www.focusfanatics.com/forum/f...splay.php?f=73
If your local to the 502, 270, 812, 606, 859 area, check out FocusXtreme, the Ohio Valley chapter of FF. Monthly meets and kickass people! Join and POST UP!!!
UnbridledCarnage is offline
Old 11-17-2012, 02:12 PM   #7
dpmeeks
Fan#: 82112
I introduced myself on FocusXtreme... good to know theres some peeps nearby :)
dpmeeks is offline
