How to: Lower hvac led mod - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus First Generation > MK1 Focus
Old 11-12-2012, 10:16 PM   #1
adrst2.3
adrst2.3's Avatar
Fan#: 80621
What I Drive: 07,red,st
FF Reputation: 4 adrst2.3 Good Standing Member
Buy-Sell-Trade Rating: (9)
ok so by now you all have seen my how to on the upper hvac but are wondering
ok so what about the lower hvac,well here you go i will explain my way of doing this conversion for the following colors that as of now i have experienced. as i go along and do other colors i will update this thread with any changes,
these instructions will be individualized by color starting with red.
i will begin with the basics and that is getting the lower hvac cluster separated
first what you must do is take a thin flat screwdriver and separate the 2 halves with your palm as you separate each section pull the 2 ends apart once you do this the underside should be alot easier.
this is how you will do it...
[IMG][/IMG]
[IMG][/IMG]
once you open up the lower hvac you will expose the board like this...
[IMG][/IMG]
at this point you will need to remove the plastic rivits that secure the board to the hvac face this is what they look like...
[IMG][/IMG]
you need a nice pair of wire cutter/strippers to remove these rivets without potentially ruining the hvac by scratching it and messing up the embedded wire traces on the board.this is how you will remove the rivits with the cutters...
[IMG][/IMG]
when your done remove the board from the face by lifting it out from the center
now that where done with the removal part its time for the led swap.
we will start with RED SMD
on the board to your right you will notice that there are 2 smds and to the left there are 4 you need to remove these once you do you will need to solder in the new red smds according to the following instruction,
the upper left red smd will be placed with the polarity side down(the flat part of the smd not the part that has a corner notched off)
the lower left smd will go with the polarity side going up.
the upper right smd that you will install next will go exactly how the upper left smd you just installed is.
the lower right smd also will go exactly how the lower left is.
once you do that cluster of four go on to the next 2 that our on the right
ok so for the top right you will install the smd with the polarity going up
and for bottom smd you will install it with the polarity side going down.
BLUE SMD LED INSTALL
UPPER LEFT SMD POLARITY SIDE UP,
LOWER LEFT SMD POLARITY SIDE DOWN
UPPER RIGHT SMD POLARITY SIDE UP
SMDS LOCATED TO THE FAR RIGHT OF LOWER HVAC IN CLUSTERS OF 2
FAR RIGHT UPPER SMD POLARITY SIDE DOWN
R RIGHT LOWER SMD POLARITY SIDE UP
WHITE SMD LED INSTALL
LOWER RIGHT SMD POLARITY SIDE DOWN
SMD'S THAT ARE LOCATED TO THE FAR RIGHT OF HVAC IN CLUSTERS OF 2
FAR UPPER RIGHT SMD POLARITY SIDE UP
FAR LOWER RIGHT SMD POLARITY SIDE UP
once you install your choice of leds all you need to do is reinstall the pcb board back on the hvac face with the gray rubber buttons and dab some hot
glue onto the rivits you popped off to secure the board back onto the face
once you do all this snap the to halves together and install in your cars
HOPE THIS HELPS WITH YOUR INSTALLS GUYS.
I didn't post up anymore pics since this conversion is fairly easy and its just annoying getting the leds to light up so this explanation should help you avoid all issues with this mod and to minimize your time going back and forth to your car to see if all the leds turn on.
enjoy!!!!!!!!!!!
adrst2.3 is online now
Old 11-13-2012, 02:24 PM   #2
adrst2.3
adrst2.3's Avatar
Fan#: 80621
anyone who reads this or my upper hvac conversion thread please let me know if it helps id love to here feedback on this besides 300 views.lol
if i get good responses ill post up more led how to's i just dont know how much interest
there is in this.
thanks
Old 02-15-2013, 12:25 AM   #3
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
FF Reputation: 4 calebstubstad Good Standing Member
very interested in this as well as the PM i sent you. wish you were closer so you could teach me your ways! i love leds way too much for my own good
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 06-22-2013, 12:22 PM   #4
wkampenhout
wkampenhout's Avatar
Fan#: 114078
What I Drive: 2007 Yellow ZX3
FF Reputation: 1 wkampenhout Good Standing Member
This is great!!! Im lucky I found this little thread. I was curious though, what kind of SMD's did you use? PLCC-2 or PLCC-4?
wkampenhout is offline
Old 06-22-2013, 12:51 PM   #5
adrst2.3
adrst2.3's Avatar
Fan#: 80621
I used plcc2 led but you can also go with 4 there a bit bigger but will be brighter
Sent from my SPH-L710 using FF Mobile
Hey! I do conversions too!
Old 06-22-2013, 12:52 PM   #6
adrst2.3
adrst2.3's Avatar
Fan#: 80621
You can also use plcc2 for all your switches just cut the led heads off and solder in the plcc's you'll need to replace all the resistors using 1/4 watt 560 ohm resistors
