Rear Lower Control Arm Bolt Stuck and Broken - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-14-2012, 08:36 AM   #1
gondorian
gondorian's Avatar
Fan#: 105695
What I Drive: 2002 wgn (Selling) 2004 2.3 wgn 5sp
Points 1,547, Level 22
Points: 1,547, Level: 22 Points: 1,547, Level: 22 Points: 1,547, Level: 22
Level Up 47% Completed
FF Reputation: 7 gondorian Good Standing Member
So I was trying to do an alignment with my friend at his shop and when we were trying to loosen the bolt it broke off with the nut . I tried to loosen it and to punch it out but nothing worked. I'm wondering if I could just use an acetylene torch to cut it out but it seems rather close to the fuel tank. Have any of you had this happen before and what did you do to fix it? Here is a picture: Thanks
gondorian is offline
Old 11-14-2012, 08:54 AM   #2
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,584, Level 37
Points: 3,584, Level: 37 Points: 3,584, Level: 37 Points: 3,584, Level: 37
Level Up 56% Completed
FF Reputation: 23 wrc_fan Great Standing Member
The opposite end of that control arm is usually the one siezed in place. That is one reason to be glad I'm not in Michigan any more. Lots of rust underneath there...
Maybe try an air hammer to punch it out? Here's the general problem with this design, and you'll see it if you search. The bolt shank becomes one with the inner shank of the bushing. So you can't get the bolt out, and the bushing is still working, so it absorbs your attempts to pound the bolt out.
And, if you do get the bolt out, but damage the bushing, you'll be even worse off trying to get the outter one to remove the whole control arm.
My advice, though its probably not what you want to hear, would be to pick up two new rear control arms, hardware, and swaybar end links, then go to town with a cut off wheel.
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 11-14-2012, 08:59 AM   #3
gondorian
gondorian's Avatar
Fan#: 105695
Could I just cut through the old bushing and the press in a new one after I get the old bolt out? Or is it too soft to press in a new bushing correctly?
Old 11-14-2012, 09:25 AM   #4
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
You could, but there is not (that I'm aware of) an aftermarket OEM style bushing for the car. Ford and the 3rd party suppliers only sell arms. Maybe I'm wrong here?
There are aftermarket performance bushings available. I think it would be easiest to remove the arm from the car to install. Also, I cannot advocate doing just one side of the car, it would make the handling pretty wonky, maybe unsafe. Both are my opinions, YMMV.
Parking Lot Hero
wrc_fan is offline
Old 11-14-2012, 09:39 AM   #5
BigRed03
( o Y o )
BigRed03's Avatar
Fan#: 32177
What I Drive: 2003 CD Silver ZX5 SVT
FF Reputation: 9 BigRed03 Good Standing Member
Buy-Sell-Trade Rating: (4)
Thats the cam bolt/bushing for the rear alignment. Pretty sure Steve at Toulsey can get these. If not, its honestly easiest to just replace the whole arm and bolts. Bolts through bushings will need to be cut out.
snow/salt, FL rules for that. Also, no emissions!
BigRed03 is offline
Old 11-14-2012, 09:56 AM   #6
gondorian
gondorian's Avatar
Fan#: 105695
I'm doing both sides of course. I just trying to figure out the best course of action before I start. I don't want to drive around with the broken bolt and I can't leave my car at work or in my friend's shop, which are the two places I have enough tools for this sort of operation.
This all started because I was experiencing some rear hop, and I figured an alignment should help. Right now my plan is to replace both bolts and bushings and get it aligned, then do the whole rear suspension next summer once I get the funds. I'm also getting sick of rust so I may take a wire bush to most of these parts while I'm at it and put rustoleum or bedliner on them.
Old 11-15-2012, 10:25 AM   #7
gondorian
gondorian's Avatar
Fan#: 105695
So y'all are right. I went to the local ford dealer to order the bolts and see if they sell the bushings. They don't sell the bushings, only the whole control arm. I decided I'd look for a bushing before I got a whole new arm, but after finding some on rockauto I had to measure the bushing to see what size it is. When I was measuring I noticed that there is a groove that holds the bushing. Getting the old one out wouldn't be too much of a problem, but pressing a new one in would be pretty impossible without something breaking in the process (probably the bushing.
Now I've decided to do the smart thing as wrc_fan suggested and get two new arms. While I'm down there I'm wondering if you think I should replace the coil springs, which look rather worn, or if there is anything else that would probably need to be replaced after a couple hundred thousand miles. Here are some pictures:
Driver's side
Passenger side:
Thanks a lot y'all, this forum is proving to be very helpful :)
Old 11-15-2012, 11:15 AM   #8
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
At that kind of mileage, I would do the dampers too. Remember, the wagon dampers are different than all other foci.
The alignment probably won't help your rear end hop. This is more likely a symptom of blown dampers (lack of control of wheel motion), or sway bar binding (additional uneven spring rate).
Parking Lot Hero
wrc_fan is offline
Old 11-15-2012, 12:21 PM   #9
BigRed03
( o Y o )
BigRed03's Avatar
Fan#: 32177
^this. and order all parts through steve at toulsey ford. 10% over stocking fee for OEM parts. you'll thank yourself.
BigRed03 is offline
Old 11-15-2012, 04:22 PM   #10
Missourileo
Captain Retard
Missourileo's Avatar
Fan#: 55980
What I Drive: 2002 Black SVT ZX3,93 SVT Lightning
Points 5,291, Level 46
Points: 5,291, Level: 46 Points: 5,291, Level: 46 Points: 5,291, Level: 46
Level Up 71% Completed
Level up: 71% Level up: 71% Level up: 71%
FF Reputation: 20 Missourileo Great Standing Member
Buy-Sell-Trade Rating: (17)
Here's is some advice from experience. Sawzall and a bunch of good blades. Get new control arms and bolts, then enjoy a few cold beers.
"It's the Veteran who salutes the flag, serves beneath the flag, and whose coffin is draped by the flag."
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Missourileo is offline
