#31 | ||||
Roger that! That's how we were taught and it's common sense old school. I don't understand where this rationale comes from when it comes to placing two new tires on the rear wheels of a front wheel drive car and leaving the older worn tires up front.
Mark 2003 Pontiac Bonneville SSEi IBEW Local 261 "My Other Vehicle is a Nuclear Submarine" |
| Sponsored Links | |||
Advertisement | |||
#32 | ||||
That method can be perfect enough to never need to pay for alignments as I do. I line up my own using that and other ideas. Once you are close enough to start splitting sixteenths you are there, no car on the planet cares about amounts of error smaller than that, the deflection from actually driving the car will be more. It's funny to hear all these people talk about digital numbers that bye and large mean very little in many cases.
The rear may be SUPPOSED to be narrower than the front but careful measurement can show whether that too is the case real world. Every car can vary slightly from that, you just gotta shoot the lines and see where they end up, then adjust to fit the need. |
#33 | ||||
"Elder"
markwb - AFAIK, the "rationale" came from chain store lawyers who felt that it would be hard to defend a suit claiming that the worn tires on the rear let the vehicle "skid out of control" causing an accident. From there it spread, like a (leave bleep to imagination).
This is not "logical" says Spock... Unfortunately "logic" and "legally defensible position" have little in common... |
#34 | ||||
Thank You, sailor.. :)
#35 | ||||
The thinking is still stuck in the past of RWD cars which did it easier. The logic doesn't have to make sense to a lawyer, it just has to work.
#36 | ||||
i dont believe that a very slight toe out will cause the wobble. I also want to avoid much static toe in, as putting alot in your trunk (or compressing hte springs coing around a corner) will cause a lot of toe in which IMO is worse. anyways i think we can all agree that minimal toe in in the rear is called for (between 0 and v.slight)
for auto-x: '04 Liquid Grey ZX3 for street: '02 Infrared SVT |
#37 | ||||
"Elder"
thenorm - honestly, the "wiggle" in my experience came from toe-in - so minimizing that should help. (Winter driving specific info., summer or performance driving preferences could vary)
#38 | ||||
Here's the finished deal. A shim was added to the rear left, apparently..
Bryan Berndt bryanb@bryanb.net 2002 Focus SE, auto, 2.0L SPI |
#39 | ||||
"Elder"
Hmmm...
I'm seeing a MAJOR adjustment (needed) to front toe, as well as a change in L.R. camber. The ODD thing, is that there isn't a "shim" to adjust camber on the Focus (it COULD be done, but it would be quite difficult) The normal way to make such an adjustment would be with a "camber bolt", which replaces an upper control arm bolt and can be twisted for some adjustment, then tightened in place. |
#40 | ||||
He called it a shim. I suppose I could look and see what that part looks 'new'. He charged me, like $70 for the part. Sound about right for a shop cost + markup? I plan on keeping that sheet he gave me, and going back in a few months, maybe when winter is over, and getting it checked again, and make sure its not going out of spec over time...
| Thread Tools | |
| Display Modes | |
