Thougts on NAPA water pump and Thermostat housing? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-13-2012, 08:38 AM   #1
G Ford Fan
Fan#: 80771
What I Drive: 2000 Ford Focus Wagon, SE, Silver.
FF Reputation: 0 G Ford Fan Newbie
Hey y'all.
I noticed the other day that the water pump on my 2000 Focus Ztec started leaking (I'm pretty sure it's just the pump and not the housing thankfully as I understand you have to remove the timing belt to replace/change the housing.
I also noticed that the plastic thermostat housing is leaking some too. I think it's just the gasket for the Thermostat and not the housing itself, but I figure at nearly 13 years old I should consider changing the housing anyway. I had the thermostat out 2 yrs ago to flush the cooling system.
I got prices from ford of $105 for a new water pump, $53 for the housing, 8 for the thermostat gasket and I think it was 12 for the themostat, so around the $200 range.
NAPA has a new water pump for $56, and has a housing, thermostat, gasket assembly for $61.00, so about $20 or so cheaper.
Does anyone have any experience with the NAPA parts? Also the closest ford dealer is on the other side of town for me. Should I go with them or just pony up for the FoMoCo parts?
I feel NAPA's parts are typically better than what you get at Autozone or Adance Auto. I'm leaning toward the NAPA stuff, unless someone has had experience with their parts for these applications.\
Also, any tips on changing the water pump and housing would be appreciated as well.
Thanks for any help that can be offered,
Greg
G Ford Fan is offline
Old 11-13-2012, 10:53 AM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,809, Level 73
Points: 12,809, Level: 73 Points: 12,809, Level: 73 Points: 12,809, Level: 73
Level Up 90% Completed
Forum Activity 99%
Agreed on NAPA having better stuff as a rule, though you can get surprised BOTH ways at the other stores...
Autozone had the clutch master I needed last weekend, and it was a factory exact part in their packaging! (at 1/3 the cost). Local Ford dealer had to order, so I got lucky looking elsewhere.
Since NAPA is handy for you, it's worth a look. If it looks like junk, you can always take the longer drive...
sailor is offline
Old 11-13-2012, 11:05 AM   #3
G Ford Fan
Fan#: 80771
Ok, thanks for the thoughts, I appreicate them!
I'll stop by and take a look. I thought I remebered reading here at some point other members comments that the factory thermostat housing, although plastic junk seemed superior to other brands, but I could be just imaganing things. That's why I was cautions. The pump seems like a major PITA to get out, so I only want to do that job once!
Thanks again,
Greg
Old 11-14-2012, 02:01 AM   #4
amc49
Fan#: 96610
Points 3,274, Level 35
Points: 3,274, Level: 35 Points: 3,274, Level: 35 Points: 3,274, Level: 35
Level Up 50% Completed
Forum Activity 11%
Loosen water pump pulley bolts before you remove the belt, easier.
Don't overtighten the new housing, only run bolts down until they hit solid and no more. Any more and all you do is preload the housing so it cracks early. If leaking between front stat cover and housing itself, the crush on the stat gasket is not very much, I've added a .040" thick washer suitably ground to fit same OD as stat and glued it on top of stat to add more crush without buying new cover. Still working now years later. Of course you can have no crack in cover.
amc49 is offline
Old 11-14-2012, 02:26 AM   #5
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,065, Level 34
Points: 3,065, Level: 34 Points: 3,065, Level: 34 Points: 3,065, Level: 34
Level Up 10% Completed
Forum Activity 2%
FF Reputation: 9 emsvitil Good Standing Member
I just cleaned the housing, the mating surface on the head, and put in a new gasket...
PLUS
I smeared Ultra-Black RTV into the housing groove, installed the gasket/o-ring, then smeared Ultra-Black over the gasket/o-ring and housing mating area...........
On the thermostat side I smeared some Ultra-Black RTV around the o-ring.
Let dry before adding water.
It's not leaking, and hopefully never will.........
Ed
emsvitil is offline
Old 11-14-2012, 11:13 AM   #6
G Ford Fan
Fan#: 80771
excellent, thanks so much gents!
That was my game plan, I think I'm going to hold off on the housing as I don't think it's leaking there, I think it's the T-stat cover to housing seal that's leaking and I did not put any RTV on that before when I had the T-stat out prior.
I will do so this time and see how it is.
The ater pump seems a bit challenging, but I'm going to give it a go this weekend hopefully.
