Any 2012's losing weight? - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-19-2012, 03:15 PM   #41
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,268, Level 67
Points: 10,268, Level: 67 Points: 10,268, Level: 67 Points: 10,268, Level: 67
Level Up 55% Completed
Forum Activity 42%
Activity: 42% Activity: 42% Activity: 42%
FF Reputation: 26 suss6052 Great Standing Member
These Recaros look like they are really basically the same seat base but with more aggressive seat bolsters on the seat back. But they are too expensive to retrofit at least new from ford, maybe wait awhile until there are more used examples in the field, but I'd still prefer to have had the seats from new.
suss6052 is online now
Old 11-19-2012, 05:12 PM   #42
Tommyatomic
Fan#: 105916
What I Drive: MK3 FocusHatch 5SPD, '93 RHD WRX
Points 183, Level 3
Points: 183, Level: 3 Points: 183, Level: 3 Points: 183, Level: 3
Level Up 66% Completed
FF Reputation: 1 Tommyatomic Good Standing Member
Originally Posted by TiStick View Post
Recaros are heated. Prolly pretty pricey, though. You have a narrow ass? I don't think I'd fit in the riccis
I do infact have a narrow ass as does my wife. I'll get my friends to keep their eye's peeled for the ST Recaro's. It only takes about 6 months before you can find anything newish wrecked.
Tommyatomic is offline
Old 11-19-2012, 05:15 PM   #43
Sonic_HedgeHog
Sonic Mk3 Crew #00
Sonic_HedgeHog's Avatar
Fan#: 50003
What I Drive: '12 Sterling Focus SE 5dr Sport Pkg
Points 126,755, Level 100
Points: 126,755, Level: 100 Points: 126,755, Level: 100 Points: 126,755, Level: 100
Level Up 0% Completed
FF Reputation: 19 Sonic_HedgeHog Great Standing Member
Why wait for the ST Recaros? Why not find some new(ish) Recaros or Sparcos? The ones in the ST are pretty sweet but I'll bet money they're nowhere near being the lightest or most comfortable out there...
Hatch Nation #156. Sonic's Mk3 Crew Founder and #00
Moderator: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, SW Fanatics, Sonic's MK3 Crew
Sonic_HedgeHog is offline
Old 11-19-2012, 05:30 PM   #44
Focus YBTC
Focus YBTC's Avatar
Fan#: 97107
What I Drive: 2012 Yellow Blaze Tri-Coat Titanium
Points 653, Level 13
Points: 653, Level: 13 Points: 653, Level: 13 Points: 653, Level: 13
Level Up 6% Completed
FF Reputation: 1 Focus YBTC Good Standing Member
Originally Posted by Tommyatomic View Post
Thats basically a picture of everything in the focus that should not be considered for weightloss.
In regard to an earlier post. I also have the heated seats and my Wife would have me murdered in the night if I replaced them with light weight seats. But I too keep thinking about how much more they weigh than say for instance the recaro's in the Focus ST.
My JDM WRX came with factory recaro's that were very light weight.
I agree. The Focus ST-R even adds a very extensive roll cage for racing purposes. It looks like they might have removed the high strength steel door side beams and replaced them with sturdy looking Cro-Mo steel tubing structures.
Focus YBTC is offline
Old 11-19-2012, 06:08 PM   #45
Tommyatomic
Fan#: 105916
Points 183, Level 3
Well in the case of the Focus ST-R dont forget the weight savings from dropping support for cargo and passengers.
I would assume it also has dropped the fuel tank in favor a fuel cell and surge tank. Also the weight savings from an AC delete, heater core delete, MFT + dash delete, passenger and rear seat delete.
I can only guess that if the engineers behind the ST-R were worth their paycheck the ST-R probably uses an oil cooler combined with a smaller alloy radiator for better cooling while saving weight.
The list of things deleted from a purpose built racecar gets long and frequently purpose built racecars are seamwelded.
