Dented Piston - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-14-2012, 08:50 PM   #1
mysonsfocus
Fan#: 106048
What I Drive: 2000 Black LX Automatic
FF Reputation: 1 mysonsfocus Good Standing Member
Dented Piston
Just got the head off and guess what, ate the #4 intake valve seat which has dented the piston in #1 and #4 cylinder. The cylinder walls are undamaged, DO I HAVE TO REPLACE THE PISTONS???
mysonsfocus is offline
Old 11-14-2012, 09:22 PM   #2
DerbyDave
DerbyDave's Avatar
Fan#: 103584
What I Drive: 2002 Silver ZX5
FF Reputation: 1 DerbyDave Good Standing Member
as long as the damage is limited to just a dent and the piston dosen't have a hole in it then you shouldn't have to replace it.
2002 Ford Focus ZX5 2.0 Zetec MTX
2003 Ford Escape 3.0 Duratec
DerbyDave is offline
Old 11-14-2012, 09:27 PM   #3
mysonsfocus
Fan#: 106048
Maybe I understated the amount of denting...the valve seat bounced around and made the top look like a rocky river bottom...It is not leaking oil by the rings, but it looks pretty dented over entire top
Old 11-14-2012, 10:18 PM   #4
amc49
Fan#: 96610
Points 3,381, Level 36
Points: 3,381, Level: 36 Points: 3,381, Level: 36 Points: 3,381, Level: 36
Level Up 21% Completed
Forum Activity 55%
Can you provide a pic? Usually that much means you gotta change it, absolutely if any denting is within 1/4 inch of piston edge. There the denting fractures through to let ring land come loose as soon as engine runs, you'd be repairing it for nothing. Cast pistons pretty much crack under dents unless the dent is very shallow because they are brittle. Multiple dents close to each other are always cracked underneath the dents.
amc49 is offline
Old 11-14-2012, 10:22 PM   #5
mysonsfocus
Fan#: 106048
Thanks, the denting is right up to the edge all the way around, sounds like a set of pistons is on the order list. Any thoughts on removing the engine and leaving the auto trans in???