It's currently "marking it's territory" HAHAHA. (not severe, a small spot each time i stop and i checked the fluid level this morning and it's still at the full mark)
I was also going to put a very thin bead of blue RTV on the water pump o-ring/seal as well, not much, enough that you can still see through it just for good measure.
I also think/agree it's HIGHLY important to let the RTV dry overnight before adding water. When I was younger I never did that and sometimes had leaks. I started allowing it to dry first a few years ago and have not had any problems.
One last thing, do you all think I should just spend the $100 and get a new ford water pump or try the $50.00 NAPA job. I'm tempted to just buy the Ford and be done with it......but if the NAPA ones are good quality and will last for ahwile, I'd rather save the $50.00. I'm just concerned with fitment, as sometimes the aftermarket stuff is just a bit off and that can cause leakage problems down the line.
Old 11-19-2012, 03:03 PM   #7
G Ford Fan
Fan#: 80771
Update, Job done......some thoughts.
I wanted to thank everyone who posted in this tread with suggestions. I very much appreciate them.
I have some thoughts on the job after having finished it this past weekend. I have been turning wrenches for over 20 yrs now, both professionally for ahile (not anymore) and on my cars and equipment.
1) this job is a PITA as far as water pump jobs go. I ended up having to remove the a/c compressor, a/c compressor bracket, motor mount and drop the motor about 3" to get the pump back in without messing up the gasket and small amount of blue RTV I put on the o-ring. I have a vehicle lift in my shop and I still ended up on the ground when I had to let the motor down with a floor jack!
2) If i had this to do over again, I'd opt for a motorcraft water pump eventhough it's twice the cost. The NAPA "new" replacement is OK and is not leaking, but the hub where the fan mounts is different and the water pump pulley fit on very tight. The pump itself also did not seem to fit the cavity in the housing as snugly as the OEM pump did. Again, it's not a HUGE difference, but I noticed it so I wanted to make mention of it.
3) my original 12 yr old pump was not leaking, but I had a gasket failure (the rubber o-ring failed). I speculate this may have had something to do with the major front end collision my grandpa had with the car when it was about 2 or so yrs old, but I could never prove that fact. Sometimes these things can take years to show up and I suspect the big jolt may have slightly hurt that gasket and it just took a long time to show up as based on the condition of the bottom of the pump, it had been leaking to some degree or another for a long time now.
Although a PITA, it's a job well worth tackling as I can see how shops would want $600.00 to do this job (parts and labor). I also flushed my cooling system while I was at it.
I did replace the gasket on the stock thermostat, but not the thermostat itself as Napa did not have one in stock and the stock one has a check valve in it, I don't think some of the aftermarket ones do. I also put a slight amount of blue RTV on the gasket for the thermostat as well, then let the car sit overnight (about 24 hrs give or take) before i put any water back into the system and ran the car.
So far so good, no leaks.
Thanks again guys.
-Greg
Old 11-19-2012, 08:51 PM   #8
amc49
Fan#: 96610
Forum Activity 11%
They MUST have the disc on back of stat on these or heater does not work, you'll find them.
amc49 is offline
Old 11-20-2012, 11:09 AM   #9
G Ford Fan
Fan#: 80771
AHHHHH, well there you go. That is why I was hesistant to change out the T-stat two years ago when I flushed the cooling system and why I didn't change it this time either.
I know it's old (original), but the car only has 45K on it and it's working perfectly so I figured I'd just stick with it.
THanks for the feedback!
-Greg
Old 11-21-2012, 10:59 PM   #10
cyfocus01
cyfocus01's Avatar
Fan#: 95790
What I Drive: 01 silver zts sedan
Points 437, Level 8
Points: 437, Level: 8 Points: 437, Level: 8 Points: 437, Level: 8
Level Up 74% Completed
FF Reputation: 1 cyfocus01 Good Standing Member
Good info here, finding it usefull.
Couple questions: ZTW, wagon with a ztec? and a gasket to t-sat?
Reason being, my 01 ZTS with ztec leaks at the bottom of the t-stat housing, right where those 3 screws are and the upper rad hose attatches. No problems with t-stat, just the leak, "leaving its mark" for a while.
My NAPA guy only could find t-sat and the o-ring for main housing. Do you recall the part number for the t-stat gasket? Or do you think I can get away with an RVT gasket?
Thanks.
cyfocus01 is offline
