Zetec Powered MGB Build Thread - Page 9 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Engine & Transmission Swap
Engine & Transmission Swap The place to chat about any engine and transmission swap.
Old 01-29-2013, 07:46 AM   #81
Mustangsix
Mustangsix's Avatar
Fan#: 106702
What I Drive: 32 Ford, 73 MGB GT
Points 581, Level 11
Points: 581, Level: 11 Points: 581, Level: 11 Points: 581, Level: 11
Level Up 62% Completed
FF Reputation: 1 Mustangsix Good Standing Member
Son and new wife are on their honeymoon so I'm doing a few things while he's away.
I've decided to move the position of the crank trigger from it's normal location on the rear of the engine block. Usually it picks up the 36-1 trigger signal for the EDIS from holes or pegs on the rear face of the flywheel, but we will be using a 2.3 Mustang flywheel instead of a Focus flywheel. The pressure plate heights and clutch disc matches better to our bell housing and transmission.
we'll move the ignition pickup to the front of the engine by using a 36-1 trigger wheel on the front balancer. I got the Thunderbird turbocoupe bellhousing cleaned up and have to weld on some material in order to add a couple of mounting holes. We're not using a 4 cyl T5 so I need to turn the input shaft down to .590" to fit the Focus pilot bearing.
I made a mockup of a bracket for the serpentine idler wheel. I have to get a new water pump and finish the alternator bracket in order to check the dimensions. Once I do that, I'll carve the bracket from some aluminum stock. We'll tension the belt at the alternator by turning some rod ends or clevises.
I was going to look for a Contour oil pan and pickup but I think we'll wait until we see how much clearance we have.
That's kind of it for now. When my partner gets back, I'll let him update photos.
Mustangsix is offline
Old 01-29-2013, 02:26 PM   #82
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 21,172, Level 91
Points: 21,172, Level: 91 Points: 21,172, Level: 91 Points: 21,172, Level: 91
Level Up 65% Completed
Forum Activity 7%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
just curious why you didnt go with a bp? the 1.8l miata bp and either a 6spd or 5spd that came stock would have been a lot easier and they make just as much power and get the same economy as the zetec
Tim
Turbo Turtle Garage
Zetec and Duratec Turbo kits, engine building
turboturtlegarage.com
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 01-29-2013, 03:01 PM   #83
Mustangsix
Mustangsix's Avatar
Fan#: 106702
There are any number of off-the-shelf RWD packages that would work well in an MGB. I've seen Toyota, Nissan, Mazda, Duratec, and Zetecs put into these things. The Zetec/T5 is compact, fits well, and weighs almost 200 lbs less than the MGB engine and trans. Personally, I wanted to use a 4.0 Rover V8 that I have at my friend's shop! I think a Duratec would have been a good choice, too.
Just like the Miata, the Zetec has a lot of community and aftermarket support. The Brits routinely use the engine in everything from early MkI and II Escorts, Fiestas, Mondeos, and a host of others. They've done the goundwork for most of these kinds of swaps.
Then when we looked at the stuff we had leftover from other projects just laying around the garage it kind of made sense. We already had a bellhousng and a T5, a Megajolt controller, Mustang radiator, bike carbs, SU's (if we don't like the Keihins), and a lot of other bits. We have access to machines and fabrication tools, so making a bracket, milling a piece of aluminum, or turning a shaft is no big deal.
There's also was the cost. Zetecs are dirt cheap. We paid $250 for our low mileage engine, but have run across them for as little as "free". Not so with the Miata stuff. Good 1.8 engines and 6 speeds are still a little pricey. For the price of just a single 6-spd miata trans, I can buy five T-5's.
As far as easy, this swap is pretty straightforward. The flywheel fits, the trans and bell bolt on. Heck, the only hard part is making a water manifold to run to the radiator from the back of the head. I think there's probably nearly as much fabrication with any combo.
Finally, when you are tire-limited for traction, you can only use so much horsepower anyway. 10 or 12 lbs/hp makes for a pretty lively car. The MG will only weigh about 2000 lbs when we get finished. With 150 RWHP or a bit more, it will be pretty quick.
Anyway, it is what it is, we have it and are committed to making it work well.
Old 02-02-2013, 03:45 PM   #84
beatmaniac1
beatmaniac1's Avatar
Fan#: 90996
What I Drive: 2003 red svtf
Points 416, Level 8
Points: 416, Level: 8 Points: 416, Level: 8 Points: 416, Level: 8
Level Up 32% Completed
FF Reputation: 2 beatmaniac1 Good Standing Member
Buy-Sell-Trade Rating: (4)
Originally Posted by 79mgb View Post
It took way too long to get an engine. I hope people are still following the build thread! lol
I'm still following It's a nice build with a great car !! Wish I had time for projects like these
beatmaniac1 is offline
Old 02-14-2013, 02:42 AM   #85
jonyrocks
jonyrocks's Avatar
Fan#: 97716
What I Drive: 2002 silver focus svt #1021
Points 574, Level 11
Points: 574, Level: 11 Points: 574, Level: 11 Points: 574, Level: 11
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 1 jonyrocks Good Standing Member
interesting build, if you guys need an extra hand let me know, im near the ucf area
jonyrocks is offline
Old 02-14-2013, 02:57 AM   #86
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,709, Level 94
Points: 23,709, Level: 94 Points: 23,709, Level: 94 Points: 23,709, Level: 94
Level Up 36% Completed
Forum Activity 14%
On a honeymoon huh? Sounds like you guys have nine months to finish this project before you're stuck with it yourself. . Sounds like good progress too.
