Heated Seat Install How-To - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 02-11-2014, 08:01 PM   #41
shawn22
Fan#: 113328
What I Drive: 2012 focus T
FF Reputation: 1 shawn22 Good Standing Member
Hey guys, this definitely seems to be the go to thread for heated seats on the '12 focus.
I'm trying to do an oem install, so I pried up the existing cup holder hoping to find some extra connectors, but no luck. Just one wire for the 12 volt outlet.
Anyone know if there are wires here to tap into? Will I need to buy the leads for the new switches?
shawn22 is offline
Old 02-12-2014, 01:30 PM   #42
shawn22
Fan#: 113328
By the way, here's a pic of the new cup holder/seat heater switches... Looks like a couple of 4 pin connectors.
Rockauto has the connectors, and I am guessing these would work... http://www.rockauto.com/catalog/x,ca...%2B2012%2BFORD
But if anyone can confirm before I buy them..? And would they run from the switches all the way to the passenger compartment fuse panel, specifically fuse 85?
I've never done any automotive wiring before; learning as I go.
shawn22 is offline
Old 02-12-2014, 05:54 PM   #43
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 6,498, Level 52
Points: 6,498, Level: 52 Points: 6,498, Level: 52 Points: 6,498, Level: 52
Level Up 74% Completed
Forum Activity 4%
FF Reputation: 9 SilverPony2001 Good Standing Member
If they are like 80% of the other electronics in the car, they could be controlled by the BCM. You could buy all the factory components, wire them up properly, and they still wouldn't work. A lot of people trying to add fog lights found that out the hard way.
Let us know how it goes though, I have that factory switch piece as well and was going to dive into it this summer. If all else fails you could dremel out the factory switches to mount the aftermarket ones and it would look "almost" factory.
EDIT: This whole thread might be of interest to you, it's from another forum. But I'll link to one post. Someone with an ST verified that the wiring under the seat is there, and hot. Not sure if it's the same case with a S or SE.
http://www.focusst.org/forum/focus-s...html#post20959
SilverPony2001 is offline
Old 02-12-2014, 09:49 PM   #44
shawn22
Fan#: 113328
Interesting. I'll have to look into the BCM, and your right, worst case, use aftermarket in place of factory switches.
So the thread you linked has a picture specifying the pins for the heated seats (for the ST). I'm not sure how he confirmed that, as in our manual, it says fuse 85 is heated seats, as well as the "passenger airbag deactivation indicator" (PADI), and some other things. I don't want to screw up the occupancy detection sensor.
And that electrical connector their showing is the one under the seat, not under the cupholder... I wonder does the power run from the fuse panel to the switches, and then to the seat connectors and pads? Or does it go from the fuse to the seat connectors and pads, with a separate wire back to the switch.?
shawn22 is offline
Old 02-12-2014, 10:13 PM   #45
shawn22
Fan#: 113328
Btw, here's the other end of the seat connectors they show in the other post. And the factory heat pad.
So factory heat pad is using two connectors, one green and one blue.
It would be nice to see how someone that has factory installed heated seats' connectors line up...
shawn22 is offline
Old 03-10-2014, 08:59 AM   #46
bproctor
Fan#: 140178
What I Drive: 2014 Ingot Silver Focus SE
FF Reputation: 1 bproctor Good Standing Member
I just installed heated seats yesterday and everything seemed to go well. I seem to be having a problem with the luggage compartment fuse panel. When the seats didnt power on I went back to double check the fuses and they were good. I then put a multimeter on the fuse panel and never could get a reading. Anyone have any ideas?
bproctor is offline
Old 03-10-2014, 10:04 AM   #47
bproctor
Fan#: 140178
Ok I feel stupid, I used one of the add a fuse adapters and didnt realize that I had to put two fuses in it for it to work. I still dont understand why i didn't get a reading on the multimeter though.
bproctor is offline
Old 12-14-2014, 11:29 AM   #48
Rsaxon
Fan#: 208177
Points 1, Level 1
Points: 1, Level: 1 Points: 1, Level: 1 Points: 1, Level: 1
Level Up 0% Completed
FF Reputation: 1 Rsaxon Good Standing Member
are the connectors on the st leather seats same as ford focus zetec s 2012
Rsaxon is offline
Old 01-06-2015, 02:53 AM   #49
Focus 13
Focus 13's Avatar
Fan#: 208417
What I Drive: 2014 Gun Metal Grey Sedan SE
Points 2,778, Level 32
Points: 2,778, Level: 32 Points: 2,778, Level: 32 Points: 2,778, Level: 32
Level Up 19% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
FF Reputation: 2 Focus 13 Good Standing Member
Can you feel any difference in the seat? Like can you feel the pad at all?
MK3 Sedan - FSWerks CAI, Rear Strut Bar, X-Drilled-Slotted Rotors, LED/Projectors all around, 3D Carbon Rear Skirt & Painted Skirts, Billet Grille, Painted Fog Bezels & Logos. MK3 Hatch - LED/Projectors all around,3D Carbon Rear Skirt, Painted Skirts
Focus 13 is offline
