"Computer" location? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-14-2012, 05:05 PM   #1
Copedawg
Fan#: 105970
What I Drive: ford
FF Reputation: 1 Copedawg Good Standing Member
Howdy All! I have an 02 Focus as well as an 02 donor Focus. Can someone tell me where the PCM/ECM (or whatever you all call the computer) is located? I would like to pull it and send it out to get "re done". Also, can you all recommend a place to send it to and what is the ball park price for that? Or would you all recommend a tune? or what?
Thanks!
Ian
EDIT: Also, what else would you all recommend snagging from the donor before it is gone?
Thanks!
Copedawg is offline
Old 11-14-2012, 06:07 PM   #2
Mike_Mac
Mike_Mac's Avatar
Fan#: 61110
What I Drive: 04 Red/Black ZX5, 00 infared ZTS
Points 2,383, Level 29
Points: 2,383, Level: 29 Points: 2,383, Level: 29 Points: 2,383, Level: 29
Level Up 56% Completed
FF Reputation: 12 Mike_Mac Great Standing Member
Buy-Sell-Trade Rating: (8)
its above the passangers kick panel. pull the glove box out and you should see the ECU with the GEM mounted on top of it.
as far as getting it re-done. idk what you mean by that like have the pcb replaced?
if it works just tune it.
just remember ECU has to match the keys or you get a no start
Mike_Mac is offline
Old 11-14-2012, 06:59 PM   #3
Copedawg
Fan#: 105970
What I Drive: ford
OH!!!!! The ECM goes with the key and visa versa....Thanks! VERY GOOD TO KNOW! Thanks Mike!
I spose we'll tune it. We changed the doors so maybe we will swap the ECU and the ignition cylinder so the keys match.
Thanks for the info. What kind of mods do you all do to these things? Is there a "what to do first" thread as far as mods go?
Thanks!
Copedawg is offline
Old 11-14-2012, 09:46 PM   #4
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,848, Level 100
Points: 51,848, Level: 100 Points: 51,848, Level: 100 Points: 51,848, Level: 100
Level Up 0% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
Swapping the ECU isnt as easy as getting the keys and ECU you have to change the ECU back to the strategy that was in the car as many things changed over the years , each Focus has a ECU code and only that code can go back in it , there is no performance gains from swapping out the ECU anyway
If you would like a tune I can help with that
Mods that work well is
SVT Header
TB
2.5 exh
Intake
cams
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 11-14-2012, 10:11 PM   #5
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 35,504, Level 100
Points: 35,504, Level: 100 Points: 35,504, Level: 100 Points: 35,504, Level: 100
Forum Activity 6%
Yep it is located directly behind the glovebox in the big open spot you see here, where the two hole are in the sheet metal. I swapped mine out when I did a engine swap. But you need to remove the kick panel and such to get easier access.
Sent from FBI surveillance van 2
TheGlassMaker is online now
Old 11-15-2012, 09:57 AM   #6
Copedawg
Fan#: 105970
What I Drive: ford
This is a great forum!
The Vehicles are very similar (options-none) and the VIN#'s are just 32 off even though there is a 5 month gap on the dates. You think we could change the ECU's, so the key will work? If no, then how could we make it work?
Copedawg is offline
Old 11-15-2012, 10:57 AM   #7
TheGlassMaker
REVOLT.BUILD.RISE
Fan#: 69510
Forum Activity 6%
In my case I changed engine, harness and ecu. But I kept the keys from the last set up. I had to take the car to a ford dealer to have the keys reprogrammed to read the new computer. Or in other word have the PATS system reprogrammed.
