#1 | ||||
License Plate light
Is there an inline linkable fuse to the license plate. I just purchased my 01 Focus SE and found water in the passenger side light case. I replaced the lights (drained the water) and checked fuses in the fuse box and still no license plate light. Any help would be appreciated.
Remove Advertisements |
Fan#: 1
#2 | ||||
My guess is that the electrical contacts are all corroded from being wet.
EAP with 1/3 of the cold weather package. No block heater or TCS. |
#4 | ||||
DTC P0606
No. Corrosion in that circuit is common due to the reason you describe.
Both left and right lights share a common ground. The black wire from both lights meet at a splice and are grounded by a single lead within the tailgate. Check that ground. Also check you are seeing 12V at the orange and black wire (with the side lights on). It's a common feed also; left (driver's side) light main power wire feeds right (passenger's side) light via a short secondary orange/black wire.. |
#5 | ||||
DTC P0606
#7 | ||||
DTC P0606
#8 | ||||
Yeah i found the problem. the wires were old and split at the back hatch seal. I had to rewire that whole pigtail... thnx tho for the help.
| Thread Tools | |
| Display Modes | |
