Does your vent selector stick? Have you broken the cables? Read on, - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-29-2013, 12:02 PM   #21
hamlorac
Fan#: 101842
What I Drive: 2006 white ZX5
Points 753, Level 14
Points: 753, Level: 14 Points: 753, Level: 14 Points: 753, Level: 14
Level Up 53% Completed
FF Reputation: 1 hamlorac Good Standing Member
Flap fix
Ref. Sticking vent selector heater controls on 2006 ZX5.Remove drivers under dash panel,loosen hood cable nut and slide off, unclip data connector and set panel aside.Remove 4 screws from selector control ,cables attached, and let hang down. Unhook the black selector gate and feel the action of both front and rear flaps.The main culprit is the flap closest to the radio so as you move that flap you should feel the sticking or stuck condition at both of its far end positions.A deformed internal flap seal causes this jamming effect, so here follows my humble solution, that involves adjustable end stops.I used a 1/16" aluminum strip 3" long and bent up one end about 1/8" at 90 degrees and mounted it on the heater box with short self-tappers against the link of that flap to provide a forward stop.This stop should be carefully positioned so as not to allow the flap to drop into its sticky resting place.If you are close the aluminum is easy to bent so as to get a finer adjustment.The next step is to remove the radio surround panel,disconnect cigar lighter,remove the radio, pull two cables and set unit aside.Drill a hole in the heater box and install adjusting bolt bracket as shown in the photo. It is important to adjust these end stops as minimally as possible or the mechanism will bind. After the two stops are mounted a final check before reassembly is to install the black selector gate back in position and work "by hand" the mechanism through its full motion to confirm that no stickiness occurs in either of its end positions and that it transitions smoothly through its various modes.Although the flap is not technically as the designer intended, my air flow is normal and the cable controls work properly. The cost of materials is negligible and the labour maybe two hours work .The Ford car company does not need any more of our hard earned money so I hope this helps some other physically challenged heater boxes. The cost of materials was negligible and took maybe 2 hours, with a low difficulty scale.
Name:	next flap fix 1 edit.JPG
Name:  next flap fix 7 edit.jpg
Name:  qed 3 edit.jpg
hamlorac is offline
Old 09-14-2014, 05:34 AM   #22
Tklein
Fan#: 115031
What I Drive: 06zx4-silver
Points 11, Level 1
Points: 11, Level: 1 Points: 11, Level: 1 Points: 11, Level: 1
Level Up 21% Completed
FF Reputation: 1 Tklein Good Standing Member
NICE !! Thanks for this reply, lots of good info to get busy on !! Thanks; Tim Klein
Tklein is offline
Old 02-01-2015, 10:12 AM   #23
catfish77
Fan#: 189882
What I Drive: 2004 Red ZX3
Points 119, Level 2
Points: 119, Level: 2 Points: 119, Level: 2 Points: 119, Level: 2
Level Up 38% Completed
Forum Activity 3%
FF Reputation: 1 catfish77 Good Standing Member
There are a lot of post about the door sticking at the extreme ends but none for in the middle. I keep mine in the blend setting most of the time and mine will stick there. It is very difficult to get it to switch to vents or feet from there. Is the door sticking or does it have to do with the track? Same fixes as mentioned or different?
catfish77 is offline
Old 02-01-2015, 12:22 PM   #24
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,449, Level 75
Points: 13,449, Level: 75 Points: 13,449, Level: 75 Points: 13,449, Level: 75
Level Up 50% Completed
Forum Activity 99%
Posts about sticking at the ends refer to the heat control blend door, not the multiple doors controlling defrost/vent/floor.
Center position on the knob (floor) isn't QUITE exact on mine for example, there's a transition there between defrost settings & floor/vent settings that's often sticky because a lot moves at once there.
For myself, just keeping it on either side of that position avoids leaving it right at that "sticky" transition point - either in the defrost/floor side or the vent/floor side. Not being heavy handed when moving it through that point has avoided troubles with it so far.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
