Zetec Powered MGB Build Thread - Page 15 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Engine & Transmission Swap
Engine & Transmission Swap The place to chat about any engine and transmission swap.
Old 04-09-2013, 08:38 AM   #141
Mustangsix
Mustangsix's Avatar
Fan#: 106702
What I Drive: 32 Ford, 73 MGB GT
Points 581, Level 11
Points: 581, Level: 11 Points: 581, Level: 11 Points: 581, Level: 11
Level Up 62% Completed
FF Reputation: 1 Mustangsix Good Standing Member
The engine isn't going to be as far back as the pictures might look. When that was shot, the whole thing was hanging by a couple of straps. The motor and trans actually needs to come up and forward a couple of inches, so the net result is that the clearance issue is mainly due to the thermostat housing on the rear of the block. You could shove the engine all the way back against the inner firewall, but there's no need.
We ended up using the Focus pan. The Contour pan wouldn't help a lot in this installation. Both pans are angled for their FWD configuration. That angle interferes with the front crossmember on this car even with the sump to the rear, so there was really nothing to be gained.
I did give some thought to using a 1.9 Escort pan. I could have made a new pickup tube and notched the sump. If we do this again, we might consider that option.
The plan is to start at the transmission mount first. The tunnel is very narrow and positioning the drive yoke is critical so that it doesn't hit the tunnel or the e-brake mount. Once we determine height and fore/aft position on the trans, we can just lift or lower the engine to get the driveline angle set to match the pinion input. I'll use a magnetic caster/camber gauge to read that.
I put the hood on and looked at the front of the engine thru the grill and we have about 3.5" of space to work with between the hood and the cam gears, so no worries there.
I also noticed that there really isn't a lot of room for a conventional release arm to be used, so our plan to use the hydraulic throwout bearing is going to work out.
Starter clears very well, steering is no issue.
Mustangsix is offline
Old 04-09-2013, 10:05 PM   #142
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
very strange to see a zetec in a non-transverse posture!!! If nothing else, it greatly simplifies a whole lotta future maintenance. Can't wait to see it with the side-draughts mounted.
I don't recall if you've mentioned how much heavier/lighter the zetec is than the MG's original motor (cast iron block/head/manifold?), but have you recalculated the weight redistribution of sliding it fore/aft of the original? The British 2-seaters are sufficiently light in the back for a couple of people to lift with their hands, so the rear wheels are gonna have enuf trouble sticking with the powerplant upgrade (the stock 80 hp (?) motor relieved the MG engineers from worrying too much about that).
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 04-10-2013, 07:48 AM   #143
Mustangsix
Mustangsix's Avatar
Fan#: 106702
With the stock engine and transmission the MGB is a little nose heavy and the weight distribution on a late model rubber bumper like ours is about 52/48. Our new weight distribution will be closer to 51/49, still biased to the front. The engine setback is not really that much - less than two inches. The B engine was setback pretty far to the rear as well - it just didn't have a thermostat trying to occupy the firewall!
Any distribution change will come mostly from the weight reduction, not the engine relocation. The old engine was a heavy lump. Most sources say it is over 400 lbs; as much as 450lbs fully dressed. The Zetec is at least 100lbs lighter (we haven't weighed it). The two of us can easily lift and carry the long-block around the shop. The T5 is a little lighter than the original 4-speed, too.
Removing 100lbs of bumpers, the new engine/trans, and some other tricks, we're probably trimming 300lbs off the car and will end up with a curb weight of about just over 2000lbs. That's HUGE! A Focus SVT weighs almost 2800lbs, for comparison, with nearly 61% of that over the front wheels.
MGB's are traction limited anyway because of the leaf spring suspension. Racing versions added traction bars and panhard bars to help control spring windup and axle movement. We're going to skip that stuff - not racecar.
We will have to do something the get the ride height back down, though.
Old 04-26-2013, 02:36 PM   #144
Mustangsix
Mustangsix's Avatar
Fan#: 106702
It's been a while since the last update.