Old 11-20-2012, 01:46 PM   #46
Focus YBTC
Focus YBTC's Avatar
Fan#: 97107
Well since the ST-R still weighs approximately 2700 pounds, at first glance it looks like they didn't save a whole lot of weight by dumping all that stuff. Considering that they are starting with an ST that weighs significantly more than a regular Focus (ST curb weight is 3,223 lbs.) it's not bad at all.
Focus ST-R
TECHNICAL DATA
Powertrain
• 2.0L EcoBoost I-4
• 250 hp est.
• 250 lb.-ft. of torque est.
• Ford Racing custom exhaust
• Ford Racing engine calibration
• Ford Racing high capacity radiator
• Ford Racing clutch
• Ford Racing oil to air oil cooler
• Remote oil filter
• 6-speed manual transmission with limited-slip differential
Chassis
• Weight – 2700 lbs.
• Structural performance: over 20,000 lb.-ft/degree (torsional)
• Seam-welded steel unibody with integrated FIA-certified safety
cage.
Front Suspension
• AST performance coilover adjustable dampers
• Adjustable camber plates
• Ford Racing upgraded sway bar with adjustable end links
• Upgraded bushings
Rear Suspension
• AST performance adjustable dampers
• Control-blade multilink rear suspension
• Ford Racing upgraded swaybar with adjustable end links
• Upgraded bushings
Steering
• Electric steering with unique Ford Racing calibration
Brakes
• Front: 336mm 2-piece rotors with race pads
• Rear: 271mm production with race pads
• Ford ABS with unique Ford Racing calibration
Wheels & Tires
• 18-inch BBS CF 1-piece cast alloy wheel (Anthracite)
Fuel System
• ATL® 18-gallon fuel cell with custom single-dry-break system
Exterior
• Brake cooling ducts
• Hood pins
• Ford Racing front/rear tow hooks
Interior
• Ford Racing lightweight wiring harnesses
• RECARO Pro Racer HANS® racing seat
• AiM MXL Pista GPS-based data system
• Ford Racing short throw shifter
• Ford Racing fire suppression system
• Ford Racing 6-point safety harness
• Ford Racing driver safety nets
• Ford Racing steering wheel with quick release
• Custom center panel with switches
https://docs.google.com/viewer?a=v&q...JZg53yhbUyUCCw
Old 11-20-2012, 03:16 PM   #47
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
What I Drive: LesVagon
Points 3,706, Level 38
Points: 3,706, Level: 38 Points: 3,706, Level: 38 Points: 3,706, Level: 38
Level Up 38% Completed
FF Reputation: 16 TiStick Great Standing Member
Airbag light
Sonic's Mk3 Crew #11
Hatch Nation#163
Originally Posted by suss6052 View Post
Watch out for the D
TiStick is offline
Old 11-20-2012, 03:46 PM   #48
UnleashedBeast
UnleashedBeast's Avatar
Fan#: 100738
What I Drive: 2012 Focus Titanium
FF Reputation: 3 UnleashedBeast Good Standing Member
Airbag light
Resistor plugs
2014 Mustang GT custom ordered to replace the GT500: Sterling Gray, NAV, Recaros, Brembos, Glass Roof, back up camera, 6 speed auto, loaded
2012 Focus Titanium - 18" wheels with handling package
2009 GT500 Shelby (700 rwhp) - sold
UnleashedBeast is offline
Old 11-20-2012, 11:39 PM   #49
Albarry
Sonic Crew #016
Albarry's Avatar
Fan#: 87877
What I Drive: 2012 Sport completely stock, DCT
Points 3,558, Level 37
Points: 3,558, Level: 37 Points: 3,558, Level: 37 Points: 3,558, Level: 37
Level Up 39% Completed
FF Reputation: 8 Albarry Good Standing Member
Originally Posted by UnleashedBeast View Post
Resistor plugs
Sounds irresponsible, might need your airbags... Just sayin'
(STORM THE ALBATROSS) SC016 RR054 SR251 [HOONIGAN]
Albarry is offline
Old 11-23-2012, 11:57 AM   #50
Tommyatomic
Fan#: 105916
Points 183, Level 3
Yeah probably irresponsible. But depending on the state very illegal to tamper with safely equipment.
I'd be curious about the weight of the wheels used on the to us st-r
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
