Noise and vibration - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-13-2012, 05:26 PM   #1
jtpilot1
Fan#: 73773
What I Drive: 2002 focus se
Points 104, Level 2
Points: 104, Level: 2 Points: 104, Level: 2 Points: 104, Level: 2
Level Up 8% Completed
FF Reputation: 1 jtpilot1 Good Standing Member
Noise and vibration
2002 focus SE
With engine at idle there is a really profone vibration you can feel both in the steering wheel and the seat of your pants.
There maybe more then one thing going on here, there is also a mild clacking noise from the valve cover area. But not enough to say it is a rocker arm.
I have checked the motor mounts and they seem to be good. Not much movement of the engine.
There is no check engine light and seems to run ok other then the vibration.
Any Ideas would be greatly appreciated.
jtpilot1 is offline
Old 11-13-2012, 07:32 PM   #2
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,314, Level 77
Points: 14,314, Level: 77 Points: 14,314, Level: 77 Points: 14,314, Level: 77
Level Up 66% Completed
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
FF Reputation: 15 Elizabeth Great Standing Member
Motor mount. The only thing it can be...
The rubber inside the metal is gone worn.. so metal to metal contact.
Elizabeth is online now
Old 11-14-2012, 04:09 PM   #3
jtpilot1
Fan#: 73773
Points 104, Level 2
Thanks, that was it. I did not realize the upper mount was fluid filled. Mine was empty.
jtpilot1 is offline
