Official 2012+ Focus Used Oil Analysis thread - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-29-2012, 10:51 PM   #21
UnleashedBeast
UnleashedBeast's Avatar
Fan#: 100738
What I Drive: 2012 Focus Titanium
FF Reputation: 3 UnleashedBeast Good Standing Member
Originally Posted by TboneZX3 View Post
Simply real world numbers that don't relate at all. A comparison of particle counts from a FL-910s to a 5-micron Amsoil bypass setup wouldn't really mean anything to our discussion of FL-910s vs EaO34 bypass valves now would it?
I'm not the only person here who uses Amsoil 5W-20 and could change to any EaO oil filter.
I'm simply baffled that you think a $4.00 to $7.00 oil filter could compare to one that is twice to three times the price, with far superior media and materials. All because you think a stiffer bypass is the end all be all of the design, not even considering the flow differences of the media.
To comment on your thread end versus top end valve placement debate. The thread end bypass was originally designed that way as a sludge prevention (sludge getting pulled back into the engine when the bypass was open). Odd, never found sludge in an engine maintained properly with Signature Series. Not even after cutting the oil filter open. None to be found.
2014 Mustang GT custom ordered to replace the GT500: Sterling Gray, NAV, Recaros, Brembos, Glass Roof, back up camera, 6 speed auto, loaded
2012 Focus Titanium - 18" wheels with handling package
2009 GT500 Shelby (700 rwhp) - sold
UnleashedBeast is offline
Old 11-29-2012, 10:57 PM   #22
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
You're not comprehending my posts, are you? I never made that claim. I was very specific about the conditions where the Amsoil filter might not be the best choice.
Never mind...
Hatch Nation #90
TboneZX3 is offline
Old 11-29-2012, 11:02 PM   #23
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
I didn't say anything about sludge. I've never found sludge in any engine I've maintained. You will have more contaminants settle in the dome end of a filter that is mounted thread end up.
Hatch Nation #90
TboneZX3 is offline
Old 11-29-2012, 11:06 PM   #24
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Let's compare UOA's...you will lose.
/conversation
OK, so who was I supposed to compare my UOA with again?
Man, you really are a piece of work.
Have a nice day!
Hatch Nation #90
TboneZX3 is offline
Old 04-22-2013, 10:52 PM   #25
UnleashedBeast
Fan#: 100738
10,000 miles on Amsoil ALM 5W-20 and appears that half the lubricants life remains (or more). Wear metals are very low. TBN is just under 5. No make up oil added, the engine doesn't use a drop. Viscosity hasn't budged 1%. This is what a lubricant SHOULD be!
Old 04-23-2013, 07:39 AM   #26
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: '14 Ruby Ti w/ Handling Pkg
Points 7,615, Level 58
Points: 7,615, Level: 58 Points: 7,615, Level: 58 Points: 7,615, Level: 58
Level Up 33% Completed
Forum Activity 3%
FF Reputation: 13 kam327 Great Standing Member
Not a fair representation of the oil since you have a bypass system and 75% more oil capacity than the rest of us.
kam327 is offline
Old 04-23-2013, 07:50 AM   #27
UnleashedBeast
Fan#: 100738
I expected that, and why I have 7 quarts of Pennzoil Ultra 5W-20 on standby for the next test using the same system. A true side by side.
Your math is wrong, I only have 35% more capacity.
Ultra, unfortunately, isn't going to be a dominating competitor to Amsoil Signature Series 5W-20, as it's already at a disadvantage from the start.
1. The awesome (legendary) 5 quart container from Wal Mart selling for ~$27.00 is yesterday's dream. Wal Mart has dropped it from most of their stores, if not all. Ultra is found on their clearance racks now. Doubtful to return, despite the improvement made in the new API SN formulation. I bought all the 5W-20 for my testing purposes on clearance for $4.00 to $5.00 per quart at multiple locations. I bought all that remained (10 quarts total).
2. Pep Boys sells it, but only by quart in most stores. $9.79 per quart is too HIGH! Amsoil Signature is cheaper for preferred customers and will retain TBN longer (longer oil change interval).
It's doubtful I will be able to achieve the same mileage interval with Ultra, as compared to Amsoil Signature Series. Not going to waste my time with anything else commonly found on the shelf. Ultra is the only formulation that could even think about challenging what I already use, despite its downfalls.
Old 04-23-2013, 08:45 AM   #28
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Forum Activity 3%
Your UOA shows a sump capacity of 8 quarts. Standard sump capacity is 4.5 quarts. 8/4.5 = 1.77. That is a 77% increase (I rounded down). That alone would greatly extend the life of any oil wouldn't it?
Your Ultra comparison will indeed be a fair representation of the two oils. I look forward to that.
You go on to say that no other oil is worth testing. To me the issue is not which oils can safely handle a 15k OCI or whatever. That ignores the issue of value. If Amsoil costs 75% more than Pennzoil Platinum or QSUD, can it guarantee a 75% longer OCI?
kam327 is offline
Old 04-23-2013, 05:17 PM   #29
UnleashedBeast
Fan#: 100738
Just a smidgen shy of 7 quarts capacity.
I do as well, but will take another 1.5 to 2 years to see the results.
Since Pennzoil Ultra isn't available cheap in 5 quart jugs at Wal Mart anymore, the price is actually higher per quart than a preferred customer will pay for Amsoil Signature Series. Less performance for more money, doesn't make sense really. However, since the change over to GTL basestocks in the API SN reformulation, Ultra has been returning good UOAs in the Ford Mustang. I'd like to see how it does in a Focus.
What others fail to see, it's not only UOA results that make a difference. Many people do not realize that cheaper base stocks have a higher frictional coefficient, causing higher friction, higher heat, and lower efficiency.
Old 04-23-2013, 06:00 PM   #30
RedComet
RedComet's Avatar
Fan#: 99232
What I Drive: TB '14 Fiesta ST
Points 2,564, Level 30
Points: 2,564, Level: 30 Points: 2,564, Level: 30 Points: 2,564, Level: 30
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 8 RedComet Good Standing Member
I've added links to both this thread and the bypass filtration install info to the modifications list thread. :)
Kay - HN#79
'14 Fiesta ST Tux. Blk. 6MT, COBB Stg. 1
Gone: '12 Hatch SE Sport MTX75
V - Power* Junkie
RedComet is offline
