Cylinder head temperature sensor wire fix. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-12-2012, 08:43 PM   #1
gondorian
gondorian's Avatar
Fan#: 105695
What I Drive: 2002 wgn (Selling) 2004 2.3 wgn 5sp
Points 1,500, Level 21
Points: 1,500, Level: 21 Points: 1,500, Level: 21 Points: 1,500, Level: 21
Level Up 50% Completed
FF Reputation: 7 gondorian Good Standing Member
So I my car started throwing a code for the cylinder head temperature sensor (2.0 zetec) and also the temp gage stopped working. When I went to replace the cht sensor I found that the wire was broken.
What I found out is that you can remove the connector from the end of the cht sensor and take it apart, strip the wires, and reinsert them back into the connector. I was very glad this worked out because I the only replacement part I could find was the whole wiring harness. The only thing is that you need to be careful about taking the plug apart so you don't break the connection pieces. In the end I got it back together and it is working fine :)
gondorian is offline
Old 11-12-2012, 09:41 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,775, Level 73
Points: 12,775, Level: 73 Points: 12,775, Level: 73 Points: 12,775, Level: 73
Level Up 82% Completed
Forum Activity 99%
Good job!
You'll find that many special plugs can be repaired/reused, there is a special tool avail. to remove connectors from the type of plastic plug they clip into.
(difficult to describe, but a common type has a one piece plug that the connectors are pushed into until they click in place from the rear after being attached to the wire. pushing the right tool into the front of the plug unlocks them for repair/replacement)
Cheers for not giving up, and figuring out how to repair that connector!
sailor is offline
Old 11-13-2012, 08:18 AM   #3
gondorian
gondorian's Avatar
Fan#: 105695
Thanks sailor! It's really a lot of fun to MacGyver a solution and spend $0.00.
Old 11-14-2012, 02:12 AM   #4
amc49
Fan#: 96610
Points 3,267, Level 35
Points: 3,267, Level: 35 Points: 3,267, Level: 35 Points: 3,267, Level: 35
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 7%
Amen brother, I do stuff like that all the time.................they make fifty different types of plug, mostly to confuse, a good close look is the tool to figure out how it goes together. Dentist pick or hobby tool helps greatly getting in the small space there.
I just looked up several common Ford connectors to buy the metal only online for like 5 cents each, bought several sizes to be able to fix connectors without buying $15-$20 connectors as so many of them are nowadays. Just revamped coil connector on mine for like $2 of parts. Rebuilt radiator fan resistor and connector for maybe $3-$4, $60 part there and not counting connector.
amc49 is offline
