Problems with ESP - Traction Control - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-16-2012, 02:59 PM   #1
phill8686
Fan#: 106331
What I Drive: 2010 Ink Blue. Estate. Diesel
FF Reputation: 1 phill8686 Good Standing Member
Hi.
When driving in a straight line car is perfect. When I corner sometimes not always I get a odd noise from the front left wheel. after the noise I hear ttsssss as though pistons or something are resetting to their correct place.
However on some large roundabouts the left front wheel makes a loud ttsssss noise and the ESP light comes on for a few seconds then it goes out.
If I turn off ESP the car is perfect in all conditions.
more info.
I have just had 2 new tyres, I asked them to put the new on the rear and the rear on the front for tyre rotation. I also had the tracking done.
I read in a post that the esp sensors could have been knocked during this rotation process.
I do not want to go back to that garage and I cannot really afford to go to a ford dealer so any help would be fantastic.
As the noise is coming from the front left, is that likely where the problem is?
Would knocking the sensor cause this kind of problem?
Do I need to buy new sensor or can they be repaired?
I have removed the front left wheel and checked for dirty conections etc but everything seems to be ok, I have not looked at other wheels.
Is it possible the car doesnt like the rotated wheels although they are same size.
Many thanks for your thoughts and suggestions.
Ford Focus Estate. Tittanimum 1.6 tdci 2010
phill8686 is offline
Old 11-16-2012, 03:27 PM   #2
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 3,959, Level 40
Points: 3,959, Level: 40 Points: 3,959, Level: 40 Points: 3,959, Level: 40
Level Up 5% Completed
Forum Activity 9%
FF Reputation: 14 mac.mogul Great Standing Member
Were you hearing the sound before or after you had the tires rotated to the front?
It seems to me that what you're hearing is the brake booster working for either ABS, TC, or ESC.
If you're turning and going over a bump at the same time, its possible that you are triggering the sensor and what you're hearing are the brakes pumping the front wheel.
In almost all vehicles now with traction systems, they are brake based and people really need to take care of their brakes in order for these systems to function properly. If this noise is new, it may be worth taking to a garage for brake service. If there is air in the brake lines, or if your brake pads are worn too far down, it is possible for the system to be making more noise than necessary.
I'm fairly certain that if something was actually wrong with a sensor, it would trigger a service light and a trouble code.
Best of luck to you.
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is online now
Old 11-16-2012, 04:34 PM   #3
phill8686
Fan#: 106331
Thanks mac.mogul
The noise started when I had the tires rotated.
The road / roundabout that I notice it the most is a newly laid surface without pot holes.
I think the brakes pads are ok because of the visual inspection I did on the front left wheel and the warning light has not come on for the brakes.
Will check the other wheels / brakes pads tomorrow
Thanks again.
Old 11-16-2012, 05:39 PM   #4
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 460, Level 9
Points: 460, Level: 9 Points: 460, Level: 9 Points: 460, Level: 9
Level Up 20% Completed
FF Reputation: 17 nilskje Great Standing Member
Esp sensors at the wheels = ABS sensors, to me it sounds like different tyre sizes, it take very little to upset the ESP system, it measures differerences it wheel speed.
nilskje is offline
Old 11-16-2012, 06:53 PM   #5
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,678, Level 86
Points: 18,678, Level: 86 Points: 18,678, Level: 86 Points: 18,678, Level: 86
Level Up 66% Completed
Forum Activity 18%
Buy-Sell-Trade Rating: (4)
"tsssss" sound to me would indicate the rotor is moving/flexing under cornering loads. Typical sound of a stone stuck in a pad, worn pads, rust buildup, improperly TQ'd lugnuts, worn wheel bearing or any other loose part you may thing of attached to the wheel.
Now the fact that the traction lamp comes on, to me that points more towards a bearing issue. There is a specific 'air gap' between the Wheel Speed Sensor and the Tone Ring. This is a fixed clearance. But if a bearing is worn/loose this clearance can move/grow. I can see where this could cause a lamp to light up.
But seems that if a bearing were bad you'd notice it under other conditions.
So I'm kinda at a loss as to what exactly it can be. But the simple things are making sure everything is tight and TQ'd properly. Jack the car up and wiggle the tire from top to bottom, there should be no play at all. If there is, it points to a bearing.
Also make sure the axle stub is tight, something like 233ft/lbs IIRC.
OH, you're not playing dumb ...
iminhell is online now
Old 11-17-2012, 12:53 PM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,816, Level 73
Points: 12,816, Level: 73 Points: 12,816, Level: 73 Points: 12,816, Level: 73
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 99%
Agreed - This was my first guess as well, thinking that if the bearing was starting to get loose that air gap could be excessive only when cornering...
Good thing to check out in any case...
sailor is online now
Old 11-17-2012, 01:19 PM   #7
nilskje
Fan#: 11478
Points 460, Level 9
This would give an ABS error message as well....
nilskje is offline
Old 11-18-2012, 01:30 PM   #8
phill8686
Fan#: 106331
Thanks for the suggestions.
I have not been able to check for any movement etc as it has been raining here. Nothing new with that, at least the weather is working as it should
Will post back once I have had the chance to look.
Old 11-26-2012, 03:04 PM   #9
phill8686
Fan#: 106331
Hi.
The rain stopped long enough for me to check all 4 tires, could not find anything obviously wrong. it is still only on the front near side. seems to be more when i turn to the right than the left if that would mean anything.
Guess its a trip to the garage, for now im just going to turn off esp.
Thanks again for everyones help.
Old 06-25-2014, 03:34 PM   #10
veganjames
Fan#: 172449
What I Drive: 2010 Focus 2.0 Titanium (petrol)
FF Reputation: 1 veganjames Good Standing Member
Hi,
My Focus has started making a noise like this in these situations, sometimes accompanied by the ESP light flashing. All very similar to this thread.
It has only done 35k miles and is about 8 months out of warranty.
Did you ever find out what was causing this?
Did you get it sorted out?
How much did it cost?
How do you turn the ESP off?
veganjames is offline
