Heated Seat Install How-To - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 09-29-2013, 03:21 PM   #31
SulavT
Fan#: 93904
What I Drive: 2012 Oxford White Sedan SE
FF Reputation: 1 SulavT Good Standing Member
So I think I'm going to try this myself but can somebody elaborate a little bit more on this part right here.
"With you spool of wire, cut two lengths. Start at the fuse box, run it along the door sill trim, and into the driver's side seat area. Do the same for the passenger side, cutting across the driver's side area, through the gap on the bottom of the center console.
Strip the end of each wire. Pull the 15A fuses, shove one end of the wires into one of the slots where the blades from the fuse would go. Then reinsert the fuse, holding it in place.
Tuck the wires under the sill plates."
SulavT is offline
Old 10-07-2013, 11:01 PM   #32
SulavT
Fan#: 93904
Originally Posted by mrpeaches View Post
If anyone is planning on doing this, please take the safe route and use something like this Add-A-Fuse from Amazon when you tap into the fusebox for power.
Other than that, nice write up!
Originally Posted by merkidemis View Post
Absolutely, sorry I missed that step. Tapping the fuses in this manner does NOT get you any circuit protection.
Peaches the link you provided.. is this it?
http://www.autozone.com/autozone/acc...entifier=32416
It only says 10Amp, aren't the heated seats 15A? Will this work?
SulavT is offline
Old 02-08-2014, 09:35 AM   #33
mlheck
Fan#: 140617
What I Drive: 2012 Focus SEL
FF Reputation: 1 mlheck Good Standing Member
I plan on doing this mod to my daughters car with she comes home from school for break. So I need to gather a little more information. Are the fuses that you connected to constant on or switched? If they are constant on, does anybody know where I can tap into a switched source to run a relay? I prefer to have the power cut to the seat heaters with the car is shut off.
Thanks
mlheck is offline
Old 02-08-2014, 11:41 AM   #34
rexazz2
rexazz2's Avatar
Fan#: 121761
What I Drive: 2014 HB SE
Points 1,763, Level 24
Points: 1,763, Level: 24 Points: 1,763, Level: 24 Points: 1,763, Level: 24
Level Up 63% Completed
Forum Activity 3%
FF Reputation: 1 rexazz2 Good Standing Member
Thanks
for sure you want to use a relay and switched power otherwise she will end up with a dead battery at some point
rexazz2 is offline
Old 02-08-2014, 12:27 PM   #35
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,550, Level 75
Points: 13,550, Level: 75 Points: 13,550, Level: 75 Points: 13,550, Level: 75
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (17)
I have installed 2 of these kits in my 04 and my sisters 07, Now in those cars the seat heater fuse is a switched circuit.
The kits come with relays already in-line, no need to install ones on your own.
SkyPilot is online now
Old 02-08-2014, 09:50 PM   #36
mlheck
Fan#: 140617
I forgot to mention that it is a 2012 sedan. You are correct that a relay comes with the kit. Just need to know where to find a switched source if the heated seat fuses are not.
mlheck is offline
Old 02-09-2014, 06:42 PM   #37
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Forum Activity 5%
they should be switched in the 2012, rear fuse panel
Old 02-09-2014, 06:50 PM   #38
mlheck
Fan#: 140617
Excuse my ignorance but where is the location of this rear fuse box?
mlheck is offline
Old 02-09-2014, 07:34 PM   #39
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Forum Activity 5%
http://www.fordservicecontent.com/Fo.../12focog5e.pdf
Pg 302-303
Fuses F34 and F35
Old 02-09-2014, 08:49 PM   #40
mlheck
Fan#: 140617
Thank You
mlheck is offline