We're finishing off the final sheetmetal firewall mods today. The new motor mounts got done last week and are off to the powdercoater alnog with the brake pedal box, pedals, and a bunch of other brackets. I still have to tack weld a couple of things and then we can shoot paint and primer.
My son spent over a week wire brushing and cleaning old seam sealer and undercoating from the firewall. Gummy, nasty work, but the metal underneath was like brand new.
The engine fits beautifully. I cut the old MG frame mounts off and fabbed some new ones to hold the original rubber. The T5 sits in the original crossmember using a stock Mustang trans mount and the shifter comes up thru the stock hole. I'm going to pull the tailshaft off to install a 6-tooth speedo drive gear. E had to modify our alternator bracket a little to get the alt up higher over the chassis rail.
The Magnaflows came in and we'll mount those just like the stock arrangement.
I have the new driveshaft but will have to swap on one of the u-joint flanges from the old MG shaft. The MG u-joints are tiny.
The next big task is to fab the intake, but I think we'll wait until the engine is back in for good to make sure we have the angles correct and there's no interference elsewhere.
We'll get some photos up this weekend.
Old 04-26-2013, 02:42 PM   #145
Kickerbeast
Kickerbeast's Avatar
Fan#: 87814
What I Drive: FrankenFocus AWD In Progress
FF Reputation: 1 Kickerbeast Good Standing Member
I can't wait to see those carbs on there!
Andrew-aka The Swap Shop
ZX3 going AWD http://www.focusfanatics.com/forum/showthread.php?t=310574
Kickerbeast is offline
Old 04-27-2013, 11:44 AM   #146
2motorman
Fan#: 114036
What I Drive: Mgb'sx2
FF Reputation: 1 2motorman Good Standing Member
I've only just stumbled across this project although I've been considering it for some time, but I can't decide between zetec or red top, just glad that someone else is doing the development work! would you mind if I contacted you off the forum with regard to some technicalities, namely sizes of specific components and fittings, in that way we wont clog up this forum with stuff that no-one else wants?
2motorman.
2motorman is offline
Old 04-30-2013, 10:48 AM   #147
79mgb
79mgb's Avatar
Fan#: 105006
What I Drive: 1979 MG MGB
Points 2,815, Level 32
Points: 2,815, Level: 32 Points: 2,815, Level: 32 Points: 2,815, Level: 32
Level Up 44% Completed
FF Reputation: 3 79mgb Good Standing Member
Buy-Sell-Trade Rating: (4)
2motorman.
Feel free to PM either of us on this forum.
Driving a Zetec Powered MGB. :)
79mgb is offline
Old 04-30-2013, 12:25 PM   #148
79mgb
79mgb's Avatar
Fan#: 105006
Hey guys. Sorry for the lack of updates. I'd like to build upon what my dad has already mentioned. The engine compartment has been cleaned up, primed, and painted Blue Royale. The paint coverage ended up being a little too light in some areas so I'll have to respray some paint in about a day or so. It's more work than I was hoping for but it'll be worth the effort.
A few photos of the progress:
Also, all the parts came back from the powder coat company and they look GREAT. When we start piecing everything together, it'll look brand new. I'll try to be a little better about keeping this thread updated. Stay tuned!
79mgb is offline
Old 05-01-2013, 09:43 AM   #149
Kickerbeast
Fan#: 87814
I'm loving that blue. Need to do the whole car that color
Old 05-01-2013, 09:58 AM   #150
79mgb
79mgb's Avatar
Fan#: 105006
Thanks! That's the plan. The last picture is a little darker than how it looks in person. I took that photo in the evening without flash. If you look at the MGB on page 14, it looks closer to that.
After we get the car running I'm going to paint the exterior of the car. I really like this blue much better than the original color too. Not so smurfy. Since it's a factory MGB color I don't feel guilty about repainting it.
79mgb is offline
