Rear hub ass'y replaced: Already going out <5000 miles - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-19-2012, 11:48 PM   #21
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,618, Level 31
Points: 2,618, Level: 31 Points: 2,618, Level: 31 Points: 2,618, Level: 31
Level Up 12% Completed
Originally Posted by amc49 View Post
I would consider the fact that rolling drum on the last final tighten means that you are exerting torquing force also into the rear suspension in the form of twistup load, that amount of load will be subtracted from your actual nut torque regardless of what your wrench says. Meaning you won't have full torque there....
From like 75 ft. lbs. on up I have wheel bolted on, car on ground, brakes and engine on and someone standing on brake. The only way to guarantee pretty much full torque on nut itself.
What is this twistup load you refer to?
Your torque wrench will click (or display) the correct torque setting, even if the fastener you are tightening is on spring loaded suspension parts that compress under the load of the wrench.
If you put the wheel on the ground to do the final torquing, you are possibly harming your bearings during install. You will not be able to spin the drum during the torquing. Having the brakes on is another issue.
elsolo is offline
Old 11-20-2012, 12:59 AM   #22
Top-Ace
Fan#: 61807
What I Drive: 2002, Silver Frost, ZTS
FF Reputation: 1 Top-Ace Good Standing Member
That is unfortunate. My wifes 2000 Focus sedan has been running SKF brand rear hubs bought from napa for a long while now, no problems. I dont think motorcraft is necessary, but I know skf makes good stuff.
I did have to sand some rust off the spindle and applied a dab of anti-seize to keep the bearing from fusing/rusting to the the spindle again.
Top-Ace is offline
Old 11-20-2012, 05:27 AM   #23
amc49
Fan#: 96610
Points 3,362, Level 36
Points: 3,362, Level: 36 Points: 3,362, Level: 36 Points: 3,362, Level: 36
Level Up 8% Completed
Forum Activity 39%
Activity: 39% Activity: 39% Activity: 39%
Think manual transmission, the total torque rating is shared by every part the power flows through and divides amongst them. Depending on how you fit the torque wrench in on nut (angle of attack mainly) the rear suspension can deflect some thus absorbing part of it. Same reason torque wrench manufacturers tell you never to put an hand on torque wrench head say using 1/2" fittings and six inch extension. When you load it, the whole thing can swing to one side and risk rounding off corners of bolt/nut. Human nature has you putting a hand on top of wrench head to steady it but doing so affects the torque since some is absorbed by your hand.
A torque wrench is nowhere near smart enough to know if you put all that power into just a nut or into everything else the nut was attached to. It just clicks to an given number. Put a wrench on front wheel bearings already installed say with atx in park, wheel free in air and twist load on the wrench and tell me how much load you just tried to put on the axle and parking lock inside trans, you can waste 25 ft.lbs. quicker than spit there just pulling all the looseness up solid.
I roll disc or drum while tightening maybe to 50+, after that the races have contacted, all you are doing is running up the force holding them together. Balls have done all the centering they are going to do.
If suspension components compress under the load, I assure you they ARE absorbing force, the wrench does not know that, all it reads is 'total' force, not everything force was applied to.
Having brake on does nothing, if bearing already run up partially, the brakes will have an easy .020" in sideways deflection front or rear before anything becomes a problem. At full torque runup you'll do well to get another thou out of the bearing. Even though brakes themselves are a force you are working against they force the torque to pretty much stay right there local to the nut.
Quick test of bearing after done, spin it, if there's a problem you'll know it. The balls better be right or the bearing was scrap to begin with. Never lost a one doing this, in fact they last forever.
amc49 is offline
Old 11-20-2012, 09:04 AM   #24
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
twist-up load: he's referring to something else moving besides the nut or bolt you're torquing on. What it would be in this situation is that if you have the car jacked up by the subframe, then the suspension might be absorbing some of your torque instead of the nut. What should be done is that the suspension should be supported by a jack, and you should apply torque in a downward motion towards the jack so that there is no flexing of the suspension that might absorb some torque. If you torque upwards, or horizontally, then bushings or the springs will flex.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 11-20-2012, 07:24 PM   #25
amc49
Fan#: 96610
Forum Activity 39%
There you go, BTDT. There are ways of getting around the issue. Remember the angle of attack I mentioned? Simply a way to use the construction design of surrounding objects to aid you, not hurt you.
Look, there's 15 ways to skin a cat. I started doing this after observing how many times the torque did not seem very high at disassembly time. No way was there 175 ft.lbs. on nut then, maybe as low as 50 in some cases. I started looking for a way to guarantee the full torque amount. It seems to show, at disassembly now years later they seem to be tighter than they were before.
amc49 is offline
Old 11-29-2012, 11:55 AM   #26
zakkius
Fan#: 91044
What I Drive: 2005 Arizona Beige Metallic ZX4
Points 86, Level 1
Points: 86, Level: 1 Points: 86, Level: 1 Points: 86, Level: 1
Level Up 72% Completed
FF Reputation: 1 zakkius Good Standing Member
Originally Posted by G Ford Fan View Post
the above is 100% correct and I also do just that.
I spin the drum both directions several times as I am torquing the bearing hub nut down.
This helps to seat the bearing properly and is a very important step.
Seems like that would be a very crucial part of the replacement, and I have overlooked it. Let's see if I can get it right the second time around. Thanks!
zakkius is offline
Old 11-29-2012, 03:09 PM   #27
PLRX
PLRX's Avatar
Fan#: 16768
What I Drive: 2003 - ZX5 - 5 Spd - 2.3 Duratec
Points 1,402, Level 21
Points: 1,402, Level: 21 Points: 1,402, Level: 21 Points: 1,402, Level: 21
Level Up 2% Completed
FF Reputation: 1 PLRX Good Standing Member
Originally Posted by xxMichaelAnthony View Post
Chilton manual says 173 ftlbs. Also the hub nut needs to be replaced after a few uses.
I agree, 173 Ft-Lbs is correct.
2003 ZX5 HID Lights, Interior Carbon Fiber, Poly Bushings, SVT Suspension, Upper Strut Bar, Euro SVT Wheels,
SVT Brakes, Steel Braided Brake Lines, Drilled Rotors, K&N FIPK Generation 2 and Magnaflow Cat-Back
PLRX is offline
