coilover and camber advice.... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-12-2012, 03:05 AM   #1
FilthyFocus
FilthyFocus's Avatar
Fan#: 51308
What I Drive: 2003 Red ZX3
FF Reputation: 1 FilthyFocus Good Standing Member
so im already lowered about 1.2 in on tein h tech springs all around....i get some camber wear especially in the front. Im planning to buy coils and i want to go low. i already have my front fenders rolled and i am running 205/40 tires on some 17 x 7 rims...whats the best camber kit for the front? The FSwerks plates? and for the rear since i wanna go super low i should go with the camber arms right? any help would be appreciated.
FilthyFocus is offline
Old 11-12-2012, 07:57 AM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,966, Level 74
Points: 12,966, Level: 74 Points: 12,966, Level: 74 Points: 12,966, Level: 74
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 99%
So what do you want to do? Camber wear & you want coilovers to go lower? And whats the offset of your wheel's? What is your camber now= front & rear? The best way to adjust front camber is using CFM's tubular control arms w/ Suremotorsports rear arms. Seems like you have the wrong offset wheels running 205/40's & have to roll your fenders.
felixthecat is offline
Old 11-12-2012, 12:50 PM   #3
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
We need to know what your current specs are before we can determine whether its strictly a camber problem or not. The front end of a Focus tolerates more camber than the rear does. Most front tire wear problems are associated with "toe" issues. In other words, you can run a fair amount of camber up front without excessive tire wear, if the toe is set correctly. On an 03 you want your camber to be anywhere within the spec range (and that's pretty broad). On a car with rubber bushings you want a smidgen of toe-out (.01 to.02 inches...but no more!). If you have poly bushings up front, set it at zero toe.
Geezer is offline
