suspension problems???? i dont know - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-12-2012, 01:35 PM   #1
sam fisher
I hate dents!
sam fisher's Avatar
Fan#: 103137
What I Drive: 2006 silver zx4 ses
Points 4,176, Level 41
Points: 4,176, Level: 41 Points: 4,176, Level: 41 Points: 4,176, Level: 41
Level Up 13% Completed
FF Reputation: 3 sam fisher Good Standing Member
ok so iv seen other talk about a problem not unlike what i recently started experiencing , and would like some opinions on what going on , so there are clunks coming from both wheelwells , it is MUCH more noticable when going over bumps and turning is the worst . its like when a wheel hits the bump that the clunking happens . also it feels like the car want to swerve when i hit bumps at higher speeds ( anything over 40 ) . its legitimatly scary , and if there is a major problem i want to know what it could possibly be.
my girlfriend takes my car sometimes and i couldnt think what id do if she got hurt in my car.
sam fisher is offline
Old 11-12-2012, 02:08 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,312, Level 75
Points: 13,312, Level: 75 Points: 13,312, Level: 75 Points: 13,312, Level: 75
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 99%
Three main joints that are common wear items in the front end:
Ball joint - attaches suspension arm to steering knuckle
Tie rod ends (inner & outer) - attach steering rack to steering knuckle. outer end MUCH more common to wear out, and your swerve note points this way
Sway bar links - attach sway bar to struts, most common for rattles going over bumps
Nothing to mess with when you have symptoms that ANY are worn out! One friend of mine who likes to drive things 'till they break recently had a ball joint break, luckily on an off ramp & not still at highway speed. Wheel jammed back against the fender & it skidded to a stop. Bent fender (and door from opening it into the bent fender), ball joint replacement (obviously), new CV axle (pulled out & dragged on road), and a new tie rod end as that was ready to go as well!
Get it checked out right away, or post back for hints on what to look for...
luck!
sailor is offline
Old 11-13-2012, 07:06 PM   #3
pasta
Fan#: 62350
What I Drive: 2003 eap svt
Points 10,262, Level 67
Points: 10,262, Level: 67 Points: 10,262, Level: 67 Points: 10,262, Level: 67
Level Up 53% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 5 pasta Good Standing Member
Buy-Sell-Trade Rating: (42)
turn wheel all the way left make full turn then right full turn if you here clunk thats the cv joint repair immedietly
pasta is offline
Old 11-13-2012, 07:41 PM   #4
sam fisher
I hate dents!
sam fisher's Avatar
Fan#: 103137
like while driving?
Sent from my N860 using FF Mobile
Old 11-19-2012, 10:30 AM   #5
some-guy
Fan#: 104223
What I Drive: 91 Supra Turbo, 00 ZTS
Points 27, Level 1
Points: 27, Level: 1 Points: 27, Level: 1 Points: 27, Level: 1
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 1 some-guy Good Standing Member
luck!
I have almost exact same symptoms on a 00 focus I picked up not too long ago
Sent from my HTC VLE_U using FF Mobile
some-guy is offline
Old 11-19-2012, 01:02 PM   #6
sam fisher
I hate dents!
sam fisher's Avatar
Fan#: 103137
annoying huh . i wish i could just redo the front end with all heavy duty components n stuff . things just keep failing up there
Old 11-19-2012, 03:22 PM   #7
04ZTSJelf
04ZTSJelf's Avatar
Fan#: 100701
What I Drive: 14 SE
Points 1,510, Level 22
Points: 1,510, Level: 22 Points: 1,510, Level: 22 Points: 1,510, Level: 22
Level Up 10% Completed
Forum Activity 18%
FF Reputation: 1 04ZTSJelf Good Standing Member
Buy-Sell-Trade Rating: (7)
Might have that same issue.
Old- 04 2.3
New- 14 SE
04ZTSJelf is online now
Old 11-27-2012, 07:18 AM   #8
some-guy
Fan#: 104223
Points 27, Level 1
Well my problem was DS ball joint, and PS end link. I replaced both LCA and end links. No more noise for the time being.
some-guy is offline
Old 11-27-2012, 10:40 AM   #9
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,772, Level 54
Points: 6,772, Level: 54 Points: 6,772, Level: 54 Points: 6,772, Level: 54
Level Up 11% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
You should start replacing the others a little at a time FTW
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
