Sponsored by Tire Rack
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Wheels & Tires - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, offset, wheel patterns and more.
Sponsored By:
Tire Rack
Old 11-14-2012, 12:13 PM   #1
swagfocuswagon
swagfocuswagon's Avatar
Fan#: 103591
What I Drive: '00 Focus wagon, 96 Cutlass Supreme
FF Reputation: 1 swagfocuswagon Good Standing Member
How do I remove rear drums
Hey guys!
Welps I blew a wheel cylinder this morning (fluid comming out of the drum) and those stupid drums have the wheel bearing pressed in. So, how would I go about removing the drum? And what would the chance of re-using the drum/wheel bearing be? Im gonna redo the brakes eventually but due to lack of money Im kinda stuck.
Thanks!
Patrick.
swagfocuswagon is offline
Old 11-14-2012, 01:26 PM   #2
AllCarFan
Fan#: 102583
What I Drive: 2005 Saleen Sonic Blue S121
FF Reputation: 2 AllCarFan Good Standing Member
you are talking about the actual drum? I cant remember what size nut holds it on, but your local auto parts store carries a wheel nut socket. After that, it the drum several times with a deadblow hammer and work it off with a large flat head screw driver. Its not easy. That will expose the shoes and what not. I am trying to go by memory.
AllCarFan is offline
Old 11-14-2012, 01:38 PM   #3
swagfocuswagon
Fan#: 103591
I see. Well thanks AllCarFan. Ill go out there and pull them drums off lol
Old 11-14-2012, 02:09 PM   #4
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing MemberGeezer Excellent Standing Member
There's two ways of doing it. Your can remove the large nut (30mm?) from the center of the drum and pull the drum off or you can remove the four smaller nuts on the back side of the backing plate (a couple are more difficult to get at than others due to the location of some suspension components (this way removes the drum and spindle) in one piece. Note that the center nut is torqued to over 170 ft lbs so have a big bar or heavy duty impact gun to do it. Secondly the nut itself should only be removed/re-installed a maximum of two cycles as it loses it's ability to stay tight.
Geezer is offline
Old 11-15-2012, 08:21 AM   #5
swagfocuswagon
Fan#: 103591
Okay Thanks Geezer! If thats the case then Ill probably look into getting new nuts for the drums.
Old 11-15-2012, 07:50 PM   #6
swagfocuswagon
Fan#: 103591
Oh my gosh you shoulda seen the wheel bearing grease inside that brake assembally. Holy Crap. Hey, when I go to put in the new drums, what grease should I use?
