VCM II Diagnostics interface installation - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-19-2012, 10:56 AM   #11
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,080, Level 34
Points: 3,080, Level: 34 Points: 3,080, Level: 34 Points: 3,080, Level: 34
Level Up 20% Completed
Forum Activity 3%
FF Reputation: 15 PratoN Great Standing Member
Kaaru, Question: While in drive (not sport/select-shift, if you have it) does your car shift into 6th at 35mph still? Or 40?
Because the dealership did an update on my car and while I have to admit that it does shift better, it still occasionally makes the chatter/slipping noises. The update just made it that much more difficult to get a dealer to warrant fixing my car. Also, if drive up a hill or manually shift it into 2nd/4th/6th I can still get the slipping noise every time. I feel like it's a Band-Aid fix that just masks the issue that the clutch is contaminated with oil.
PratoN is online now
Old 11-19-2012, 12:50 PM   #12
Kaaru
Kaaru's Avatar
Fan#: 96763
What I Drive: '12 Oxford Wh. SEL Sedan 28/07/2011
FF Reputation: 1 Kaaru Good Standing Member
Heya PratoN,
The issues I have are not sound related as my tranny does generate the ''normal'' noise, i'm pretty sure, nothing compared to the horrors I have listened to on youtube. As you know it's more related to a loss of power or reaction in certain conditions. I Will, however, try to note when the car shifts into 6th in Auto mode, as I have the sport mode. After driving a 2013 SE loaner for 2 days with the reg tranny (no ''S'' mode), I can say w/o hesitation that the level of cabin noise is far superior in my 2012 SEL than the loaner. Both were on winter tires, btw and driven in the same conditions/roads etc.
I do get the clutch slipping ''feel'' everytime I try to squeeze some HP out of this car, kinda like an elastic band stretching feeling. I have told my dealer about the oil contamination issues and he discarded it right away after driving my car. If my car has a mechanical problem, the updates they did ''camouflaged'' it pretty well. But like I said before, I feel I am going the same path I did back in June 2012 when they did FSA 12B37. The car worked great for a few weeks and then the tranny went downhill afterwards.
I'll check for the 6th gear /40Mph thing and report back
Cheers
2012 Oxford White SEL Sedan
303A + winter package + Moonroof + 16'' OEM
Kaaru is offline
Old 11-19-2012, 05:35 PM   #13
Kaaru
Kaaru's Avatar
Fan#: 96763
@ PratoN;
I did check what you asked from me. @40 MPH I am in the high band of the 5th gear. I wasnt able to collect more info as there is too much trafic going on where I drive. I'll try to find a quiet spot around home and do some serious testing for you. So far, it looks like I'm in 5th. Tranny behaved like a champ comming back home tonite. No jerkyness, no loss of power, no hesitations, no ''feels like you've been hit from behind'' while traveling on the idlle speed with your foot on the brake. I must say, driving this car is, for the moment, a pleasure. Just like post FSA 12B37. I acheived my good old 8.2L/100Km in one 'round trip.
I shall wait a bit before celebrating too much.
Kaaru is offline
Old 11-19-2012, 06:17 PM   #14
Kabigon
Fan#: 88299
Points 4,575, Level 43
Points: 4,575, Level: 43 Points: 4,575, Level: 43 Points: 4,575, Level: 43
Level Up 13% Completed
Forum Activity 13%
FF Reputation: 11 Kabigon Great Standing Member
I have a question for you:
Do you have a confirmed oil leak?
If so, what is the reason (according to the dealer) that they will not replace the transmission seal and clutch assembly?
Kabigon is offline
Old 11-19-2012, 06:31 PM   #15
PratoN
PratoN's Avatar
Fan#: 88058
Forum Activity 3%
Nope - which is the only reason I'm thinking about taking the car apart myself... so far 2 dealers have looked into the jerky ride/poor acceleration uphill and grinding noises coming from the transmission. Without an external oil leak, they say there's nothing they can do so they come back and tell me "That noise is normal."
I suppose there's a chance I could just have a bad clutch without the oil leak - but no dealer has looked into replacing the clutch under that circumstance either.
Old 11-19-2012, 08:54 PM   #16
Kaaru
Kaaru's Avatar
Fan#: 96763
That's a negative oil leak for me aswell.
Kaaru is offline
Old 11-19-2012, 09:14 PM   #17
Brabs_Weather
Fan#: 93741
What I Drive: 04 Ex Ltd, 08 Edge Ltd, 12 FF Ti
Points 709, Level 14
Points: 709, Level: 14 Points: 709, Level: 14 Points: 709, Level: 14
Level Up 9% Completed
FF Reputation: 2 Brabs_Weather Good Standing Member
i think that most fixes have found the internal seal separating the dry clutch from the wet has a leak. All of the people who have had success show that the seals were replaced internally. my 2 cents
White Platinum Tricoat Metallic
2012 Ford Focus Titanium
Handling Package Nitto Motivo's
Borla Exhaust with UltraQuiet resonator
K&N X-4870. Steeda RSB
Brabs_Weather is offline
Old 11-20-2012, 12:41 PM   #18
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,469, Level 36
Points: 3,469, Level: 36 Points: 3,469, Level: 36 Points: 3,469, Level: 36
Level Up 80% Completed
Forum Activity 18%
Originally Posted by Kaaru View Post
@ PratoN;
Thanks for the update, Kaaru. I'm going to keep an eye on this thread and monitor how things go for you, but feel free to contact me (or Ford Canada) directly if you need any assistance.
Have a great day!
Crystal
FORD SERVICE
p: 800.392.FORD
FordService is offline
