Affordable 2013 Focus brake upgrade - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-15-2012, 04:51 PM   #1
bwh13
Fan#: 105709
What I Drive: 2013 Silver Focuse SE
FF Reputation: 2 bwh13 Good Standing Member
I've discovered what looks to be a simple way to upgrade the front rotors to 300mm using factory parts with either a modification to the mounting bracket or using a machined part to allow the use of a slightly smaller diameter bolt. I think the stock caliper may fit, but if not then the new caliper uses the stock pads.
I have a 2013 with the 16" wheels and will be test fitting the upgrade on it as soon as I get the parts.
bwh13 is offline
Old 11-19-2012, 01:13 AM   #2
Michael Jackson
Michael Jackson's Avatar
Fan#: 104370
What I Drive: 2013 Tuxedo Black Hatchback
FF Reputation: 1 Michael Jackson Good Standing Member
Interesting.
Are these Ford oem parts, or where are you sourcing them?
Sent from my SCH-I905 using FF Mobile
Michael Jackson is offline
Old 11-19-2012, 01:15 AM   #3
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 3,959, Level 40
Points: 3,959, Level: 40 Points: 3,959, Level: 40 Points: 3,959, Level: 40
Level Up 5% Completed
Forum Activity 9%
FF Reputation: 14 mac.mogul Great Standing Member
Nevermind where the parts are from, is it safe?
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is offline
Old 11-19-2012, 09:36 AM   #4
bwh13
Fan#: 105709
The parts are all OEM. It would fit and function the same as if the factory installed it.
bwh13 is offline
Old 11-19-2012, 06:49 PM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,966, Level 74
Points: 12,966, Level: 74 Points: 12,966, Level: 74 Points: 12,966, Level: 74
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 99%
Your right down there, I'd be hitting up Todd at TCE.
felixthecat is offline
Old 11-19-2012, 09:27 PM   #6
bwh13
Fan#: 105709
I've known Todd for years, even bought my first Wilwood calipers from him. I'm looking at doing a stock looking setup for now. Then I'll try putting a set of Wilwoods on there.
bwh13 is offline
Old 11-20-2012, 11:22 AM   #7
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
Just a word of caution....bigger is not always better. If fact, without proper research and engineering, adding bigger front brakes without addressing things like proper brake bias, etc. you could actually be making braking (and handling) worse. Interchanging parts willy nilly can often have more negative than positive results. If you really need better braking than stock, experimenting with friction materials may be the better way to start.
Geezer is offline
Old 11-20-2012, 03:40 PM   #8
bwh13
Fan#: 105709
I agree with that for the most part, but have enough experience (35 yrs) to know how much is too much when it comes to brake improvements.
While adding a better pad is the first step in getting the brakes to perform to a higher standard, a moderately larger rotor will be of even more help without upsetting the bias the engineers built into the car. Going from 280 to 300mm isn't that big a change that it will upset the apple cart, but will give better fade resistance and longer pad life.
I'm pretty sure the caliper brackets will fit the stock calipers, so there won't any change in the clamping force or pedal feel, travel, etc. If they don't then I'll make some brackets for the Wilwoods and use them.
bwh13 is offline
Old 11-21-2012, 08:08 AM   #9
Fernando_221
Fan#: 79468
What I Drive: '06 ZX4 2.0L Dtec, '11 MK2.5 2.0L
Points 1,806, Level 25
Points: 1,806, Level: 25 Points: 1,806, Level: 25 Points: 1,806, Level: 25
Level Up 6% Completed
FF Reputation: 3 Fernando_221 Good Standing Member
So, what parts are needed?
Fernando_221 is offline
Old 11-21-2012, 08:49 AM   #10
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
Watching this one. Interested to see what parts are involved and where they're sourced from, though.
Joined the dark side.
Zillon is offline
