Fanatics: Texas Regional discussion Forum for planning events and sharing information with all Members in the Texas (Lonestar) areas.
#11 | ||||
FF PHOTOG ENTHUSIAST
I also recommend you don't touch your ECU. It takes a couple of days after an ECU touch before you can go to an inspection computer.
Those computers will tell the tech that you have tampered with the ECU with in a couple of days. I know, I did it once. -Ray-
22ST FF PHOTO CONTEST HAS BEGUN CLICK HERE TO JOIN IN TO THE PHOTO FUN. ALL ARE WELCOME. Hatch Nation Member: #147 TeamFocalize Head Honcho R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
#13 | ||||
argh help ugrgently needed please water leak
i have a water leak from the front of my engine the 2 larger pipes what they go onto seems to be gushing with water from the rear of it any suggestions please this item is just under altnator would haelf if i had a diagram to work of
#14 | ||||
#16 | ||||
FF's Night Security
Huh, it takes a couple to few drive cycles not days. You just needed to drive more. Quote:
Sounds like a water pump housing leak or something, I suggest you make your own thread instead of hijacking someone's thread that doesn't even pertain to what's going on with your car..
I started out with nothing and I still have most of it left Hatch Nation #15 (Ole' Yeller') & #150 (The SVT) Moderator for Technical Chat Zetec Performance Chat Southern Fanatics Chat |
#17 | ||||
#18 | ||||
True ... I haven't really done a good drive in a while.
-Ray-
#19 | ||||
Blue Oval Fanatics - Join The Fun Reference Links: -Forum Rules -Buy-Sell-Trade Rules -FAQ's & How-To Information Archive -Signature Guidelines -How-To List -Member Gallery -ROTM Showcase & Voting Center -FocusFest "The Fest" Information -Focus Fanatics Facebook -Focus Fanatics Twitter
#20 | ||||
when the computer is reset (either by disconnecting the battery or by clearing the codes with a scan tool), there are 6-9 monitors that need to be reset. 4 of them (iirc) cycle almost immediately on the first startup. The others, O2 sensors, Evap, egr, need to go through drive cycles. you are allowed to have only ONE not ready, 2 or more and you fail inspection. in the OP's case, he will fail, because the O2 sensor will come "ready" before the evap (evap is 95% of the time the last to come ready) and cause the CEL to come on. Either get an O2 cheater or a tune to eliminate that.
8 Foci. Yes, I have issues. Next question. |
| Thread Tools | |
| Display Modes | |
