Why would a Slave cylinder keep going bad? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-14-2012, 10:36 PM   #1
GoNFanatic
Fan#: 106054
What I Drive: 2002 charcoal grey svt
FF Reputation: 1 GoNFanatic Good Standing Member
What are the potential causes of a slave cylinder going bad 3 times in 2 months?
GoNFanatic is offline
Old 11-14-2012, 11:00 PM   #2
Ford Fanatic
Fan#: 104637
What I Drive: '03 SVTF 5 door & built '03 mustang
FF Reputation: 1 Ford Fanatic Good Standing Member
i bet all your slave cylinders are fine.. even the stock one. check your clutch fork :)
good luck!
2003 Mustang GT - 13.1 1/4 N/A auto
2003 SVTF 5 door- stock (for now) daily driver
Ford Fanatic is offline
Old 11-14-2012, 11:34 PM   #3
Mike_Mac
Mike_Mac's Avatar
Fan#: 61110
What I Drive: 04 Red/Black ZX5, 14 SE hatch
Points 2,392, Level 29
Points: 2,392, Level: 29 Points: 2,392, Level: 29 Points: 2,392, Level: 29
Level Up 62% Completed
FF Reputation: 12 Mike_Mac Great Standing Member
Buy-Sell-Trade Rating: (8)
our cars don't have a clutch fork.
did the same thing fail on them each time?
could only imagine dropping the trans 3 times in 2 months.
if its the same pressure plate some of the fingers may be damaged causing uneven pressure on the throwout bearing and slave cylinder
Mike_Mac is offline
Old 11-15-2012, 01:20 AM   #4
fakitol
Fan#: 63209
What I Drive: 04svt 02svt
Points 747, Level 14
Points: 747, Level: 14 Points: 747, Level: 14 Points: 747, Level: 14
Level Up 47% Completed
Forum Activity 3%
FF Reputation: 1 fakitol Good Standing Member
Buy-Sell-Trade Rating: (11)
Just an info, when I put brand new master cyl my slave went bad after awhile. GL
fakitol is offline
Old 11-15-2012, 01:26 AM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,521, Level 100
Points: 140,521, Level: 100 Points: 140,521, Level: 100 Points: 140,521, Level: 100
Level Up 0% Completed
Forum Activity 55%
FF Reputation: 50 sleepyboy Excellent Standing Member
Welcome to the Forum
If 3 in a row are going bad then I would start looking at the other clutch parts such as the pressure plate and clutch. Also check out the Master Cylinder at the pedal for leaks or anything of that nature. Also are you sure your using the correct part for the SVT? The MTX-75 slave cylinder can also fit the getrag but the hole for the shaft is too big. They look identical to each other only difference the hole diameter. If you put one on a SVT it will leak fluid, I know cause...
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
