Gas station nozzel keep kicking off. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-15-2012, 01:34 AM   #1
ryan1428
Fan#: 58574
What I Drive: 06 SES ZX5 (wife), 71 Camaro New
FF Reputation: 1 ryan1428 Good Standing Member
I have run in to this a few times over the years with different cars. Don't think it is the Gas Stations Pumps. When I try to fill up gas....it clicks off, like it is full but no were near full. Need help. Thanks.
Ryan
07 ZX5
ryan1428 is offline
Old 11-15-2012, 01:42 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,343, Level 100
Points: 138,343, Level: 100 Points: 138,343, Level: 100 Points: 138,343, Level: 100
Level Up 0% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (11)
Moved your thread to the technical chat area so you can get some help. The performance chat area wasn't the ideal place to make the thread. You may want to check the hoses on the filler neck to make sure they are not broken or anything like that. I know if something is wrong with them it can cause the problem you are describing.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 11-15-2012, 06:00 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
Probably a buildup of vapor in the tank. You might have a problem with your EVAP system, but I'd think that would throw a code. Is this something that happens every time you fill up or just sometimes?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 11-17-2012, 12:50 AM   #4
amc49
Fan#: 96610
Points 3,267, Level 35
Points: 3,267, Level: 35 Points: 3,267, Level: 35 Points: 3,267, Level: 35
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 7%
I have two Focus cars, one does this sometimes and the other one never. I've pulled tanks to work on pumps and know for sure nothing wrong with hoses.
All I know is that the one with the issue fills fine if I twist the gas nozzle about 120 degrees to back of car where it is getting close to straight up, it then fills fine and every time, go figure.
In my case I'm pretty sure it has something to do with fuel/vapor stacking up right there where it's being discharged from hose to trip the gas hose shutoff. Once you angle the flow to sluice smoothly down the inside of pipe then the area stays clean enough of vapor to not trip.
Try filling at different angles from what you normally use by swinging gas hose around to different positions, that's how I found my sweet spot.
amc49 is offline
Old 12-01-2012, 10:18 PM   #5
ryan1428
Fan#: 58574
It happens at every gas station...all the time. Stupid question, what is an EVAP system? How do I check it. I understand the vapor build up problem. What if I drill another hole in the re-stricter plate? I know, sound extreme. But sounds like it may help. I thought the re-stricter plate was just so you could not put a Diesel or Leaded nozzle (old school) in it.
ryan1428 is offline
Old 12-02-2012, 06:52 AM   #6
markwb
markwb's Avatar
Fan#: 105077
What I Drive: Ford Focus ZXW 2006
Points 298, Level 5
Points: 298, Level: 5 Points: 298, Level: 5 Points: 298, Level: 5
Level Up 96% Completed
FF Reputation: 1 markwb Good Standing Member
EVAP system basically keeps fuel vapors in containment, preventing from going into the atmosphere. There is a routine run randomly by the PCM or ECU that checks the integrity of the EVAP system by pulling vacuum on the system. If you do not have any EVAP system DTC's present, then in theory you haven't a problem with EVAP.
Mark
2003 Pontiac Bonneville SSEi
IBEW Local 261
"My Other Vehicle is a Nuclear Submarine"
markwb is offline
Old 12-02-2012, 10:34 AM   #7
gopromiller
Fan#: 106819
What I Drive: 2005 red zx3
FF Reputation: 1 gopromiller Good Standing Member
you do not have any EVAP system DTC's present, then in theory you haven't a problem with EVAP.i agree it,
gopromiller is offline
Old 12-02-2012, 11:36 AM   #8
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 5%
Eh, it might be as simple as the fuel filler hoses twisting a little. I personally don't floor the gas pump when filling up. Logically, any mechanical device will have a sweet spot, and the greatest variations will be at either end of it's range. I keep the pump in the center of it's range. It doesn't take that much longer to fill. Yeah, I know, supposedly your state's weights and measures dept has verified that the pump is putting out what it reads. However, I have put 22 gallons in an 18 gallon tank that was showing 1/4 left while on a road trip, so I have lost faith in the system.
Be eclectic.
