Pinch Bolt problems - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-11-2012, 07:32 PM   #11
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
CUT the nut/bolt off then punch the bolt through without having to mess with the torx end. An angle grinder is about $9 at harbor freight - use a metal cutting disc.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 11-11-2012, 07:34 PM   #12
nate4027
Fan#: 105354
What I Drive: 2003 Competition Orange Svt
FF Reputation: 1 nate4027 Good Standing Member
I tried that just going to try and drill it completely out now.
nate4027 is offline
Old 11-11-2012, 07:48 PM   #13
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
What I Drive: 2000 Explorer 4x4, 04 Mini Cooper S
Points 4,610, Level 43
Points: 4,610, Level: 43 Points: 4,610, Level: 43 Points: 4,610, Level: 43
Level Up 30% Completed
Forum Activity 4%
FF Reputation: 28 ah1f39 Great Standing Member
The strut pinch bolt threads to the knuckle. The ball joint pinch bolt has a nut. Wich one did you break?
Your first post said lower. That would be at the ball joint wich has a nut.
ah1f39 is online now
Old 11-11-2012, 09:04 PM   #14
nate4027
Fan#: 105354
It's at the lower ball joint. I undid the nut and tried to tap it out with a hammer but no luck. So then I cut the head off and tried to drill it out. I assumed the steering knuckle was threaded and the pinch bolt was seized.
nate4027 is offline
Old 11-11-2012, 09:08 PM   #15
hEaT
Fan#: 20699
What I Drive: 2013 Oxford White Focus ST
Points 3,049, Level 33
Points: 3,049, Level: 33 Points: 3,049, Level: 33 Points: 3,049, Level: 33
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 11 hEaT Great Standing Member
The lower pinch bolt is only threaded into the nut. I had to hit mine with an air hammer to remove, for a while.
When you replace the bolt, use a hex head bolt and SOAK it in anti-seize. Probably a good idea to replace the LCA with ball joint now since the process of removing the bolt like this buggers the ball joint.
ZETEC Crew #49
Originally posted by DrkKnight614
......hmm if that works then if i put a spinner on my butt hole and rip one will i be able to run faster. ...idiots
hEaT is offline
Old 11-11-2012, 09:12 PM   #16
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
Forum Activity 4%
It is not threaded. The one we broke took a 20ton press to break loose. Remove the knuckle and control arm and take it to be pressed out.
Old 11-11-2012, 09:20 PM   #17
nate4027
Fan#: 105354
Ah ha. That's what I will do then. Thanks for the help everyone. I could have swore that was threaded in there because I was smacking it pretty good.
nate4027 is offline
Old 11-11-2012, 09:24 PM   #18
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
Forum Activity 4%
Crushed a mild steel bolt trying to press the pinch bolt out. Had to use hardened steel. Took 3 tries at full pressure. Then POP out it came, good as new.
Old 12-31-2012, 03:28 PM   #19
nate4027
Fan#: 105354
Got the lower control arm/ball joint combo put back together but found it odd the my Haynes manual called for 170ft lbs of torque on the front bolt. Is it just me or does that seem like way too much?
nate4027 is offline
Old 12-31-2012, 03:34 PM   #20
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
Forum Activity 4%
170Nm? 170ftlbs is twice what the tq should be.
