HID on third gen focus, WITH DRL - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-27-2013, 02:55 PM   #11
klotche
klotche's Avatar
Fan#: 91834
What I Drive: 2012, Oxford white, Focus
Points 4,425, Level 42
Points: 4,425, Level: 42 Points: 4,425, Level: 42 Points: 4,425, Level: 42
Level Up 38% Completed
Forum Activity 3%
FF Reputation: 3 klotche Good Standing Member
Originally Posted by Graeme S View Post
I was just turned on to that by a friend of mine who did his retrofit a little while ago. I got in touch with Andrew, and am having a bit of back-and-forth with him discussing different options.
Canadian cars come standard with DRLs (law since '89) and usually it's the highbeams on reduced power. My car's in the shop at the moment 'cause I got rear-ended by an X5 two days ago, so I can't just walk out and check--is it the same for the Focus? If not, I may ask my buddy to see if he can rewire the fogs to just always be on whenever the car's running.
No it's not, Focus mk3 uses DRL on low beams, at a reduced voltage (9 volt)...
Easiest way for me was to add a relay harness + resistor... I did wire a switch on my relay harness that goes to the interior of my car, like this I can close ALL lights, and all power is sent to my resistors. When i open this switch, i get my low beams (HID). I never get bulb out error cause of resistor, and i can control my lights like I want (only low beams, only fogs, or both). It's my way of by-passing those DRL
klotche is offline
Old 01-27-2013, 02:57 PM   #12
klotche
klotche's Avatar
Fan#: 91834
Forum Activity 3%
Originally Posted by Brad52693 View Post
Where did you purchase your HID kit from?
www.vvme.com
Very good quality though. I did install on my fog lights the ballasts I had on my cirrus 1997 4 years ago... still working pretty fine (3 years used)
klotche is offline
Old 01-31-2013, 12:58 AM   #13
Graeme S
Fan#: 101487
What I Drive: 2012 SBM Focus Titanium A/T
FF Reputation: 1 Graeme S Good Standing Member
Hmm. The car is used mostly by my mom, and so I'd rather not deal with a whole bunch of switches and fancy thingies all over. And I'd really rather she didn't get pulled over for not having DRLs on her car. Police where I am are kind of infamous for dinging people on things like that.
I don't suppose there's a way to wire up something else as a DRL instead without throwing a code? Perhaps one of those LED grills that's floating about on Ebay?
Graeme S is offline
Old 01-31-2013, 01:05 PM   #14
twinbiker11
twinbiker11's Avatar
Fan#: 108461
What I Drive: 2013 white Focus se, sport package
Points 406, Level 8
Points: 406, Level: 8 Points: 406, Level: 8 Points: 406, Level: 8
Level Up 12% Completed
FF Reputation: 1 twinbiker11 Good Standing Member
Anyone tried putting in 55 watt ballast and seeing if they work without resistors or relays?
2013 oxford white se + sport package
FS WERKS! race exhaust and Short ram intake.
Sct Tune from Tom for 94 octane
15.22 sec @ 94mph 1/4m time
twinbiker11 is offline
Old 02-02-2013, 07:28 PM   #15
Graeme S
Fan#: 101487
I just emailed TRS to ask about options for DRLs and see what they say. Worst comes to worst I think I'll pick up a set of those Ebay LED grills and wire them in and see what I can do to bypass the standard lowbeam DRLs.
Twinbiker, seems like you're in the neighborhood, what've you got running for your HIDs and your DRLs?
Graeme S is offline
Old 02-04-2013, 04:42 PM   #16
klotche
klotche's Avatar
Fan#: 91834
Forum Activity 3%
In my idea, it wont work, cause you still need anyway a relay harness, which means your connected to only 1 OEM plug (driver side for me..), so you need 1 resistor to avoid bulb out error on passenger side...
Plus, DRL on those focus are giving only 9 volt, which isn't enough to run those ballast... so you can't imagine running them without that relay harness.
There is more fact that makes me think it won't work with DRL, but that much summarize it
klotche is offline
Old 02-12-2013, 09:24 PM   #17
Dalamar
Fan#: 94696
What I Drive: 2012 SE hatch Blue Candy
FF Reputation: 1 Dalamar Good Standing Member
I ordered mine from https://www.ddmtuning.com/ I get my LED bulbs there too.
They said that because of the wiring in the car I had to use 55w for it to work properly and then said they couldn't sell me them if i lived in Cali, but since I live in Florida..... and you do have to pull the fuse for the DRL
Anywho when I bought them for my honda's they were plug and play, I've been happy with them in the past, great support and install guides on their site, they mostly do bmw stuff...
I also noticed they sell carbon fiber in fabric...I just haven't decided what to cover with it.... http://www.ddmtuning.com/Products/Carbon-Fiber-Fabric
Dalamar is offline
Old 02-15-2013, 09:22 AM   #18
klotche
klotche's Avatar
Fan#: 91834
Forum Activity 3%
Good luck in finding that fuse ! : there isn't any !!
to turn off those DRL, you have to go to the dealer, and ask them to turn them off with their OBD2..
You live in florida... shouldn't be a problem.... but for us in Canada, DRL are an obligation by the law, none of the dealer I contacted wanted to turn them off for me .. unfortunatly...
But there is a way!, that's why i got mine working :)
klotche is offline
Old 02-27-2013, 01:37 PM   #19
Sean05
Sean05's Avatar
Fan#: 62491
What I Drive: 13' ST2
Points 1,627, Level 23
Points: 1,627, Level: 23 Points: 1,627, Level: 23 Points: 1,627, Level: 23
Level Up 27% Completed
FF Reputation: 5 Sean05 Good Standing Member
Buy-Sell-Trade Rating: (4)
lol do everyone a favor and retrofit them..
After asking a friend with 07 sedan if he wanted to race " I'm gonna loose! Mines not a zx4!! "
Sean05 is offline
Old 03-04-2013, 02:18 PM   #20
dbsimms63
Fan#: 110359
What I Drive: 2013 Performance Blue Titanium 5dr
Points 1,797, Level 24
Points: 1,797, Level: 24 Points: 1,797, Level: 24 Points: 1,797, Level: 24
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 3%
FF Reputation: 2 dbsimms63 Good Standing Member
Originally Posted by apaolucci View Post
this is what im going to use for conversion ...
http://www.theretrofitsource.com/pro...roducts_id=227
Nice looking system, saw a picture of a MK III focus assembly with the kit on their site, looks really nice.
dbsimms63 is offline
