2012 focus front bumper cover removal - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-12-2012, 02:02 PM   #1
FocusBastard
Fan#: 103053
What I Drive: 2012 Black Focus SE Hatch, 5spd
Points 416, Level 8
Points: 416, Level: 8 Points: 416, Level: 8 Points: 416, Level: 8
Level Up 32% Completed
FF Reputation: 2 FocusBastard Good Standing Member
Thumbs up SOLVED: 2012 focus front bumper cover removal
Hi,
Anyone know how to remove the front bumper cover in a 2012 focus? I need to get to the metal bumper/crossbar.
Thanks!
FocusBastard is offline
Old 11-12-2012, 02:21 PM   #2
FocusBastard
Fan#: 103053
Points 416, Level 8
Even just an exploded parts diagram would do. Just need to know where all the fasteners are
Old 11-12-2012, 07:36 PM   #3
FocusBastard
Fan#: 103053
Points 416, Level 8
OK so I figured it out. Engineering degree's gotta be good for somethin!
Step 1:
Open hood
Remove four scrivets on plastic radiator cowl
Unscrew headlights (two torx each) and move them out of the way
Unscrew the torx screw next to the lowermost headlight screw you just removed (both sides, duh
Undo hood release cable
Unclip bumpre cover, near where the aforementioned torx screws were in the front.
2:
Lift front of car
remove the underbody fairing (like when doing an oil change)
remove front bumper spoiler (7 torx screws and a shitpile of scrivets)
in each wheel well, remove three torx screws and the single scrivet. These particular scrivets are ing bungholes, and you will most likely break them.
3
In the wheel well, where the bumper cover and fender meet, pull the bumper cover straight out, away from the car. be gentle, it should pop out easily. (both sides)
lift and pull buper cover away from car
unhook foglight connector
Done!
Hope this helps another noob. Overall, very easy to do, but a little daunting at first! The scrivets will most likely break. be careful.
The trick to remove them is find the indentation between the base and the inner section and gently lift the rim with a flat head. Then wiggle the middle section out. To put them back, insert the middle section a couple of millimeters, jam the thing in the hole and push the center section in.
Old 11-12-2012, 07:44 PM   #4
FocusBastard
Fan#: 103053
Points 416, Level 8
In case this helps, here is a low res diagram i found. Cannot wait for someone to post the service manual already!!!!
Old 11-13-2012, 11:34 AM   #5
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,366, Level 36
Points: 3,366, Level: 36 Points: 3,366, Level: 36 Points: 3,366, Level: 36
Level Up 11% Completed
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
Hi FocusBastard,
You can always purchase a copy of the service manual. They're available in both in printed and electronic formats and can be purchased here: http://www.motorcraftservice.com/vdi...op&kevin=rules
Let me know if you have any other questions or concerns; I'm always just a PM away.
Thanks!
Crystal
FORD SERVICE
p: 800.392.FORD
FordService is online now