mikebontoft is offline
Old 02-17-2013, 03:44 PM   #87
79mgb
79mgb's Avatar
Fan#: 105006
What I Drive: 1979 MG MGB
Points 2,815, Level 32
Points: 2,815, Level: 32 Points: 2,815, Level: 32 Points: 2,815, Level: 32
Level Up 44% Completed
FF Reputation: 3 79mgb Good Standing Member
Hey everybody. I'm back! We've made a lot of progress on the build and I have a lot of parts photos.
I was able to paint the block a few days before the wedding. I started by cleaning the block as well as possible by using some Marine Clean and some wax & tar remover. Then I just brushed on some gloss black POR-15 top coat. It's extremely glossy and dried hard as a rock. It should hold up much better than rattle can paint. Currently most things on the engine are just mocked up. The head is just sitting on the block with the junkyard valve cover and the windage tray and oil pan are just held on with a few bolts.
If you spotted it from the first picture, I'll be using an oil filter relocation kit from Summit Racing (p/n: TRD-1113). It'll give me plenty of clearance from the chassis rails. My dad was nice enough to get this for me while I was gone.
The windage tray needed modification to make room for the starter so I cut the sides of it off since they were unnecessary for my build. Both sides look about the same.
I cleaned and spray painted the water pump housing with the flat aluminum VHT high temp paint. I still REALLY like how easy that stuff is to paint with. I also ordered a new Motorcraft water pump (p/n: PW368) while I was gone since mine was busted. Dad and I have it installed to the water pump housing but the pulley and the housing are only mocked up and held on by a few bolts for now. I still need to get a new idler pulley and belt tensioner.
You can see the original cylinder head for the engine in the background. I might clean it up and sell it later.
I also ordered some Stage 2 Comp cams. They were purchased on this forum from Earls32 and they're still brand new in the box. They look like they'll work very well for what I'm after. He also sold me new ARP cam bolts and camshaft seals. I just need to buy some adjustable cam gears. I'm hoping to get some Fidanza's.
INTAKE
GRIND #: ZT 272S-112
VALVE ADJUST: .006
GROSS VALVE LIFT: .381
CAM LOBE LIFT: .381
ADV. DUR. @ .006 VALVE LIFT: 272
VALVE TIMING @ .050. 2- BTD 50 ABD
THESES SPECS ARE FOR THE CAM INSTALLED FOR INTAKE @ 112.00 CENTER LINE.
DURATION @ .050. 228
EXHAUST
VALVE ADJUST: .006
CAM LOBE LIFT: .381
VALVE TIMING @ .050. 42 BBD 6 ABD
THESES SPECS ARE FOR THE CAM INSTALLED FOR EXHAUST @ 112.00 CENTER LINE.
I'll update more later tonight about how we're going to adapt the Zetec to the T-5.
79mgb is offline
Old 02-17-2013, 10:09 PM   #88
79mgb
79mgb's Avatar
Fan#: 105006
Here's the other update I promised. If this sounds a little vague or spaced out it's because I'm watching Walking Dead.
I'm planning on using this 1992 Escort (1.9L) flywheel. It's used but in pretty good condition. It had a light surface rust but cleaned up well with a wire brush. The Mustang flywheel bolt holes are 10mm while the Zetec bolts are 11mm. I'll just need to open up the holes to fit some Zetec Flywheel bolts.
We'll be using a release bearing from a 2001 Camaro LS1.
Here's a T-5 from a 1996 Mustang (3.8L V6):
And here it is as we mount it to a bell housing from a 1992 Mustang (2.3L):
Now I need to look at getting a clutch kit, starter, and some hardware for the flywheel and pressure plate.
79mgb is offline
Old 02-18-2013, 11:39 AM   #89
Mustangsix
Mustangsix's Avatar
Fan#: 106702
We're mixing and matching a lot of parts, but it's not just a bolt-together. The input shaft of the transmission has to be turned down from .662" to .590" and shortened by about .380".
We're using the Escort flywheel because its a lot lighter than the Zetec flywheel (about 6 lbs less) and the Mustang clutch will bolt on. We're adding a trigger wheel to the front of the engine for the EDIS crank sensor.
Still have to make bushings for the bellhousing dowels to properly locate the bell and we still have to decide whether to mod the block or mod the bell for the top two bolts.
Old 02-18-2013, 03:42 PM   #90
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 12 Outback
Points 9,452, Level 65
Points: 9,452, Level: 65 Points: 9,452, Level: 65 Points: 9,452, Level: 65
Level Up 34% Completed
Forum Activity 10%
Very cool build. I look forward to seeing the finished product.
2012 Subaru Outback 6 speed manual - current DD
I always moderate naked!
bringler26 is offline
