2001 ZX3 wiring diagram - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-13-2012, 03:33 PM   #1
JYL007
Fan#: 105982
What I Drive: 2001 Ford Focus ZX3
FF Reputation: 1 JYL007 Good Standing Member
I was looking for the wiring diagram of a 2001 Ford Focus ZX3. I am having trouble diagnosing a problem with my vehicle and would like to find the wiring diagram for it.
Readiness codes reset every time the vehicle is turned off. I need to know what wire is giving power to the PCM memory while the vehicle is turned off. Since right now it is losing its memory when the key is off.
B+ that is NOT controlled by the ignition or relay is what I believe is the failure. I do not want to replace the PCM without confirming this wiring to be good. Any help with finding PCM wiring diagrams would be great!!! I have tried Alldata and other online resources, they are all weak and incomplete. I believe Ford's schematics is the only way.
Thanks!
JYL007 is offline
Old 11-13-2012, 05:18 PM   #2
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,146, Level 74
Points: 13,146, Level: 74 Points: 13,146, Level: 74 Points: 13,146, Level: 74
Level Up 74% Completed
Forum Activity 30%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Moved to "General Technical Chat". I don't have the diagram myself but you can easily find one in a manual that you buy at an auto parts store. I have checked online but you have to be specific as to which wiring diagram that you need. If you are looking for a wiring harness that goes to the fuel injectors and other underhood electronics I have one that I some how received and haven't been able to get rid of it lol. It is for a 2000-2001 Zetec Focus. If that's what you need I can give it to you, all you would have to do is pay for shipping.
zetecDon is offline
Old 11-13-2012, 07:37 PM   #3
drewts86
Fan#: 72974
What I Drive: 2004 Burgundy ZX3
Points 530, Level 10
Points: 530, Level: 10 Points: 530, Level: 10 Points: 530, Level: 10
Level Up 60% Completed
FF Reputation: 1 drewts86 Good Standing Member
Let me know which diagram you are looking for. I can scan it and e-mail it to you.
drewts86 is offline
Old 11-14-2012, 08:55 AM   #4
JYL007
Fan#: 105982
The ECM wiring diagram is what I seek.
JYL007 is offline
Old 11-14-2012, 10:58 PM   #5
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Level Up 52% Completed
The battery is the only source of 12V power to the PCM with the ignition off - fuse 20 (10A).
Red wire from battery (always hot) to Battery Junction Box (BJB) and fuse 20 to PCM pin 55.
IMO, you should start by checking the battery connections for tightness and cleanliness and reseat the fuse. There is unlikely to be anything wrong with the wiring harness or PCM.
BC_ZX3 is offline
Old 11-19-2012, 02:37 PM   #6
drewts86
Fan#: 72974
Sorry I've been super busy at work with Thanksgiving holiday coming up. I'll try tomorrow evening to get the wiring diagram scanned and sent to you.
drewts86 is offline
Old 08-26-2014, 09:56 PM   #7
chuckdw
Fan#: 185761
What I Drive: 2002 white, ZX3
FF Reputation: 1 chuckdw Good Standing Member
Would you please email me a wiring diagram of the cooling system? My resistor is good. Seems to be a temp sensor that provides ground for the engine fan for high speed only. Thank you. ps , I've spent hours checking . A diagram probly help a lot!
chuckdw is offline
Old 08-26-2014, 10:14 PM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,334, Level 75
Points: 13,334, Level: 75 Points: 13,334, Level: 75 Points: 13,334, Level: 75
Level Up 21% Completed
Forum Activity 99%
Welcome
First post, eh? Asking in a thread 2 yrs old is a cross fingers, that person hasn't posted since May, yet might be on anytime.
Fan system doesn't work through a temp sensor grounding the fan.
Cyl. head temp sensor tells PCM the temp, PCM to low or high fan relay as needed.
Fan relay to fans for high, or fan relay to fan resistor to fans for low. (skipped fuse there, fan power to relay has to come from somewhere (grin))
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
