06 2.0 into 04 2.3 engine swap? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Engine & Transmission Swap
Engine & Transmission Swap The place to chat about any engine and transmission swap.
Old 11-16-2012, 09:21 AM   #1
timbowabo
timbowabo's Avatar
Fan#: 106318
What I Drive: 2004 Focus Wagon
FF Reputation: 1 timbowabo Good Standing Member
Hello Fanatics!
I have a 2004 Ford Focus wagon with a 2.3 engine. She has 321,000 hard miles and is showing signs that the end may be near. (Timing chain rattling, losing power, not shifting well, etc.)
I have a wrecked 2006 Focus wagon with a 2.0. Everyone I speak with about it is rather pessimistic about the engine/transmission swap, but I feel like they are just making uneducated guesses.
Does anyone here know what type of problems might arise if I attempt it? Wiring issues, computer compatibility, mounting, etc.?
I read on another thread that the reverse (2.3 in, 2.0 out) could be done easily because the only difference was "displacement is a little bigger".
http://www.focusfanatics.com/forum/s...=282199&page=2
Saving my beloved 04, while getting this junk 06 out of my back yard would be great. What do ya think?
timbowabo is offline
Old 11-16-2012, 09:59 AM   #2
streetfocus
streetfocus's Avatar
Fan#: 5768
What I Drive: 2004 Black Focus SVT
Points 2,551, Level 30
Points: 2,551, Level: 30 Points: 2,551, Level: 30 Points: 2,551, Level: 30
Level Up 68% Completed
FF Reputation: 2 streetfocus Good Standing Member
I think it will be fine. I hear that going the other way, 2.0 to 2.3, you have to shim the motor mount about a half inch. I don't know how that will affect you doing the reverse.
05 ZX3: Steeda intake, 67mm TB, custom 2.5 Magnaflow exhaust, Tom's Tune.
New: 04 SVT : K&N panel filter, 3 performance motor mounts, Taylor wires, orp, 67mm TB, Tom's Tune.
streetfocus is offline
Old 11-18-2012, 10:46 PM   #3
timbowabo
timbowabo's Avatar
Fan#: 106318
Good to hear streetfocus. Thanks.
I'm being told wiring is going to be a problem.
Anyone know for sure what I can expect?
Old 11-19-2012, 07:34 PM   #4
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,717, Level 76
Points: 13,717, Level: 76 Points: 13,717, Level: 76 Points: 13,717, Level: 76
Level Up 17% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
You will found the 23 has imtv, unlike the 20. Both use the imrc thou. I'd figure out if you can use the 23 head (after doing a valve job) on the 20, w/ the 23 intake manifold, then you shouldn't have any issues, w/ the pcm. You'll see the 2 electronic vacum switchs on the 23 & only 1 on the 20.
felixthecat is offline
Old 11-22-2012, 11:17 PM   #5
timbowabo
timbowabo's Avatar
Fan#: 106318
Good info felixthecat. Thank you.
I'm going to move forward with the job.
The two cars are not currently available for a side by side comparison.
What would happen if I did a straight swap without changing the head as suggested?
Would it be easier/cheaper to switch the pcm out rather than putting the 2.3 manifold on the 2.0? I have the entire 2006 2.0 at my disposal. The damage didn't affect the engine at all.
Old 11-22-2012, 11:34 PM   #6
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
You could try it right now by switching the pcm's & seeing if they run. I don't think its going to work w/ the imtv that the 23 has. I know you'll have your car down, but to speed it up, pull the 23 out & remove the head, clean it up for the 20 motor w/ intake manifold.
