I fixed my armrest for less than $5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-13-2012, 12:06 AM   #1
neamerjell
Fan#: 105215
What I Drive: Red 2007 Ford Focus SE
FF Reputation: 1 neamerjell Good Standing Member
I have a 2007 Focus SE with this type of armrest:
I leaned over to pick something up out of the passenger floorboard and *snap* the armrest was wobbling and hanging on by one end of the pivot axle.
In the image above, you can see a metal bracket on the bottom and the axle which the armrest pivots on is covered by plastic circles on either side.
This is the axle that broke:
http://www.ebay.com/itm/NEW-FORD-FOC...-/230765466196
This guy has the nerve to charge nearly $30 for it.
The plastic end snapped off. I had already decided that Home Depot had the parts I needed when I saw the metal bracket had square holes under the circular covers.
* 1-3/8"x5 1/2" long lag bolt (has the little square under the head, then threaded all the way down, not a carriage bolt which is only threaded part of the way and lacks the square part)
* 4-washers (2 for each side)
* a thin lock washer
* a jam nut (not enough thread protruding on the other side for a nylon lock nut to grab onto)
Total cost: just under $5!
The end of the bolt and the jam nut won't allow me to put the other circular cover back on, but my armrest is reattached and it ain't goin' nowhere any time soon!
I saw another thread showing how to beef up the latch on the armrest lid with a spring from a stapler. I may do that next as the latch seems loose to me. Surely I can find someplace to buy just the spring; it seems wasteful to buy and cannibalize a perfectly good stapler.
I hope this info proves useful to someone else who is also a cheapskate, er on a shoestring budget like I am.
neamerjell is offline
Old 11-13-2012, 12:10 AM   #2
Merrigan
Merrigan's Avatar
Fan#: 104581
What I Drive: 2013 Black SE Hatch
FF Reputation: 2 Merrigan Good Standing Member
Great thinking! I don't know how long I would pass on the spring. Maybe check a hard ware store and you could pick up a beefy spring for under $1.
Merrigan is offline
Old 01-01-2014, 12:03 AM   #3
redbuzz
Fan#: 94753
What I Drive: 2012,white,S model,5-speed
Points 55, Level 1
Points: 55, Level: 1 Points: 55, Level: 1 Points: 55, Level: 1
Level Up 10% Completed
FF Reputation: 1 redbuzz Good Standing Member
Armrest pivot shaft repair
I too leaned on the armrest of my '06 Focus and broke the armrest. I lived with it for awhile then finally got ambitious and took it apart. I pushed out the metal shaft, put it in the vise then drilled and tapped both ends for machine screws. I put it all back together using Loctite and appropriate sized washers under the screw heads. I re-installed the trim caps. It's solid now and works as before.
redbuzz is offline
Old 01-01-2014, 05:02 PM   #4
Leora83
Fan#: 69136
What I Drive: 2003 ZX5 chrome yellow
Points 520, Level 10
Points: 520, Level: 10 Points: 520, Level: 10 Points: 520, Level: 10
Level Up 40% Completed
Forum Activity 10%
FF Reputation: 1 Leora83 Good Standing Member
Excellent. I love hearing about fellow cheapskate...I mean, thrifty...repairs.
Leora83 is offline
Old 01-11-2014, 08:16 AM   #5
Wiplash2000V6
Fan#: 27480
What I Drive: silver ST
FF Reputation: 1 Wiplash2000V6 Good Standing Member
I just got done doing this...worked out great.. now need to find out how-to fix the latch.
Wiplash2000V6 is offline
Old 03-28-2014, 11:40 AM   #6
Johnpnt
Fan#: 151770
What I Drive: 2002 Blue lx
FF Reputation: 1 Johnpnt Good Standing Member
2002 focus armrest repair
I just fixed mine for 95 cents. Drill hole in broken side self tapping screw washer. Done in 15 minutes. Removed back plastic cap, two Philips screws removed drilled reinstalled.
Johnpnt is offline
Old 03-28-2014, 09:20 PM   #7
guy2545
guy2545's Avatar
Fan#: 53972
What I Drive: 2007 Black SES
Points 681, Level 13
Points: 681, Level: 13 Points: 681, Level: 13 Points: 681, Level: 13
Level Up 62% Completed
FF Reputation: 1 guy2545 Good Standing Member
I thought about trying to purchase this arm rest. to replace my broken arm rest. I have not done any measurement or planning, but it looks nice and just may fit.
Stephen
2007 Ford Focus -- Black SES ZX4
Steeda SRI//Focus Sport Exhaust//Eibach Pro-plus Kit
guy2545 is offline
Old 03-28-2014, 10:43 PM   #8
amc49
Fan#: 96610
Points 3,362, Level 36
Points: 3,362, Level: 36 Points: 3,362, Level: 36 Points: 3,362, Level: 36
Level Up 8% Completed
Forum Activity 39%
Activity: 39% Activity: 39% Activity: 39%
When you get inside that armrest it becomes very obvious what a piece of junk it is as supplied with the car. I modded mine long ago for probably around $5 as well and now it holds up pretty much all my weight when I lean on it hard. I cannot believe the parts pricing on parts for it, I used all steel and it will have to collapse the sides before it will fail now.
amc49 is offline
